Hello!
I am having some problems with my fuel tank leaking, i need to disconnect the fuel pump relay so i can drive on TNG until i fix the gasoline tank. I dont know which one is the fuel pump relay.
There are 10 cubes and can someone tell me which one is it?
Thanks!
Let's teach you to fish for yourself, because it's worth much more than just this single answer.
GO TO:
http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf
This is the factory wiring diagram and electronics manual for your car.
After it loads, scroll down the list on the left, to group 7000 - Component location charts
Now, scroll through those pages until you come to "K" group, which is the relay group. Find fuel pump relay.
AHA! There are 2 of them! They are referred to as K210, and K211. (You have two, because like everything else on a 750's engine, each half of the engine runs as a six cylinder engine, so you have two computers, two distributors, etc.) You'll see they are listed in the right column as having Component Location views, on page 7100-24, view 01. Flip back to the left column, click on 7100 (Views), go to page 7100-24, look at view 1.
And there they are, above the right front wheel well in the aux relay box, just like the picture showed.
Chris Powell
BMWCCA 274412
Thanks for answer!
Now i found third pump relay its on page 7100-01 named K201. Maby it's that one for the M30 engines or the M70 too have it?
No, just the two on the far right of the aux relay box.
Chris Powell
BMWCCA 274412
not all 750 M70 have the fuel pump relays on the far right of the aux box, up to 1988 they are in the middle, K210, K211, http://bmwe32.masscom.net/sean750/fu...gFuelRelay.jpg
from 08/1988 built year K210 and K211 are farest right http://www.e32-schrauber.de/bmw/s-relaisbelegung.htm
Relay Fuel pump 13631725654 1725654, Siemens 5WK2222 it is a black relay on my 11/88 750 and on top is written BenzinPumpeRelais = fuel pump relay, do not mix that up with the DME relays.
Only used on E32 750, BMW Relay (Si121 09-89) - BMW 13631725654 Pins 31, 50, 1 , 87b, 87, 15, 30. https://recyclebmws.com/bmw-e32-7-se...654/#gallery-3
alternative: STANDARD IGNITION RY-1663 - Intermotor Fuel Pump Relay, STANDARD MOTOR PRODUCTS RY1663 , price abt. $100,--
The fuel pump will only run when ignition is in position 2 and it gets a signal that ignition sparks are coming.
31
50
87b
87
15
30
Terminals definitions http://www.e38.org/understanding%20e...20diagrams.pdf
