Ok guys. I am back with my car and will be doing some work. I have decided to do some myself as it brings me enourmous pleasure so stay tuned. This thead will be updated so I hope it will bring you also some pleasure along some info. I arrived 2 weeks ago and the first thing was to get the car out of the garage and send the computers to Omega man as he is reprogramming them for me to suit the s70. That guy knows his way around that stuff so I highly recommend him this is how the car was after the whole winter.
I am still waiting for the computers so the baby just sits here and waits
I decided to take the old engine apart while Im whaiting and boy it gave me experience.
How would you say it looks under the covers on the old engine ?
One question. Are those the newer injectors
Don't think so. That's what my originals looked like coming out of my '94
Great Thread. Dismantling a V12 is always a great and unique experience.
My CSi`s originals injectors looks just like yours.
- Grush
E31 850 CSi "Chimbica" Thread
E34 M5 3.8 "Charanga" Thread
Workshop Site (in portuguese):
AvantGarde Serviços Automotivos
good. I will have them refurbished and ready for my top end rebuild
get a set of new ones from Bill (Max Lumens). They are almost for free
This so called refurbishment of old injectors is BS IMO because all they normally do is an ultrasonic cleaning plus replace the two O-rings and the yellow cap.
If the yet itself is worn out and shows an uneven spray pattern it won't be fixed.
In regards to the heads I can only say that they look pretty clean (thanks to synthetic oil?) but some jerk has used liquid sealer on the VC gaskets.
Check the condition of the drag levers (part #11 33 1 709 063) because they wear. And new ones aren't that expensive unless you get them from BMW directly.
I always put Mineral oil on that engine as the previous owner had also done so and told me it would be better to do so also.
This engine will be not used in any way. Its just for me to have fun taking apart. I will then just put it in storage. Maybe one day it will be needed.
BINGO,,, a very good point,,
Many owners that gets an idea to put some new fully synth, oil on their old engine start to complain why the hell their engine starts to leak like never before,, this is the reason
But regarding the S70 engine,, i think thats a bad idea to put it in to your 850,,
you know my adresse,,,,,,,,,
Sveinbjörn Hrafnsson
E30 CABRIO V12 M70B50 ///
ALPINA B10 BITURBO 346 @ 507
ULTIMA Evolution
Contacts
http://alpina.123.is/pictures/
I know your address and I know you personally.
I think though it looks better in my e31 :P
Ok,, if you know of an extra CSI engine,,, let me know
ULTIMA Evolution
Contacts
Interesting thread -- keep it coming. Do you know how many miles were on the injectors you show above? Are injectors something that should be replaced every X number of miles because they wear (or deteriorate)? Based on what I read on this forum (thanks to all of you), I'm starting a checklist of unusual things that should be checked periodically and considered for repair/replacement.
Life's too short to drive boring cars --
- 1988 M6 (e24) - Zinnoberrot/Pearl Beige (sold )
- 1994 850 Ci (e31) - Orient Blue Metallic/LtSilverGray
- 2017 Porsche Macan - Night Blue Metallic
Jesus that doesn't look good....what relay number is that slot?
I'll guess at the starter relay ? Looks to be bypassed. Maybe they couldn't start it after changing your DME's .
Possible. What now?
New CSI comp are in. Runs good.
The relay was from the starter. We are slowly getting there!!!
yes, thats the starter relay. BMW basically did the same thing at the factory for manual transmission cars, although they installed a jumper that looked like a relay. The main function of that relay is to prevent you from starting the car in any gear but park, which isnt applicable in manual cars. It doesnt even connect to the DME's.
P# 61368366282
Current:
- 09 335i MSport, FBO.
- 98 Euro M3, Estoril Blue
- 04 M3, Carbon Black, 6 Speed Coupe
- 06 M5, Black on Black, Full Leather.
- 73 3.0CS, Tagia Green, 5 speed M30b35 converted
Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
Yeah I told him to find and old relay, open it up and zip tie the contacts together :-)
Thanks guys for that.
One question.
How do you get that cover off that sits on the radiator?
? The one with 6 plastic fasteners holding it in place? if you look closely you will see 3 triangle marks where it clips into the radiator....pry it up with a small screwdriver at those marks.
