Page 37 of 37 FirstFirst ... 122728293031323334353637
Results 901 to 919 of 919
Thread: What did you buy for your e36 M3 this week v3.0
  1. #901
    Jan 2013
    Ottawa, ON, Canada
    '99 M3 vert, '07 X3
    Ignition Project IP coils and and NGK IX Iridium one step colder plugs (7 temp).
    Had the BavAuto coils in her for about 8 years and they are still working fine but I read all the propaganda about Okidata Plasma coils and realized the IP are the identical coil at half the price and the company just changed their name.
    Obviously not expecting a big change but I can say my idle is a little less stumbly (which would probably be the same with ANY fresh coils and plugs).
    Level 3 Active Autowerke supercharger, Schrick Cams... and all the supporting mods... Figured a multiple firing coil couldn't hurt LOL.
  2. #902
    Jan 2013
    Ottawa, ON, Canada
    '99 M3 vert, '07 X3
    Track time! Did my first ever track day. All day event at a very technical track (Calabogie Motorsport Park) and learned that I am definitely a comparatively slow driver of a VERY fast car! The nut behind the steering wheel is going to need some significant upgrades! 🤣
  3. #903
    Jun 2022
    Austin
    1999 m3 coupe
    BAVSOUND STAGE ONE SPEAKER UPGRADE FOR 1996-1999 E36 COUPE/SEDAN WITH HARMAN KARDON
    Glass fog lights (old ones broke)
    Wind shield wipers
    Sony stereo
    New head lights (from dad)
  4. #904
    Aug 2018
    Ne
    M3,69 Swinger
    New fuel pump, fr struts,shifter rebush,plugs,coil packs,cam pos sensor,crank pos sensor,staggered Contours,
  5. #905
    Aug 2018
    Ne
    M3,69 Swinger
    Rear trailing arm Turner mono balls,Bav sound speaker upgrade,Continental Bluetooth stereo
  6. #906
    Aug 2018
    Ne
    M3,69 Swinger
    New rear brake lines stainless & rubber
  7. #907
    Feb 2018
    California
    1991 BMW 325i Sedan
  8. #908
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I will be buying an inspection sticker this month for the 99 that I have owned for 18 years.
  9. #909
    Feb 2019
    Memphis, TN
    1999 BMW 328is
    In the process of doing many things.
    Head gasket
    Turning valves
    Rebuilding rear calipers.
    Flush with new brake fluid
    New rotors/pads
    New vanos oil line
    Oil filter housing gasket
    New guibo
    New speakers, sourced myself, then cut down to fit into the cylinders
    Middle arm rest cover
    Patch up missing leather on steering wheel
    Patch some ripped driver's seat leather
    A lot of it is a long time coming.
  10. #910
    May 2003
    Chicago
    '95 M3
    New tires, including a new spare to replace the 1995 one in the trunk!
    "And also, let's not forget let's NOT forget, Dude, that keeping wildlife... um, an amphibious
    rodent, for... um, you know, domestic... within the city. That ain't legal either."
  11. #911
    Jun 2022
    UT
    1997 M3/4/5
    msportparts euro light harnesses (removed failing HID kit. may go back to HID later but want to focus on mechanicals)
    msportparts trans tunnel brackets
    corteco trans mounts
    corteco motor mounts
    front door handle gaskets
    valve cover gasket
    throttle cable
    next up tires, windshield seals, trans & diff fluid, then new starter and injectors rebuilt when subframe is down for bushings and oil pump nut. Gotta plan that one out a bit. maybe next year, maybe in the fall. car is seeing about 10k mi/year right now. mulling a move to somewhere where I wont have my own space for a while (still 2 years out), so any other futureproofing suggestions welcome. ill do rear subframe/rtab reinforcements, full brake job, and fuel pump before said move too.
  12. #912
    KC
    1995 M3 & 1998 M3 coupes
    Just a few things taken right from my spreadsheet.
    Alternator - Bosch - 80 Amp $316.99 6/12/2023 12311744565
    BMW Radiator Hose Upper - Genuine BMW $51.99 6/12/2023 11531708499
    BMW Thermostat Housing Gasket Genuine BMW $10.19 6/12/2023 11531740437
    Aluminum Thermostat Housing, URO $23.74 6/12/2023 11 53 1 722 531
    M16 Crush Washer, Copper (6 total) $5.94 6/12/2023 32 41 1 093 597
    M16 Crush Washer, Genuine BMW (Aluminum 6 total) $8.46 6/12/2023 32416773722
    Manual Transmission Shift Shaft Seal (Elring Klinger) $2.99 6/12/2023 23121282394
    Genuine BMW Oil Filter Housing Gasket $9.12 6/12/2023 11421719855
    BMW A/C Belt Tensioner Damper $45.29 6/17/2023 11281717210
    BMW Belt Tensioner Base Plate Bearing $29.67 6/17/2023 12311713153
    Genuine BMW Inner Right Window Channel Cover $100.99 6/17/2023 51218201064
  13. #913
    NY
    skateboard
    AL head lights to replace the depos
    ― George Orwell
  14. #914
    Jun 2022
    UT
    1997 M3/4/5
    Quote Originally Posted by GG///M3 View Post
    Jealous. Where did you source them?
  15. #915
    NY
    skateboard
    eBay
    ― George Orwell
  16. #916
    Apr 2021
    Mesquite, TX
    '97 M3
    Disassembled the rear driver's side suspension, removed the bearings and bushings. Will be tackling the passenger side today. Will remove the diff/cradle afterward, remove the tank, clean everything, and get some RTAB reinforcements added.
  17. #917
    Aug 2023
    East Peoria, IL.
    1999 BMW M3 Convertible
    Weather tech all weather mats. Dyno sheets show a .025 hp gain 😎
  18. #918
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    Quote Originally Posted by QuickMcRunFast View Post
    Yeah, but that's on a dynojet. All the rest only show .015 hp.
    See ya later,
    tony
    '98 M3, '92 Dinan3, '05 R1100S BCR, '07 R1200S, Aprilia T
  19. #919
    Mar 2024
    Pacific northwet
    1999 M3 convertible
    I registered it, the tags were from 2019 woke up the old girl last week from her 6 year slumber.
  1. E36 WANT TO BUY: Avus Blue E36 M3 Mirror and Hood (NY area)
    By emericanmilitia in forum Exterior Lighting & Body Parts
    Last Post: 04-13-2020, 05:59 PM
  2. E36 Want To Buy Hard top E36 M3
    By showtimex22 in forum 3 series & Z Series
    Last Post: 10-30-2014, 03:38 PM
  3. Considering buying a used E36 M3 - ?'s
    By justin.b in forum 1992 - 1999 M3 (E36)
    Last Post: 07-20-2003, 10:01 PM
  4. Possibly buying a used E36 M3 (OBD I or OBD II?)
    By Deutscher Konnt in forum 1992 - 1999 M3 (E36)
    Last Post: 02-03-2003, 01:04 AM
  5. Would you buy a used e36 M3 with a supercharger?
    By joeyc in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-26-2002, 09:52 AM
