Bought a GoPro to record her with =)
Reach out to me once you start. Depending on the build year coding can be a pain. Also if you want better than new e36 shift lever performance i can let you know what parts to get as far as zero wiggle in gear, short throw and zero notchiness. Coming from 2 oem e36 manuals i live the way this set up is 100x more.
The downside to purchasing a 20yr old car with only 60k miles on the clock, my vcg went, so i just replaced that. O2 sensor up next. Look at that top end though.
Current:
1988 Alpine White M3
1997 Boston Green E36 M3 4dr
Past:
2007 Interlagos Blue BMW M5 SMG
2004 TIAG BMW 330ci zhp 6mt
2000 Gold Metallic B5 Audi A4 1.8T QT 5mt
1999 Cosmos Black BMW 318ti 5mt
1997 Montreal Blue BMW 318ti 5mt
Its quite the laundry list. Various seals and teflon bushings from ecs tuning. Also new oem m3 shift linkage and selector rod, z3m shift arm. Attached is my order summary for reference. The shifter rebuild/upgrade kit as well.
Current:
Past:
new tires (dunlop zii star specs)
and alignment
O2 Sensors, DrColorChip, rear OEM speakers, and trim paint for the front lip.
Brand new fender liners + hardware, motion motorsports underpanel and baffle, and a new MKAH motorsports trunk delete panel.
Driver's side front door lock actuator so I don't have to climb in and out of the window like a NASCAR driver. And air filter, cabin filter, and fuel filter.
GT splitters to even out the big GT2 wing on the back.
DSC_0626 by Chris West, on Flickr
DSC_0636 by Chris West, on Flickr
got a nice RMS Stage2 SC kit for S50B32 euro engine
S50B32 341Bhp@7800Rpm, CDA SP03, Supersprint manifold+decat+Rear race exhaust, BMW Performance Brembo 6/2pot brake with E46 M3 CSL discs, KW V3, H&R sways, Motorsport strut bars, fully powerflexed, GT2 optic, 19" BBS RS-GT wheels with Michelin PSS.
Just mounted the (Blower) Final Stage Unit 64116929540 , what a PITA to get at!!! BUT Wifey now has a HIGH speed!
Had her 2 new 225/45/17 Dunlop DZ102 UHP Summer tires mounted on the front.
Brand Spanking New WV inspection stick this morning $15.
Guaranteed +5 HP when you climb in and out of the window like a NASCAR driver LOL, +10 HP when you make the passenger do it too LOL.
'Sweetness Tres' M44, 1.9L Z3 5-Speed Roadster '97 Boston Green 66K Smiles Mine
'Sweetness Too' M52, 2.5L Z3 5-Speed Roadster, '00 Jet Black 165K Smiles 2022 Gone Ins Co Total in Jan 2022- Right Front Collision - Paid $8850 !!
'Ol' Black Betty' S52, 3.2L ///M3 5-Speed Vert '98 Cosmos Black 265K Smiles Wifeys
M50, 2.5L 525i E34 Tragi-matic '95 Sedan Alpine White III 238K Smiles Was Daughters Mine Again
'Gretchen' M30, 3.5L 535i E34 Tragi-matic '90 Sedan Glacier Blue/Indigo 144K Smiles 2018 Gone & I miss her
'Sweetness' M44, 1.9L Z3 5-Speed Roadster '96 Boston Green 264K Smiles Was Mine Ins Co Total in Jan 2013- Rear End Collision - Paid $4800 !!
Passenger & Driver exterior door handles, gaskets, trim, an extra key (all coded), and a brake switch. Definitely not looking forward to replacing ANY of that =/
as you said its only credit card
Hahahaha. I got the old actuator out and the door unlocked, but the door will still get stuck locked if I lock it, even without the actuator installed... I'm afraid to install the new one in case it doesn't fix it. Unlocking it isn't easy when it gets stuck!
What does add/restore a ton of HP is installing new precat O2 sensors and new air filter (which looks like it had never been changed)! This car is amazing to drive, even with my "VANOS Mechanically Stuck".
p.s., if you accidentally swap the connectors for your O2 sensors you'll know in about 30 seconds of driving!
Installed Xbrace, purchased LTW motorsport glove box, having fikses redone for bimmerfest - its going to be hit or miss if they're done, have michelin PSS for them, have a fresh alignment for them, picked up style 5s for my e34, and some other non important stuff..
Herr, wirf Hirn vom Himmel! ... oder Steine, Hauptsache er trifft.
88 Alpineweiss / black E30 M3 -Project.
Brilliantrot / black US SPEC 3/90 prod e34 M30b35 535i 5spd - Modded.
98.5 Tiag Silber /black e36 m3 - Modded.
99.5 Estoril Blau /dove e36 m3 - Modded.
07 Crimsonrot /black E83 X3 6spd - Stock..
Besian systems VANOS repair kit (including anti-rattle) and the tools and extras to do the job.
VANOS oil feed line
Oil Filter Housing Gasket
Valve Cover Gasket
Throttle body cooling hoses, because the previous owner removed them.
Brake Caliper Rebuild Kit -- one of them started sticking this weekend, plus BMW fluid
Spark Plugs (NGK BKR6EQUP)
Oil Service Kit
Finally getting around to redoing my front suspension...bought control arms/bushings/tie rods over 6 months ago.
Now, have ground control redo my front struts (10 years old)
In the meantime, fixing little projects:
-new ///M3 floor mats
-new shift/ebrake boots (alcantra)
-installing new knee panel
-fixing dark spots on cluster
-new ///M3 door sills
-new driver vent/light housing
-new sway bar bushings (poly)
-getting lux door/rear panels finally refurbished (alcantra inserts)
1997 Arctic Silver/Black M3
1999 Techno Violet/Dove M3
-Rear caliper rebuilt kit, which amounts to some seals and dust boots.
-Bleed valve screws x2
-Stainless steel caliper pistons x2
-Brake pads
-Brass brake caliper guide bushings
-Powder coating for the torn down calipers.
-VIS CF hood via Amazon.
1988 911 - Carb'd - Twin Plug - 3.6
1999 SL 500
2016 4Runner TEP - Gone
1995 M3 - LS2 - Gone
1998 M3 - Gone
1991 M5 - Gone
1993 RS America - Gone
1995 M3 - Gone
