You can see how big the exhaust system is. That 3" cannon goes all the way to the B38 extractors! Big brakes next year. Just hoping to get it dyno'd this year.
1977 633 CSi RHD Euro. S38B38 3.9L M5 Transplant. 5 Speed Getrag Dogleg. 3.73 LSD. 417hp, 369lb/ft
1971 3.0CS E3 2dr Alpina Special Coupe Racer, 347hp, 295lb/ft
Car continues its slow final fit-out. Short shift kit to get through gears quicker now that we will spin to 8000rpm.
Zender wheels. Don't know the exact name but something like Zender Turbines? Or Zender Turbo (insert number 1 or 2 after Turbo).
See this link. https://www.mye28.com/viewtopic.php?t=60363
Steering wheel spline change from fine to coarse now done. Steering wheel now going back on. Cost me two bottles of good Aussie red wine.
Steering wheel on;
Lathe old spine out of the steering wheel assembly. Place and thread holes for receiving bolts from boss kit.
Prepare boss kit.
Check fit.
Bolt in place after testing fit to coarse spline in steering column.
Beautttiiiffffuuuullll.
New carpet can be seen too! Not well, but it's in!!
Out with the old, in with the new.
Steering wheel in and short-shifter in. Carpet done. Left side Recaro going in.
Engine all back together. Rocker cover on.
Rubber trim going onto the front bumper. Finally!
Left Side Recaro in. Short-Shifter is fantastic. Carpet came up well.
Two short Vids.
Not much as been done over Christmas. I'm recommissioning the batwing after brakes issues. I had the boosters rebuilt and one came back holding zero vacuum. Now both are working well the car is missing under load at higher rpm and pulling to the left. So the missing could be leads, dizzy, plugs or the carbies. The brake issue must be a right calliper.
The Fordcedes shown below has pushed the 633 back but when your mate needs to feed the family other projects drop in. I'll get the race car tuned on the dyno with a carbie specialis while the Fordcedes is finished. Then back to the 6'er followed by the batwing brakes as she should be easiest.
Slowly getting there.
Dyno booked for late April to May.
Front bumper rubbers now on. A mix of new, second hand and crash repaired rubbers. It will do me but I'll keep an eye out for all new rubber sections.
Recaro's still need to go in. Transition base plates need shaping.
You need some Euro stripes for that beastie! I am still making them
81 Euro undergoing total nut and bolt restoration
pictures at: flickr.com/photos/bertsphotos
I bought a set off you. They may be in poor nick now so I might just get back to you.
Car is now actually ready for dyno. Seats in. Other minor issues addressed. Still needs new front brakes, new dash in and a few other things but I'll drive it for a while first post dyno before new major works.
Bar to items requiring repairing that were missed under the previous collision repair, the car is ready.
The two items are;
1. Bent front 'K'-frame (subframe). right wheelbase 30mm shorter than the left.
2. steering box and bracket has broken free from the 'K'-frame.
So it looks like a new 'K'-frame. Hopefully struts and shocks are not bent.
Seats are in. This is a lovely cockpit to sit in. Period correct Recaros from a 1977 911RS.
New carpet too. I'll get the small cut near the handbrake fixed when it goes to an upholsterer in a year or two.
The short-shift is brilliant.
Snaps into gear with about 20mm movement. Will be great to race.
Engine rev. Note the steering box has separated from the 'K'-frame later in the video.
A few more photos of this gorgeous girl.
hehehehehe,
It's funny because its true..... almost.
Dyno April, Shannons assessor calling today or tomorrow re the front 'K'-frame issue.
Then on the road.
Need a drive. How goes your 6'er?
Insurer picked up the car yesterday to fix the front 'K'-Frame issue. And the right hand door not closing properly.
Rather wet here. Today we passed out average yearly rainfall in Sydney, and it's just April 7!
Going to be a wet wet year!
Painful, to say this has been painful is an understatement.
Does it surprise anybody that the insurer is trying to get out of the repair? That was a rhetorical question!
I'll fire this off in bullets;
1. Car goes back, new repairer says power steering bracket on front subframe cracked.
2. Insurer tries to find out if car was wheel aligned by 1st repairer. It was not, despite hitting a double high gutter head on! Negligence by 1st repairer. Negligence by assessor.
3. Insurer claims previous repair to power steering bracket as weld present, will not repair now. Unethical. I state welding is an acceptable repair methodology and car has been on racetrack with no issues.
4. Insurer then claims 1st repairer said found crack in power steering bracket and claimed it was old damage. I call 1st repairer who said "we did not say that!" Insurer lies.
5. Bought a second hand front subframe.
6. Got a specialist inspecting the weld.
7. I'm a structural engineer. The failed power steering bracket has hammered out! Must have been the accident! That is clearly impact damage.
8. Photos tell you where we are at.
New front subframe to go it. Will have cleaned and painted 1st.
Bracket should look like this.
Existing bracket looks like this. And was missed during the original repair. Car is undriveable. How the hell did the original repairer approve this as fixed!
I seem to always end up here. In this case incompetence by insurer and 1st repairer.
400+ hp just hanging around awaiting dyno.
My mechanic put the second hand front subframe in and bolted it up. What a surprise, both wheelbases are exactly the same. My front subframe was obviously bent in the accident, by at lease 30mm.
It needed to be replaced irrespective of any repair to the power steering bracket as this bracket adds no strength to the frame. Frame bent when it hit the kerb.
Hopefully I do not need to take my insurer to court but happy to do so if they do not pay for a proper repair.
Repairs continue. Refurbished front subframe nearly finished.
Awaiting refurbished subframe.
So getting there, slowly.
A few shots from underneath, showing the E34 M5 3.8 LSD and the exhaust, large enough to crawl through! (not really)
And the race car, in for a service pre end of year racing.
A few more items being reconditioned as she goes back together.
Car is now ready for the dyno.
Front subframe new. All linkages and bushes new.
Will get Megasquirt expert across in the next week to do an in-shop tune check and mayhaps a road check, then book dyno.
Post dyno, new front calipers and disks.
https://www.youtube.com/shorts/O1clMwC20qs
Started the Tune Check Friday night.
Running very rich. Plugs fouled but expected as sitting for 2 years while being repaired then having the dodgy insurance repair, repaired.
Running at 10:1 AFR so way to rich and we were struggling to pull the fuel down.
Could be the two PLX O2 sensors need calibration or could be the plugs.
We'll spend a week or two mapping then spend a Saturday morning working it out.
Once worked out and driveable on the street, we'll book the dyno in.
Vid has the Batwing Racer with the Group A engine in the back half.
