Page 3 of 22 FirstFirst 12345678910111213 ... LastLast
Results 51 to 75 of 548
Thread: S38B38 into my 1977 e12 chassis'd 633CSi
  1. #51
    Aug 2008
    Sydney Australa
    1x633, 1x E3 2 DR Racer
    Car drives great with the 17 inch wheels. 17x225. Really holds the road well and a huge leap over 14x195. Scrub fronts just a little at full lock but never been an issue and only absolute full lock. Changes the road holding completely. Note that I run Bilstein Sports Shocks and my springs are 40mm lower and 40% stiffer. You may have no issues what so ever if your spring/shock setup is stock. The scrubbing is so minor it has never marked the wheels and only buffed the rear of the front wheel arches over a very small area, like 20mm by 50mm missing a little under-body tar.
    More photos and vids to come. Want to dyno the car to get engine tune right.
    Was always slow on the updates as the car was 850kms away in another state. Now she is home I can play, photo and vid far more.
    1977 633 CSi RHD Euro. S38B38 3.9L M5 Transplant. 5 Speed Getrag Dogleg. 3.73 LSD. 417hp, 369lb/ft
    1971 3.0CS E3 2dr Alpina Special Coupe Racer, 347hp, 295lb/ft
  2. #52
    Feb 2012
    Hagerstown, MD
    1985 M635; 2010 Z4
    I applaud your efforts and success. Well done, mate.
  3. #53
    Socal
    Euro 81 628csi. 02 325i
    Thats reassuring, thank you.
  4. #54
    Aug 2008
    Sydney Australa
  5. #55
    Aug 2008
    Sydney Australa
  6. #56
    Sep 2010
    CA
    1985 635csi
    Thats a great exhaust setup , looks a lot lighter than stock. Love those '77 front valences
  7. #57
    Sep 2009
    Lititz, PA
    99 740iL, 12 VW TDI
    Have to agree with that early front valance. Though that single rear drain pipe detracts from the car's line. I've had many setups on my e 24. The best look for the car I think was a dual off-centered 3 inch pipes to followthe angle of the rear lower valance.
    Love your car, I had to settle for a low compression ugly US bumper US variant of the 86csi. I blew that engine test fitting a top mounted turbo set up for a built engine. Still building. She is waiting.
    Looking forward to video of your car.
  8. #58
    Aug 2008
    Sydney Australa
    It seems a car is never finished. Fixing the rear boots on the e28 rear subframe I never needed. Not a surprise that the crap mechanic that said it was needed (and it wasn't) did not ask me if I wanted the boots replaced as they were cracked. What sort of mechanic negligently advises you and then when sourcing second hand parts, fails to check their condition? Now that everything is in, it will cost far more. They could have been replaced in minutes when everything was disassembled.
    They are cracked and can be easily inspected. One has split throwing grease under the car and over the exhaust. All are badly cracked and can easily be seen without stretching or touching them. Really badly split and aged. BMW Australia wanted $180 each. I bought the set of 4 made in Italy for around $100.
  9. #59
    Sep 2009
    Lititz, PA
    99 740iL, 12 VW TDI
    Sucks dude....
  10. #60
    Aug 2008
    Sydney Australa
    boots fixed. onto the oil and hydraulic fluid leaks.
    The oil leak is very. About 100ml a day with engine off. It appears to be the timing chain cover.
  11. #61
    Sep 2009
    Lititz, PA
    99 740iL, 12 VW TDI
    Nope, that's the sump gasket leaking I reckon.
  12. #62
    Aug 2008
    Sydney Australa
    We checked the sump gasket. It appears fine. The timing chain cover dribbles onto the sump and sway bar and you can see it happening. But, to replace the timing chain cover gasket, which we can see but appears missing in places, we need to drop the front subframe and sump anyway. I have a new sump gasket to go back in as we re-assemble. So the sump, if it is an issue, will have a new gasket automatically.
  13. #63
    Sep 2009
    Lititz, PA
    99 740iL, 12 VW TDI
    Not a small job. Best to keep oil in the engine though I suppose.
  14. #64
    Aug 2008
    Sydney Australa
    Rear boots fixed. Will need to temp wrap that exhaust however or cook the boot.
    Now this is the cause of the hydraulic leak. The ex crappy mechanic's hooking up of the power steering, with an aluminium air conditioning pipe that the idiot bent by hand, seriously!! WTF?????!!! Aluminium fatigues if you bend it. Note the wonderful crimping as the lazy sod bent it. It cracked when he bent it costing me more money. The bill for his shoddy negligent work keeps adding up.
    The last two photos are the fixed hydraulic pipe. New, equal radius bends without crimping, aircraft aluminium with perfect welds. Compared to the absolute crap above you can tell the difference between a competent BMW specialist and a back yard hack.
    The timing chain cover is back on with a new gasket. The old gasket was torn and leaking oil so must have also been a source for a vacuum leak. Start up Monday and will test car again next week. Hopefully this one gasket was the source of the vacuum leak. If not we'll need to chase it down.
  15. #65
    Sep 2009
    Lititz, PA
    99 740iL, 12 VW TDI
    Nice work!
  16. #66
    Aug 2008
    Sydney Australa
    Time to crank up the power. I've decided to undertake the following and the order for parts is on its way.
    CATCAM 293/279 camshaft upgrade. See here: http://www.catcams.co.uk/acatalog/BM...v_Engines.html
    High Performance valve kit that includes high strength springs, spring seats, steel alloy retainers.
    High Performance valves.
    Megasquirt MS3-PRO engine management system with wiring loom. See here: http://www.ms3pro.com/
    The head is off and old valves out. Head is being decked and checked now.
    3.73 LSD sent off today to specialist for sand blasting, painting and new seals and fluids.
  17. #67
    Dec 2005
    Melbourne, Australia
    E24, E34 x2, E36
    Haha you have had it done 5min and upgrading. Sounds like a good plan. It's a good sized set of cams but u will need to confirm with your engine guy that you don't run into Piston to valve clerance. Also it's wise to consider slotting the cam wheels. Ultimately josh u will need to give your engine as much compression as you can to feed the bigger cams. Mid to high 11's is the number. Also consider using a thin spec cometic MLS rather than skimming the meat out of the head to gain the comp u need.
    BMW’s
    90 E34 M5
    84 E24 M635csi standalone ecu with coil on plug
    94 E34 540i/6 SC 5-17psi Flex fuel/standalone ecu
    97 Z3 2.8
    97 E36 M3 euro SC still u/c
    OTHERS
    11 Audi S5 APR stg2
    19 Volkswagen Amarok V6
  18. #68
    Aug 2008
    Sydney Australa
    Fitting diff now. Some modification needed as the rear top mount in the medium case diff was located centrally but the large case mount is offset to the left.
    Should be bolted up this week. And Dave, mechanic says the diff has been refurbished. We'll change the fluids but apparently the seals are new. Will also get it cleaned up.
    The megasquirt MS3-PRO is ordered and in the post. Hopefully the camshaft and running gear is ordered by mid week. 3-4 weeks to fab the camshaft then send it back to Aus.
  19. #69
    Sep 2009
    Lititz, PA
    99 740iL, 12 VW TDI
    That's some nice work there. Love your commitment to this.
  20. #70
    Socal
    Nice, i noticed you have replaced your rear trailing arm bushings. What did you use? and are they difficult to replace?
  21. #71
    Aug 2008
    Sydney Australa
    Quote Originally Posted by n2bimmer View Post
    Here are the best you can get. https://www.powerflex.co.uk/black-se...%29-803/1.html
    Bearings and bushes. Two of the hardest things to replace on a car. Just youtube it, you'll find plenty of methodologies and pick the best one for you. But very hard work.
  22. #72
    Socal
    Quote Originally Posted by Shipper View Post
    Thanks, my shop tech said he would have to take down the entire rear suspension/frame, he quoted $900 in labor, which is outrageous.
  23. #73
    Jul 2006
    Southern IN
    635csi, 325is, 740il
    Sounds about right, though. I don't see a better way to do it than to drop the rear axle carrier.
    Alex
    All cars are money pits, it's just that some people love theirs more than others.
    The '85
    The '83
  24. #74
    Aug 2008
    Sydney Australa
    Quote Originally Posted by Alex E24 E30 View Post
    Alex
    Yeah, I have a mate here in Australia who was quoted $900 for the same work. So I'm agreeing with Alex. $900 is about the commercial labour cost. Try youtube.
  25. #75
    Socal
    Hmm, I still think i can get it done for cheaper. But thanks guys. I dont have a press so doing it myself is out of the question.
