Have any of you done the rear pads and rotors on your e39?
Is it any different from the front. Will the ebrake make any difference on the work needed to be done?
yeah, I have to do this this week too... good question!
this space reserved for pissing off liberals...
ronthebabboonslayer: "helmet guy's post is far from polluting"
I did rotors and pads about 5K miles ago, they are basically the same as the front except for the e-brake. The adjustment for the e-brake is behind the rotor once you remove it.
Make your adjustment so the rotor can just slide over the small pads for the e-brake w/o rubbing.
I also read on another forum about bedding brake pads after installing new pads and rotors. See below.
http://www.zeckhausen.com/bedding_in_brakes.htm
97 540i6
OE Front lip spoiler
OE M5 wheels
Bilstein Sports Shocks & Struts
H&R Sport Springs
M5 Rear sway bar
M5 kidney grilles
Hella Halogen Angel Eyes
