Page 58 of 63 FirstFirst ... 83348495051525354555657585960616263 LastLast
Results 1,426 to 1,450 of 1557
Thread: DYNAVIN N6 E39 Multimedia GPS System, New for mid-2014
  1. #1426
    Jan 2014
    Maryland
    2003 540 M Sport
  2. #1427
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by ViolinARC View Post
    "This video contains content from SME, who has blocked it in your country on copyright grounds."
    Quote Originally Posted by dohc97 View Post
    I just saw it myself:-(
    Probably because of music you were playing.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
  3. #1428
    Oct 2016
    Kongsvinger Norway
    1999 BMW 528IA
    My N6 started acting like an idiot today, called last contact 35 times in 10 minutes, radio stuttered every second, I have to press each physical button fast multiple times, and I can only listen to the local radio, if I switch channel it switches back in a second.
    Haven't done anything to it other than updating the maps a month ago
  4. #1429
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by Perern View Post
    Check the physical connections to make sure nothing has come loose.
    Nate J.
  5. #1430
    Fresno,ca
    E46 E92 E70
    I just saw that the navigation software that I have on my newly installed unit is 9.6.13.268494. Below that it says Nov 13, 2012. Does it mean that the map version I have is from Nov 13, 2012? I looked at Naviextras.com and it says the latest version is 2017 Q1. Do I have to pay $79 to get the latest map or are we able to download it for free?
    Update: I was able to use the Navi tool to run the update. When I tested the navigation, it still shows the same info as above. Also, I tried playing a movie file. It says that I can not do this when I am driving. I was not driving. I was parked in my garage when I tried it.
    That is the date that iGO Primo came out, not the date of the map data. Your map data is current.
  6. #1431
    Apr 2017
    New York
    2001 540i 6MT
    This might have been said here, but I couldnt find it in the 30 pages I read. 2001 E39 540i w/ DSP will replacing the OEM with this unit fix the "cutting out" problem, or is that an amp on its way out.
  7. #1432
    Fresno,ca
    E46 E92 E70
    depends on what is wrong with the stock system....there are quite a few points of failure in the stock system but generally the audio cutting out entirely is not the amp, if you are loosing specific channels intermittently or entirely, then its likely the amp.
  8. #1433
    Apr 2017
    New York
    2001 540i 6MT
    Quote Originally Posted by jeffb325 View Post
    Ok well, my screen doesnt show picture, completely black. So i just listen to cd's using the player in the trunk. No matter if engine is on or car in acc mode, all speakers just cut off to no sound and stays this way until i turn off the stock unit and turn it back on. I plan on purchasing your unit soon anyways, hope it fixes my problem :]
  9. #1434
    Fresno,ca
    E46 E92 E70
    Yeah, from your description it does not sound like your amp is the cause of the issue, going to the dynavin should get you back in business.
  10. #1435
    Apr 2017
    New York
    2001 540i 6MT
    Thanks Jeff, you will most likely be hearing from me again in the next couple months after purchase, during installation! xD
  11. #1436
    Aug 2017
    Greenville
    M3 E46
    @ jeffb325 how does one know which bracket to purchase without taking the unit out? i do not have nav- 2003 M3
  12. #1437
    Fresno,ca
    E46 E92 E70
    Its in the FAQ on our website. Also explained on the product pages for the brackets.
  13. #1438
    Mar 2015
    Folsom, CA
    2001 530i/a Sport
    I have everything installed. I noticed two things:
    1. Occasionally, when I start the car it will not play any audio. If I stop, turn the car off, turn it back on, the audio works.
    2. I am using Dynos 1.2.1 (I think). I see discussion of a version 1.3, but I can't find the download on the Dynavin website. Is there a newer OS available?
    2001 530i Sport
    Alpenweiss III / Black
    I do so I can understand.
  14. #1439
    Fresno,ca
    E46 E92 E70
    Email your dealer for the firmware update, if thats me, email me.
  15. #1440
    Mar 2015
    Folsom, CA
    2001 530i/a Sport
    That would be you. I'll email you in a bit.
    -Felix
    2001 530i Sport
  16. #1441
    Mar 2015
    Folsom, CA
    2001 530i/a Sport
    Update installed. Thanks!
    2001 530i Sport
  17. #1442
    Fresno,ca
    E46 E92 E70
  18. #1443
    Los Angeles, CA
    Formerly 03' 540i
    Quote Originally Posted by FelixEsq View Post
    I have everything installed. I noticed two things: 1. Occasionally, when I start the car it will not play any audio. If I stop, turn the car off, turn it back on, the audio works.
    Just to follow up, do you still experience this issue after the update?
    I have yet to update my SW since i heard a few mixed things with the most recent. And i have the no sound issue from time to time.
    2003 BMW 540i [Sterling Gray / Gray]
    [Msport] [Mods from A-Z] [Two-Tone Interior]
    Stuff For Sale :
    All types of E39 OEM Used HVAC Buttons
    Other E39 Parts, see my ebay! [Click]
  19. #1444
    Fresno,ca
    E46 E92 E70
    Its not something that an update would do anything for.....Its my belief that this DSP "no sound" thing has to do with the timing of the "handshake" between the DSP amp turning on and the ibus box. I have heard differing reports from customers however as to what causes it, pausing while turning the key, NOT pausing, turning on from the acc position, NOT turning on from the acc position, etc.... I have not yet had anyone give me a definitive answer that is repeatable but we HAVE found that the simple act of paying attention to how you turn the key will often alter the timing enough that the issue goes away! If anyone that has experienced this can isolate the timing and actually create it at will, let me know!
  20. #1445
    San Diego, CA
    98 M3, 03 540it M-Sport
    Jeff, I currently have an older dynavin (like one from 2010). I doesn't even recognize my new pixel, and the screen won't show anything from a dvd. How compatible are the current units with the new iphones and google phones? And what about HD Radio? Are you aware of any major updates on the horizon that are worth waiting for?
    '98 M3 5spd - '03 540it 6spd M-Sport
  21. #1446
    Fairfax, VA
    2001 BMW 540iA TiAg
    Wanted to pop in here because of a new issue I'm having.
    I got a new phone yesterday (Galaxy S8+ running Android 7.0), and now it refuses to pair with my Dynavin running 1.2.1. Reset both, and it gives the "make sure Dynavin is in pairing mode and discoverable." I see it in my Bluetooth menu, but it won't connect. Anyone else having issues with this? My previous phone had no issues, was a Galaxy S6 running Android 7.0 as well). What would the latest OS for the Dynavin be, and how can I go about remedying this issue?
    "Serena" Current mileage: 150,157. 15 years celebrated 09/20/2015.
  22. #1447
    Jan 2014
    Maryland
    2003 540 M Sport
    I've had my Dynavin now for a out 2 months. Now, I noticed that when I am playing an FM station and I go into reverse, the radio cuts off. It comes back on as soon as I shift out of reverse. Also, my navigation now does not give me the audio turn by turn direction. It used to do that.
  23. #1448
    Oct 2017
    Los Angeles
    E39
    Quote Originally Posted by QtheGenius View Post
    Looks like I got burned by a cheap chinese unit which quit working after two years and Would be interested to know the answer to these questions.
    Also noticed MFG is out of stock on the unit, are they still in production? If not, are there plans to release a new model?
  24. #1449
    Fresno,ca
    E46 E92 E70
    If you have a reverse camera or PDC and you put the car in reverse the volume will be lowered. Its supposed to do that. If you dont have a camera or PDC turn the reverse function off in the system settings menu.
    For the nav, the volume is turned down. There are a couple places where this could happen: Go to the volume settings within the nav program, check the settings. If everything is ok there, go to the setting where you choose the "person" who's voice you hear, select one (forcing it to talk) and simultaneously turn the volume button up.
    The dynavin has a discrete volume setting for the nav so that when its talking and you turn the volume knob you are turning up or down ONLY the nav volume....so its likely you inadvertently turned the volume down on the nav, and you can only turn it back up while the nav is talking.
    Quote Originally Posted by Sigil750il View Post
    Thats a fairly old firmware you have on there, 1.3.0 is the current version and has some changes to bluetooth. A quick google of "samsung galaxie s8+ bluetooth wont connect" brings up A LOT of similar S8 problems but mostly from 5 months ago....would hope they worked them out by now! Generally speaking though if you are having bluetooth pairing issues when you get a new phone, make sure you delete the old phones from the dynavin's bluetooth menu, reset and reboot. Delete from the phone and reboot as well. Then with a completely clean slate try again.
  25. #1450
    Fairfax, VA
    2001 BMW 540iA TiAg
    Thanks for the response Jeff. I didn't realize my firmware was so out of date haha, I guess that's the price of having a device not connected to the Internet. If it's not too much trouble, would you be able to link the latest firmware to me?
    Got it to work! Turns out the Bluetooth settings are hidden in the Phone menu, paired my phone and it plays with no issues.
