Results 1 to 25 of 28
Thread: E36 M3 Max wheel/tire width with stock fenders
    USA
    997 GT3, E90 M3, E46 ZHP
    What is the widest wheel/tire combo that will fit on an E36 M3 coupe without cutting the fender and using an over fender. I've rolled my fenders pretty aggressively to the point where I've flared them out a bit and changed the shape slightly. Can I stuff a 255/40/17 or a 275 tire in there or do I need to go with the Hardmotorsport over fender to run a 275?
    What offset wheel is ideal to run the most tire? My car is lowered a good amount on some Moton motorsport coilovers and I have -3.3 camber in the front -2.5 in the rear.
    997 GT3, F80 M3 6MT, E90 M3 Sedan DCT (for sale), 03 330i ZHP, 2016 WRX STI Limited
    Dec 2004
    Sherbrooke, QC, Canada
    VW Touareg TDi 2010
    I stuffed 255's just by rolling the fenders on a 17x9 rim.
    Dunno about 275's...
    HaLo
    - Volkswagen Touareg TDi '10 (daily)
    - BMW M3 Coupe '98 (race car)
    Minneapolis
    1995 M3 Coupe
    Are you going to be running sticky tires on a track? I have 255 Toyo 888 on 17x9 on my car but had to beat the crap out of the inner fender, roll the lip...because the sticky tires and low spring rates (400/500) were causing the car to roll over so much. 245 fits without an issue.
    Dec 2004
    Portland, OR
    1992 325i
    Kosie K1 40mm offset with a 245 Kumho V710 fit with a bit of room. My car is not an M3 however. 255 is the widest I would think would fit.
    Sep 2008
    NS, Canada
    E36 M3
    255/40/17s on 17x9 fit no problem with a roll with your camber settings. My setup is ~-3.5 front and -2 rear with 12.5" ride height both ends. I tested the rear under full compression with no spring and had room left to the fender lip on a set of yokohama A032r (ancient rcomp) mounted on dforce LTWs.
    Anything bigger and you will have to start cutting or making compromises. There is a really good post by terry fair (vorshlag) about what they went through on an e36 M3 to fit various different sizes up to 315, I just can't seem to find it in search. I came across it when looking for info or rolling e36 rear fenders.
    Jul 2010
    562/ 949 CA
    M3 Saloon
    265's fit on 18x9.5 with a roll. A lot of the track guys run them..
    If the mind can conceive it, & you believe it, you will achieve it. - Napolean Hill
    1998 Alpine White & 1998 Arctic Silver ///m3/4/5
    JC Intake - ASC Delete - Dinan TB - Flow Matched 21.5# Injectors - JC Tune - SS Euro Reps (modified to retain SAP) - z3m ssk - Eisenmann Race 76mm - Yokohama Advan S2 - Squared LTW's - FK Silverline +X - Rogue FCAB/ RTAB/ RSM/ TM - X-Brace - CDV Delete -Racing Dynamics F&R Strut Braces - NGK BKR6E- German Castrol 0w-40
    Dec 2005
    Seattle
    Euro Group N M3, 2004 M3
    A 255/40 or a 245/40, depends on the tire manufacture. A lot of DOT R 245/40-17 tires are actually wider than 255...
    USA
    Thanks using a 18x9 now with 245/40/18, may try a 255 or 265 Hoosier. What offset should the wheels be for maximum tire clearance? I currently have a pretty thick spacer and I think the wheel is 45 offset.
    Do you guys completely remove the fender liners? If so how do you keep the brake ducts and undertrays in since they all tie together?
    Virginia
    E30M, E36M, E61TT
    scott blair (joenationwide on the forum) was able to squeeze 275s under his stock pulled fenders (not crazy ugly pulled either) but I think he had to raise his car height. I personally can't imagine fitting anything larger than a 255 under my fenders without it looking horribly pulled.
    May 2005
    san francisco
    E36 M3 , E39 540is
    Quote Originally Posted by ALong View Post
    +1
    "Racing is life, anything that happens before or after is just waiting" -Steve McQueen
    "Sex is safe & racing is dangerous" -Hans-Joachim Stuck
    USA
    My 245's don't seem to rub except on the fender liners at full lock.
    Do you 255 guys remove the fender liners or just let them rub on the tire at lock?
    Sep 2008
    NS, Canada
    E36 M3
    Just let it rub.
    West Chester, PA
    98 M3
    People have recently been running the 265 setup on 18x9.5s and 18x10s a lot recently, but there was someone on here with 275s on 17x10 SSRs a few years back I believe.
    USA
    When my 245 Rivals are dead I'm going to try 265 on 18X9.5. No rubbing issues at autocross this weekend. The fenders liners stayed intact.
    Jun 2016
    Miami
    1995 BMW M3
    What do you guys think about Toyo Proxes RR 255/40 on 17x8.5" Kosei K1's for an e36 M3 strictly track car? I've been trying to find some well priced 17x9 but it's a hard to find used wheels in that size. I find plenty of 17x8.5" wheels but i'm hesitant to run 255 tires on them. Is there a big difference between running 255's on 8.5" vs 9" rims?
    Jul 2001
    F150, Suburban, M3
    Quote Originally Posted by BeeHemDoubleU View Post
    255/40 on 17x8.5” Kosei is a proven combo. Probably need a little fender roll, easy fitment.
    Apexraceparts has perfect 17x9 for the e36, reasonably priced.
    "It's not the people who vote that count, it's the people who count the votes."
    -DNC
    Nov 2007
    Orlando
    99 M3, 11 GT3RS
    245 Hoosiers fit with a 17" wheel. Those tires are 10.3" wide according to Hoosier. So closer to 265 street tire.
    I can't see anything much wider than that fitting under stock fenders after a solid roll/ little pull...
    99 M3 STU/ GTS3 Project
    Fair's Avatar
    Fair is offline Senior Member Supporting Vendor
    Oct 2003
    Dallas, Texas
    E36 M3, E36 LS1, E30 318
    Quote Originally Posted by NotoriousJJE View Post
    Yea the 245/40/17 Hoosier R7/A7 is fairly wide at 10.3" section width, 9.7" tread width. That is going to be pushing the limits of an E36 fender...
    We picked this size because it is the widest "245" that Hoosier makes (compared to their 16" and 18" 245mm tire, the 17" version is a 1/2" wider).
    We tend to look at the manufacturer's recommended wheel width range for a given tire and go to the widest wheel shown, or even a little bit more. Hoosier states that an 8-9.5" wide wheel is optimal for this 245/40/17 R7. But another 1/2" of width is even better! But fitting that on an E46 is gonna take some HAMMER TIME.
    The E46 has a bit more fender room than the E36 and we still had to flatten the front and rear lips to clear this tire at full compression, when stretched out onto the 10" wide wheel.
    Eventually we flared this E46 Coupe (HARD Motorsport flares) just to keep the rubbing under control...
    Terry Fair @ Vorshlag Motorsports
    Nov 2007
    Orlando
    99 M3, 11 GT3RS
    Quote Originally Posted by Fair View Post
    Confirmed it fits on an E36. I have run that setup for the better part of a year now. Takes a roll and some massaging but it fits. THis is on an ET45 wheel with a 15mm spacer because it is close to the strut. The problem is the tire deflection on my skinny ass wheels I have to run.
    Aug 2002
    Denver, CO
    '98 M3
    I fit the 245 R7 on Kosei K1 17x8.5 ET41 wheels. 15mm spacer up front to clear the struts, rolled rear fenders. I do get a little rubbing on the inner front fender on the rear with them...
    '03 911 Turbo 6MT fun car
    '18 Toyota Land Cruiser Daily driver/Ski Machine/Off Roader
    '15 Cayenne Diesel Wife's DD
    '17 KTM 690 "Adv" 2 wheeled Adventurer
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    I'm on 255/40/17 Federal RS-Rs that run 265
    17x9 +42 APEX ARC-8s
    12mm spacer up front
    Fenders are rolled and the liners have been cut.
    I was getting some rubbing on the muffler and the front frame rails but it's nothing I'm worried about. Doesn't impact the performance of the car at all.
    Next tires will be Hankook TDs which have stiffer sidewalls.
    Montreal, Quebec, Canada
    E46 330 ZHP, E36 328i
    I have a sedan and it has less room in the back then the coupe.
    I'm on coilovers at approximately 5'' ride height. 2.5 to 4 degrees of camber. 20mm spacers in front nothing in the back.
    Wheels are 17x9 with 42mm offset.
    BFG R1 245/40R17 tires.
    Good luck.
    Charlotte
    2012 GTI
    Bumping this up. The class I run allows fenders to have the OE lines exaggerated, but no material can be removed or added and the inner lips can't be unfolded and rolled outwards. The goal is to run 255 or the class limit 265 Yokohama A052's, ideally on 10's or 10.5's. I am aware that 255's will fit on a 9 or 9.5 (I have actually tried the 255 on a 9 and it sucked), but the A052 REALLY likes wider wheels and I'm looking to explore what is possible. There are posts saying people are running certain wheel setups that meet that criteria, but without offsets and/or specifics it doesn't really tell anyone more than that it might be doable and I'm not looking to reinvent the wheel (pun intended).
    So, does anyone have specifics? The car is track only and already beat to hell so I don't really care how the fenders look, and it is on MCS 2WNR with adjustable rear control arms and camber plates so alignment has room for adjustment. TIA.
    97 M3 - SCCA TT Prepped
    17 F150 - Tow Pig
    05 S2000 - Sold
    88 325is - S52 powered - Sold
    95 M3 LTW Rep - Death by Altima
    ithaca Ny
    95m3/97m345/powerstroke
    I wish they made 265/35/17s. They would work well on the apex 9.5. Or if you could find a higher offset 10inch. The 17x10 et25 won’t work without flares. Best bet is for the 255’s with the 9.5.
    Consensus is that the ao52 is the fastest, but it is not a very stiff tire and feels vague. So that may have been why it sucked for you? Maybe by the time your season ramps up the new re71rs’s will be available.
    Charlotte
    2012 GTI
    Quote Originally Posted by Pat533i View Post
    Thanks Pat. The vague feeling with not enough wheel width to support it is exactly why they sucked. I went down to a 245 on a 9 and they had much better feel and were faster. The 255 on a 9.5 is likely where I'll end up, but I'd really like to make 10's work if possible.
    17 F150 - Tow Pig
    05 S2000 - Sold
