Results 1 to 2 of 2
Thread: first turbo build and need insight!!
    Dec 2012
    knoxville tn
    1995 bmw turbo m3
    Hey everyone this is my first build and i could use some insight.
    I have a 93 325i with 150k miles.
    Im installing a gt35r turbo kit, boshce 44lb injectors, bav auto high performance coilpack, walbro 255fuel pump, aem fuel pressure reg., arp head studs, and considering getting a high boost cut ring head gasket. vvvv
    http://www.cesmotorsport.com/documents/94.html
    But i need to know if my stock ecu can adjust to all this or do i need a fi/c or piggy back? Also i have reading about lowering compression and dont know what would be best? Thanks for your time
    Nov 2013
    VA
    E36
    top or bottom mount manifold???...rk tunes or another vendor can provide the injectors, tune, and maf... ces provides good headgaskets so you're in the right direction on that part. However, best thing to do is to just look at the forced induction part of the forum and read. I'll be starting my build next year and that's the only way I learn. Most likely every question you ask has already been answered...
