It would be interesting to know the total running cost of the vehicle thus far. I'm enthused by all your DIY but also discouraged by the constant barrage of failures.
Sent from my iPhone using BF.com
1999 BMW 740il 137k
3800 for the car, and most expenses have been used parts to enhance it to my liking.
I think the lowering springs, and new rear tires were the biggest spend so far.
My E38 Project...................DSP Rear Deck Subwoofer box with Monsoon Speakers and Metal pulleyed window regulators NO longer for sale (click link to see how to make your own)....................................
Awesome job. Thanks for posting all of your work. You've already given me some ideals for mod projects this winter while the car is in it's annual winter hibernation.
Because back then they would take it so far that the car would be riding on the bump stops.
There is no ride difference. The Ride Is the same, comfy/sporty as stock.
I had a 99 740iL a few years back where I accidentally threw away the rear Eibach lowering springs. So Instead of ordering a new set I just cut the factory springs 1.5 turns.
Ride quality was the same as before I cut them. I used a cutoff wheel, not a welding torch either.
Polished headlight lens. Didnt think it would get any better than this.
Installed Front Passenger regulator with metal pulleys (requires slight modification to install process)
Fixed passenger seat trim.
http://www.bimmerforums.com/forum/sh...rim-fix-part-2
Installed Angel Eyes and polished Headlight lens, the most dramatic cosmetic change to the car so far since lowering.
Before:
AFTER:
Installed metal pulley regulator in front passenger door...
Requires different bolts than factory since pulley is deeper due to mounting method.
Polished some used headlight lens I got, still not as good as new, but better....
After this pic, I used a higher speed drill and got the lens to look much better.
Decided to install the Angel Eyes I got from Ebay...
Made grooves on top of the lens for the wire to pass through
Found out my projector lens were extremely dirty...
Placed the transformer inside the lens near the reflector.
Ran power wires through existing grommet.
I like very much...
AE and polished lens on the LEFT of photo, and existing lens on RIGHT of photo.
AE on with low beams
Original low beam with no AE
BEFORE:
Wired into DRL fuse. Added a wad of solder to twisted wire, wedged into wire connector and tie wrapped to wire
Wires coming into fuse box
Wires passed through existing grommet next to 20 pin connector under hood.
Love it....
9/13/15 172779 miles
Upgraded to Steptronic shifter by doing a Steptronic Shifter Retrofit.
http://www.bimmerforums.com/forum/sh...ttern-Mismatch
Very interesting thread.
Thank you.
i like your projects sir, thanks for sharing.
Added a drop of oil to my IHKA fan.
It used to be noisy when you shut the car off.
Wired a USB outlet and iPhone cable under the armrest.
When installing center console the material appeared too stretched so I had to tighten it back up for a clean fit.
I used wire.
Switched from new ATE pads to Rotex Gold pads due to excessive dust.
Feel the same as before.
This came in the mail.
Did a test fit.
Luv your thread and all the mods your doing. Awesome work.
95 740i 99 750i
What are the orange crumbs from?
Captains log 11/17/15 175081 miles. While idling in traffic, engine felt very rough like driving over gravel, shut off suddenly with ignition still on. After looking in trunk put car in park and it started and was able to drive to parking lot. Towed home.
If my car was any lower he said they would no tow and have to get AAA to send a specialty recovery company.
Tow driver was so happy to see me screwing the tow hook in!!!
No material in oil pan, *
checked 2 spark plugs, not fouled.
Just small amount of oil around one of them
Sound seems to be coming from water pump bearing, observed fan thrust axially slightly more than once.
Observed metal shavings behind water pump pulley.
Piece of pulley was missing....
Ordered pump, tstat, hoses and trans heat exchanger regulator.
What brands did you go with?
Any thoughts on why it caused the engine to shut off?
I picked up shavings with a magnet
Started car and shut down when noise started to get louder.
Saw a tiny bit more metal behind water pump pulley.
I think heavy metal to metal contact caused a sudden drag on engine that runs at low rpm caused it to shut off.
That's what I think until I start taking more parts off.
I put my ear on the handle of a long screwdriver and touched it to the water pump and that sounds like where the noise was originating from so that's where I am starting.
Hepu pump.
After I placed my order Last night, this morning I get an email from FCPEuro offering a loyalty discount, so I emailed them to complain and they offered to give me the $25 price reduction.
Noise from pump
Carefuly removed serpentine belt
Fan play
Engine running with no belt.
No rattling noise.
