Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 96
Thread: Fatandres project thread BMW 850 "CSI"
  1. #26
    San Francisco, CA
    1972 3.0 CSi-1988 M6
    There are 2 plastic lock pins that snap into the upper radiator plastic side tanks, use a small flat screwdriver and pull out. These are the only fastening devices used. Also, these are 2 piece assemblies, so don't lose one or the other. Additionally, there are 2 black plastics side pieces (where the large cover clips onto...6 plastic clips) that are bolted to the body, carefully pry away the top flaps that sit ontop of radiator. Remove viscous fan/clutch assembly, shroud can be pulled away now from radiator.
    Bert
    91 850i-A
    1972 3.5 CSi (L-jet, Getrag 265 5 speed)
    1988 ///M6
    2021 X3 M40i
    The back to back BIG COUPE” duo
  2. #27
    Iceland
    BMW 850
    Thanks guys for that. It helped a lot as I changed the thermostat. bleeded the car and wasnt able to get the car to heat up like it should.
    I thought that the temp sensor is wrong. Unplugged all the sensors from the back and nothing. It didnt fall down or anything ( the temp needle)
    There must be something seriously wrong with the harness. I will be changing it out soon.
    After putting on the new computers I am getting CE light and stomp test shows 1224 on both sides. I am also suspecting the harness to be at fault.
    Here is the part number that is at the MAFS i think are from a CSI
    Am I comparing it not correctly?
    Here is what real oem shows me
    http://www.realoem.com/bmw/showparts...55&hg=13&fg=15
    Here is the maf I own
  3. #28
    Jun 2012
    Uk
    1994 850csi rhd
    You car will run cooler with my Maps.......the standard timing (more retarded) lets more heat run down the exhaust ports in turn heating the coolant quicker. Optimum timing keeps the heat expansion in the cylinder longer.
    Those MAFs are for a CSi. Odd you have 1224 on both sides.
  4. #29
    Iceland
    BMW 850
    Yeah. There is something wrong there. Could this be triggered by a faulty pin in the harness or something?
  5. #30
    Jun 2012
    Uk
    1994 850csi rhd
    Knowing your "Frankenstein" CSi I'd say very likely :-)
  6. #31
    Iceland
    BMW 850
    You are right. Took the car for a spin. It drives good I must say. First it hadno power and i got scared. Forgot to connect one maf for 1 km, fixef it did it and we are roling though the ce light is still on. Must be the harness.
    I am also starting to like the throwing stars
  7. #32
    Iceland
    BMW 850
    In a couple of days there will be an update
  8. #33
    Jun 2012
    Uk
    1994 850csi rhd
    V8 installed ? ;-)
  9. #34
    Iceland
    BMW 850
    Never. We dont need no monkey business .
    Just some plane old v12
  10. #35
    Iceland
    BMW 850
    Got the car from the mechanic
    I had the wishbones regenerated and had some poly ordered. We will see how that will hold up. Its a test for now.
    Also had the started regenerated and now it starts like a champ. Finally!!!
    Whats the best way to change out the wiper mechanism?
  11. #36
    Nov 2005
    Langley BC Canada
    91 850 Panzer
    Really hope that your urethane uca bushings last longer than the ones from Phoenix I installed into 4 local cars did. Think the best ones lasted a month before the death wobble started again. Center of the urethane "ovalized". I would never install them again... fwiw!
    91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
  12. #37
    Iceland
    BMW 850
    Quote Originally Posted by Wuffer View Post
    The upper ones are from Pheonix as I bought them years ago. If they fail I will replace them with yellow ones.
    Car is stiff, but rides good. I like the stiff and raw feel
  13. #38
    Iceland
    BMW 850
    So what is the best way to change out the wiper mechanism?
    One from today
  14. #39
    Nov 2009
    WI
    01M5,72TA,06LBz,850,540m
    Just a thought here...... if the center ovalized. how abbout making a thicker center sleeve as to distrubute more of the load on the urethane. we did this on my brothers mustang awhole back and it has lasted over 40k miles now with no issues. Just a thought. i am sure i will need the thrust arm bushing replaceent soon. I would like to see this get sorted before i have to replace mine.
  15. #40
    Iceland
    BMW 850
    Decided to give here a bath
  16. #41
    Nov 2008
    Maryland
    not enough
    gorgeous!
    With all your research, did you find any alternative to the CSi MAF sensors? My CSi currently has a limp home condition, swapped MAFs and nothing changed...same bank still malfunctioning. Changing DK's hopefully this weekend if it stops raining, but I'd like to get an extra working MAF if one is available that is not a GAZZILLIOOON dollars new .
    CB42366 - 1991 850i 6-speed. Brilliantrot & Black Nappa Leather
    CD00144 - 1994 850CSi. Hellrot & Black Nappa Leather
    My other projects:
    Supercharged Tbirds, V8 Tbirds, V8 Mustang Convertible, Audi V8 Quattro & Audi S8
  17. #42
    Iceland
    BMW 850
    Quote Originally Posted by CaifanSC View Post
    gorgeous! With all your research, did you find any alternative to the CSi MAF sensors? My CSi currently has a limp home condition, swapped MAFs and nothing changed...same bank still malfunctioning. Changing DK's hopefully this weekend if it stops raining, but I'd like to get an extra working MAF if one is available that is not a GAZZILLIOOON dollars new .
    It wasnt me but Omega man who was working on that
    One in the morning
  18. #43
    Ellicott City, MD
    1994 e31, Porsche Macan
    Beautiful car -- and you do such nice photos. Are you using camera or cell phone?
    Life's too short to drive boring cars --
    • 1988 M6 (e24) - Zinnoberrot/Pearl Beige (sold )
    • 1994 850 Ci (e31) - Orient Blue Metallic/LtSilverGray
    • 2017 Porsche Macan - Night Blue Metallic
  19. #44
    Iceland
    BMW 850
    Quote Originally Posted by M6ermike View Post
    Just an iphone 5
  20. #45
    Jun 2012
    Uk
    1994 850csi rhd
    Quote Originally Posted by Fatandre View Post
    One in the morning
    Looking good Andre !!
    as for the MAFs ...if someone can find a MAF that has the same connector and fits the CSi I can adjust the DME to run with it.
  21. #46
    Iceland
    BMW 850
    Quote Originally Posted by Omega man 1969 View Post
    Looking good Andre !! as for the MAFs ...if someone can find a MAF that has the same connector and fits the CSi I can adjust the DME to run with it.
    What about the normal 850 mafs?
  22. #47
    Jun 2012
    Uk
    1994 850csi rhd
    Yeah sure, they don't flow quite as well but could be used...I just need one to test.
  23. #48
    Iceland
    BMW 850
    Winter is coming!!
  24. #49
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Quote Originally Posted by cer54467 View Post
    Just a thought here...... if the center ovalized. how abbout making a thicker center sleeve as to distrubute more of the load on the urethane. we did this on my brothers mustang awhole back and it has lasted over 40k miles now with no issues. ...
    That Mustang also has a different suspension geometry than the E31, plus the Mustang also doesn't weigh in at 4200 lbs...
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
  25. #50
    Iceland
    BMW 850
    Time passes by.
    Car is going to my newest mechanic soon
