Anyone from here buy these? I am wondering if they were e34/2 made to fit on an e23. They had to have dripped new holes for the top mount, right?
http://www.r3vlimited.com/board/showthread.php?t=325800
Kent up in BC bought 'em for his 745i.
I make E23 parts.
10/1984 745i
11/1984 745i
11/1984 735i (10:1-265/6)
We need to get some more pics of them. I wonder who owned the car initially.
Zip him a PM, I speak with him on a regular basis.
Who knows, they came off a junkyard car...so it is anyone's guess.
I make E23 parts.
10/1984 745i
11/1984 745i
Post up any info you find out!
I honestly want to know if he gets them to fit without modification and if there are any marking to indicate which model they are from Ksport. Also, if it looks like a custom job on the knuckle.
Hey, yeah i bought them. I should have them in late July and i'll post up some pictures then.
1984 BMW 745i I always know when im boosting because i can feel the seat springs in my back
There must be info online somewhere about these. I doubt the person that did them was completely offline but if they no longer have the car they might not check forums. Wonder what else might have been on the car.
95 BMW M3 Alpine-
<GO...JIC Cross Coilovers- UUC RCAB, AKG FCAB, Rogue Engineering TM bushings- AA Gen3 Exhaust- Dinan F&R Strut Bars- Dinan F&R Sway Bars- X-Brace- Mishimoto Rad- BBS RK 17x8"- TRM Chip- Dinan BBTB- DIY CAI- JP Performance Headers- 21.5 injectors- JB Racing Flywheel- Bimmerworld TB boot- 540i MAF><SHOW...OE euro clear exterior lights- Depo w/ HID- Hurricane Alcantara interior- Stereo (Kenwood,Sony,MB Quart,Rockford Fosgate,JL Audio)- Black kidneys- Euro 3 Spoke- ZHP Knob- AutoDim Mirror>
Also, one good thing about Ksport is that you can buy shorter or taller springs to change the stiffness or if you need to clear wheels. I had Ksport coilovers on my e36 M3 and it took a lot of springs to find the ones I liked. Therefore I have some extra springs if you need to change yours out.. Let me know.
Here is what I have (2 of each):
205mm in length 8.7kg / 487lbs
180mm in length 11.5mm wire diameter, ID: 63 OD: 86.5, 8kg per mm / 447lbs per inch
160mm in length 11mm wire diameter, ID: 63 OD: 86.5, 9kg per mm / 503lbs per inch
Update,
Received the coils and can't find any information on them, no marking or anything. I have no idea how the front was mounted as the holes are no where near close. The guy who pulled them said the PO widened some holes? no idea, the lower struts for the front are correct. I'll need to figure out how to mount the front if im going to re-use the top but i think d-unit had issues running original top mount.
Holy thread revival (lol). I've acquired the KSport coilovers (previously sourced from a junkyard e23) from Kent (thanks Kent) and will attempt to move this saga forward, albeit at a snail's pace unfortunately. The Seattle area weather at this time isn't much help for us driveway mechanics. Any help from the suspension/coilover gurus out there is much appreciated. Kent has a lot of good pics but if someone wants some more (for example a close up of something) feel free to reach out to me.
Id like to see some overall pics, especially the top mount, and how the threaded collars are on the front strut housings.
I vaguely remember those, but thanks to photobucket no pics to refresh the memory. From what I recall they were just a custom coilover set up someone made. I do not know of any production E23 coilover, some people have made some but it's basically a front insert welded in.
95 BMW M3 Alpine-
I'm just curious how they were put together. Coilovers are simple, but the execution can be easily botched.
I remember D Unit having issues with the top mount/bearing.
--Jay3->Sic gorgiamus allos subjectatos nunc
84 €735i manual, 88 528e/i
Motronic 1 and 1.3 wiring
Transmission & Diff gearing sheet
Does KMac make plates for the E23? Hole spacing is different from E24/28/30 which is most commong.
I ran them on an e28 a while ago, part of the Dinan suspension package- Gave good adjustability, and from the limited knowledge I had on them they used a good quality bearing (important), the real difference aside from the bolt spacing is the strut rod size on the e23 and the associated bearing ID, think the rest is the same when it comes to fabrication.
Some people hate on the Kmac plates but that's pretty much like anything else and when sourcing parts is limited, sometimes you gotta take what you can get-
I had heard that IE could make E23 plates but I called them recently and asked about it and got a no. KMAC has been the only option forever for front camber plates, and they have had different versions over the years but you would need the ones with both camber/caster adjustments. They do work, but are not necessary for lowered suspension. I have lots of suspension stuff for various bmw and lots of GC stuff. I would think the easiest route would be to shorten and modify front housings to accept inserts and coil collars. This is commonly done for E30 and E36, and I'll have to measure but don't recall if the e23 tube is that much bigger. Normally I would say just get a set of good springs and shocks/struts but due to lack of e23 springs I think this is a good idea for us to follow up on.
95 BMW M3 Alpine-
I'm 97% certain that E23 front strut tubes are the same diameter as E28/32/34.
BUT, E23 are the shortest of the bunch already.
I do agree though that modifying the strut tubes to accept a more universal and cheaper insert for a coilover setup is the long term way to go.
