Page 11 of 38 FirstFirst ... 2345678910111213141516171819202136 ... LastLast
Results 251 to 275 of 932
Thread: What did you buy for your e36 M3 this week v3.0
  1. #251
    Aug 2013
    Houston
    99M3, 95Dakar, e46Zhp
    dr. vanos
    Coming Soon! thebimmerdude Youtube Channel.... Everything Bimmer...Everything...duuuddee
    1999 e36 Convertible Hardtop - Sypder (byebye softtop conversion )
    http://www.bimmerforums.com/forum/sh...5#post28143955
  2. #252
    Mar 2014
    san diego
    E36...
    Motor mounts, trans mounts, guibo, center support bearing and idler pulleys
  3. #253
    Aug 2013
    Houston
    Quote Originally Posted by jesus619 View Post
    make sure you tq that guibo... ask me how i know
  4. #254
    Mar 2014
    san diego
    E36...
    Quote Originally Posted by M3Dynamic View Post
    How do you know? Lol jk. Def gonna tq that sucker, thanks for the tip. Point me in the right direction for ss headers or raceland better? All I need is headers, bbtb and cat delete to be full bolt ons lol
  5. #255
    Jun 2004
    Columbia, SC
    97 M3, 80 320i, 07 328it
    Activated carbon canister shut off valve + 4 O2 sensors to get rid of check engine light. Seat belt tensioner to get rid of airbag light. New door handle trim. New flasher relay so hopefully my turn signals will work again.
    1997 M3 | 1980 320i | 2007 328it
  6. #256
    Mar 2013
    Albany, ny, usa
    96 M3. 94 E34. 98 750il
    just picked up a set of DS2's in near mint condition. Been wanting a set since i bought my M. i'll keep the contours for track tires (if i ever have time to make it to the track)
  7. #257
    Indianapolis, IN
    951, LTW M3, Esprit S4s
    3.0 euro cluster, new bulbs, new pin/wire for oil temp, rally road oil block, VDO sender, Z3M ASC delete boot, z3m idle valve hose.
    86 951
    95 M3 LTW - S54 http://www.bmwmregistry.com/detail.php?id=15735
    95 Esprit S4s
  8. #258
    Queens, NY
    destiny
    Condor speed differential and subrame bushings, new armrest.
    Current
    2008 E70 4.8 BSM/Black - 100% Options2007 335i SG/Coral Red - 6MT - Ets, Spec, BMS, VRSF, Broadway Static
    2004 325i AW/Black
    Past
    2000 M5 Silverstone/Silverstone - ST Coilovers
    1998 E36 M3 - Tiag, Bride Gias, RK Tunes, M50, AA Track Pipe..
  9. #259
    Boston, MA
    n/a
    99 M3 coupe
  10. #260
    Feb 2015
    San Diego, CA
    1999 BMW M3 Cosmos Black
    M50 manifold!!!
  11. #261
    Oct 2013
    Upland, CA
    97 E36 M3 Coupe
    Amir'S Front Splitter
    Actually bought picked this up from Amir @ Avus earlier this week. Waited until it was tested and true at the track (today). Beautiful piece, well constructed and functional. Some of the best money spent! In combination with true R-Comp tires and a 3.64 differential, I bettered my best time by 3.9 seconds today @ Auto Club Speedway.
    Cheers
    97 Artic Silver E36 M3 Coupe; Track RAT (Thanks to Irish M3 for the guidance)
    Full Track suspension via TC Kline; TMS and BW; BFG R-Comps; Custom Splitter made by Amir; 3.64 LSD 40% Lock-up; 24lb inject; M50; Dinan TB; 803; 3.5" CAI; Supersprint LTH & AA 3" race exhaust; S54 oil pump combo; BW fuel starvation kit; tuned by Epic Motorsports (thanks to Randy Mueller...253/242 on race gas via DynoJet)
    https://www.facebook.com/groups/bimmerchallenge/
  12. #262
    NY
    skateboard
    Where did you pick up the 3.64?
    I purchased these.
    ― George Orwell
  13. #263
    Oct 2013
    Upland, CA
    97 E36 M3 Coupe
    [QUOTE=GG///M3;28334086]Where did you pick up the 3.64?[quote]
    a guy in SoCal who buys them, tears them apart, inspects them, builds them to spec, replaces what needs to be replaced (e.g. Pinion gear; clutch pack etc.) and re-specs the tolerances then re-seals them.
    Sergio: (818) 261-6876
  14. #264
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    Mcoupemindy in Virginia builds diffs too.
  15. #265
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Quote Originally Posted by havasusteve1 View Post
    Cheers
    i get the feeling you don't run any kind of undertray except the splitter?
    TIA
  16. #266
    Oct 2013
    Upland, CA
    97 E36 M3 Coupe
    Quote Originally Posted by doktor b View Post
    TIA
    Yeah, no fender liners and just this. Well, actually I have brake duct lines and an oil cooler, but the setup allows for the 4-nut only front fender removal.
  17. #267
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    ^^^awesome.
    i may just build a gnarly splitter for my M instead of messing around with an under tray and then a splitter.
  18. #268
    Indianapolis, IN
    3.0 Euro cluster in, mileage recoded, oil temp wired in, ASC deleted and a new vent piece above the glovebox as all the tabs on mine were broke, hopefully that cures the saggy glovebox. S54 Z3M radiator also arrived.
    86 951
    95 Esprit S4s
  19. #269
    Aug 2013
    Houston
    Bosch 24lb injecotrs
  20. #270
    Mar 2013
    Albany, ny, usa
    just bought a new set of staggered PSS's.
  21. #271
    Indianapolis, IN
    glovebox fix success, no more sag. If anyone wants to fix it correctly just buy a new vent piece (all 4 of my plastic clips were broken on that piece). $61.70 from ECS.
    86 951
    95 Esprit S4s
  22. #272
    Dec 2002
    Bay Area, CA
    e23, e28, e36
    Thanks for posting this!!!
    Quote Originally Posted by SamGrant951 View Post
  23. #273
    Sep 2012
    Moscow, Russia
    1992 318iS, 1997 328iS
    I apologise, but what parts from ECS do you mean? I don't understand.
  24. #274
    Nov 2013
    Poughkeepsie, New York
    1999 BMW M3 Coupe
    KW Variant 1s, Rogue Engineering RTAB, and a Momo steering wheel hub with nardi adaptor.
  25. #275
    Dec 2008
    NYC
    95 M3/2/5, 2011 Audi A4
    new shift knob..
  1. E36 WANT TO BUY: Avus Blue E36 M3 Mirror and Hood (NY area)
    By emericanmilitia in forum Exterior Lighting & Body Parts
    Last Post: 04-13-2020, 05:59 PM
  2. E36 Want To Buy Hard top E36 M3
    By showtimex22 in forum 3 series & Z Series
    Last Post: 10-30-2014, 03:38 PM
  3. Considering buying a used E36 M3 - ?'s
    By justin.b in forum 1992 - 1999 M3 (E36)
    Last Post: 07-20-2003, 10:01 PM
  4. Possibly buying a used E36 M3 (OBD I or OBD II?)
    By Deutscher Konnt in forum 1992 - 1999 M3 (E36)
    Last Post: 02-03-2003, 01:04 AM
  5. Would you buy a used e36 M3 with a supercharger?
    By joeyc in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-26-2002, 09:52 AM
