Results 1 to 25 of 29
Thread: Someone found some e23 coilovers on a car in the yard
    ATL
    e23 e36 e46
    Anyone from here buy these? I am wondering if they were e34/2 made to fit on an e23. They had to have dripped new holes for the top mount, right?
    http://www.r3vlimited.com/board/showthread.php?t=325800
    Jun 2010
    TX
    1983/84/85 745i
    Kent up in BC bought 'em for his 745i.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    ATL
    e23 e36 e46
    We need to get some more pics of them. I wonder who owned the car initially.
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Zip him a PM, I speak with him on a regular basis.
    Who knows, they came off a junkyard car...so it is anyone's guess.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    May 2014
    Mobile, AL
    1993 325i
    Post up any info you find out!
    ATL
    e23 e36 e46
    I honestly want to know if he gets them to fit without modification and if there are any marking to indicate which model they are from Ksport. Also, if it looks like a custom job on the knuckle.
    Apr 2006
    Pemberton, B.C., Canada
    1984 BMW 745i
    Hey, yeah i bought them. I should have them in late July and i'll post up some pictures then.
    1984 BMW 745i I always know when im boosting because i can feel the seat springs in my back
    ATL
    e23 e36 e46
    Thanks!
    SD, Cali, USA
    1995 M3, 1985 745i , S13 240sx sr20det
    There must be info online somewhere about these. I doubt the person that did them was completely offline but if they no longer have the car they might not check forums. Wonder what else might have been on the car.
    95 BMW M3 Alpine-
    <GO...JIC Cross Coilovers- UUC RCAB, AKG FCAB, Rogue Engineering TM bushings- AA Gen3 Exhaust- Dinan F&R Strut Bars- Dinan F&R Sway Bars- X-Brace- Mishimoto Rad- BBS RK 17x8"- TRM Chip- Dinan BBTB- DIY CAI- JP Performance Headers- 21.5 injectors- JB Racing Flywheel- Bimmerworld TB boot- 540i MAF><SHOW...OE euro clear exterior lights- Depo w/ HID- Hurricane Alcantara interior- Stereo (Kenwood,Sony,MB Quart,Rockford Fosgate,JL Audio)- Black kidneys- Euro 3 Spoke- ZHP Knob- AutoDim Mirror>
    ATL
    e23 e36 e46
    Quote Originally Posted by 1981320i View Post
    Also, one good thing about Ksport is that you can buy shorter or taller springs to change the stiffness or if you need to clear wheels. I had Ksport coilovers on my e36 M3 and it took a lot of springs to find the ones I liked. Therefore I have some extra springs if you need to change yours out.. Let me know.
    Here is what I have (2 of each):
    205mm in length 8.7kg / 487lbs
    180mm in length 11.5mm wire diameter, ID: 63 OD: 86.5, 8kg per mm / 447lbs per inch
    160mm in length 11mm wire diameter, ID: 63 OD: 86.5, 9kg per mm / 503lbs per inch
    Apr 2006
    1984 BMW 745i
    Update,
    Received the coils and can't find any information on them, no marking or anything. I have no idea how the front was mounted as the holes are no where near close. The guy who pulled them said the PO widened some holes? no idea, the lower struts for the front are correct. I'll need to figure out how to mount the front if im going to re-use the top but i think d-unit had issues running original top mount.
    Dec 2002
    Bay Area, CA
    e23, e28, e36
    Sounds like the car it was taken from was either not an e23 or an e23 that drilled 3 new holes on the strut tower. If it was me, I'd be pretty pissed at the seller.
    Dec 2009
    Seattle, Washington
    E23 E24 euros E34 E38
    Holy thread revival (lol). I've acquired the KSport coilovers (previously sourced from a junkyard e23) from Kent (thanks Kent) and will attempt to move this saga forward, albeit at a snail's pace unfortunately. The Seattle area weather at this time isn't much help for us driveway mechanics. Any help from the suspension/coilover gurus out there is much appreciated. Kent has a lot of good pics but if someone wants some more (for example a close up of something) feel free to reach out to me.
    Update,
    Mar 2006
    Sacramento, CA
    87 535i/84 €735i/8
    Id like to see some overall pics, especially the top mount, and how the threaded collars are on the front strut housings.
    Dec 2009
    Seattle, Washington
    Quote Originally Posted by Jay535is View Post
    Shoot me a PM where I can text some pics to you.
    Sent from my HTC6545LVW using Tapatalk
    SD, Cali, USA
    I vaguely remember those, but thanks to photobucket no pics to refresh the memory. From what I recall they were just a custom coilover set up someone made. I do not know of any production E23 coilover, some people have made some but it's basically a front insert welded in.
    95 BMW M3 Alpine-
    Mar 2006
    Sacramento, CA
    87 535i/84 €735i/8
    I'm just curious how they were put together. Coilovers are simple, but the execution can be easily botched.
    I remember D Unit having issues with the top mount/bearing.
    --Jay3->Sic gorgiamus allos subjectatos nunc
    84 €735i manual, 88 528e/i
    Motronic 1 and 1.3 wiring
    Transmission & Diff gearing sheet
    Mar 2013
    USA
    E21/early e23/e34
    He ended up having Ireland Engineering make a set of camber plates- I spoke to Jeff, he'd still do up a set but needs a strut bushing for a template, the ID bearing size is different on the e23.
    Dec 2009
    Seattle, Washington
    Quote Originally Posted by kojo96 View Post
    Would KMac camber plates work?
    Mar 2006
    Sacramento, CA
    87 535i/84 €735i/8
    Does KMac make plates for the E23? Hole spacing is different from E24/28/30 which is most commong.
    Dec 2009
    Seattle, Washington
    I found a pair on eBay. Also, KMac's website shows e23 camber plate setups for track and street. I was wondering if anyone on here has had experience with the KMAC camber plates?
    Mar 2013
    USA
    E21/early e23/e34
    I ran them on an e28 a while ago, part of the Dinan suspension package- Gave good adjustability, and from the limited knowledge I had on them they used a good quality bearing (important), the real difference aside from the bolt spacing is the strut rod size on the e23 and the associated bearing ID, think the rest is the same when it comes to fabrication.
    Some people hate on the Kmac plates but that's pretty much like anything else and when sourcing parts is limited, sometimes you gotta take what you can get-
    Dec 2009
    Seattle, Washington
    Kojo, thanks for the info. I'll probably take a run at the ones on eBay.
    SD, Cali, USA
    I had heard that IE could make E23 plates but I called them recently and asked about it and got a no. KMAC has been the only option forever for front camber plates, and they have had different versions over the years but you would need the ones with both camber/caster adjustments. They do work, but are not necessary for lowered suspension. I have lots of suspension stuff for various bmw and lots of GC stuff. I would think the easiest route would be to shorten and modify front housings to accept inserts and coil collars. This is commonly done for E30 and E36, and I'll have to measure but don't recall if the e23 tube is that much bigger. Normally I would say just get a set of good springs and shocks/struts but due to lack of e23 springs I think this is a good idea for us to follow up on.
    95 BMW M3 Alpine-
    Mar 2006
    Sacramento, CA
    87 535i/84 €735i/8
    I'm 97% certain that E23 front strut tubes are the same diameter as E28/32/34.
    BUT, E23 are the shortest of the bunch already.
    I do agree though that modifying the strut tubes to accept a more universal and cheaper insert for a coilover setup is the long term way to go.
