goodmorning,
i own an e46 3.16ci '00 which doesn't have the front fog lights installed from the first place.
so i bought a used pair of them like this post http://www.e46fanatics.com/howto/how...hp?howto_id=15
and i want to connect them but i don't know how.
it will be kind of you if you could give me some info and pics about the installation.
i've already intalled a new main light switch in the cabin which includes the button for the fog lights.
i also don't know if the car has already the wiring for them or i should make new wiring too.
the long lateral piece and the 4 smaller ones i know how to remove them but i cannot procced any further.
thanks in advance,
It would've been easier to simply tap the fog lights to your low beams and have them turn on along with your headlights.
ECSTuning has a fog light wiring kit for cars that didn't come wired for fog lights. You'll also need to install a new fuse in the fuse box I believe if you want it to be factory-ish.
