Page 4 of 57 FirstFirst 12345678910111213142954 ... LastLast
Results 76 to 100 of 1402
Thread: So that the "What did you do to your E34 today?" thread may never die...
  1. #76
    Jun 2005
    @6500RPM Las Vegas
    Z3 5-Speed Roadster '97
    Inbound for the 1995 525i, will install this coming weekend...
    Rear brake pads asbestos-free 1 set 34211162536
    Brake pad wear sensor 1 each 34351179820
    72111950829 seatbelt Button top
    72111917406 seatbelt Button bottom
    Plus did an oil & filter change.
    'Sweetness Tres' M44, 1.9L Z3 5-Speed Roadster '97 Boston Green 66K Smiles Mine
    'Sweetness Too' M52, 2.5L Z3 5-Speed Roadster, '00 Jet Black 165K Smiles 2022 Gone Ins Co Total in Jan 2022- Right Front Collision - Paid $8850 !!
    'Ol' Black Betty' S52, 3.2L ///M3 5-Speed Vert '98 Cosmos Black 265K Smiles Wifeys
    M50, 2.5L 525i E34 Tragi-matic '95 Sedan Alpine White III 238K Smiles Was Daughters Mine Again
    'Gretchen' M30, 3.5L 535i E34 Tragi-matic '90 Sedan Glacier Blue/Indigo 144K Smiles 2018 Gone & I miss her
    'Sweetness' M44, 1.9L Z3 5-Speed Roadster '96 Boston Green 264K Smiles Was Mine Ins Co Total in Jan 2013- Rear End Collision - Paid $4800 !!
  2. #77
    Mar 2010
    Marin, CA
    1989 535i Manual
    Valve adjustment on the M30, put the oil sprayer bar bolt that ran away in its place...
    Headlight trim and kidneys are drying now after plasti dip, E32 BBK and 540i6 springs still to come.
    "Big Red" 9/88 Build 535i/5: E.A.T. Chip, 24lb Bosch Design III, 3.46 LSD, 4x Clear corners, DINAN-style 750i muffler, Racing King Subframe Inserts, Koni/Vogtland suspension, E34 M5 swaybars, Brembo/Porterfield brakes, Turbodiesel grills, 16" Style 8 rims, Euro front plate, M5 rear filler plate.
    Save
    Save
  3. #78
    Mar 2011
    Neverland
    E34 525i
    S3.73 out, s3.23 in.
  4. #79
    Jul 2013
    Atlanta
    95 e34 540i/6
    540i/6
    Oil change - Mobile 1 10w-40. Whatever was in there was pretty thin. Thought maybe it was because it was still pretty warm but when I went to dump it at autozone it was still pretty thin. 0w-30 maybe?
    Coolant flush - took me WAAAAY too long! First time on a car like this. Thank God I had a buddy helping me! Ended up using 6 quarts ofG-05 and around a gallon or so of distilled.
    Did all three drain plugs. One of the ones on the engine block, driver side was a bit of a pain because of part of the exhaust.
    Forgot to take some photos before I got dirty... oh well.
  5. #80
    Jan 2014
    United States
    525i Touring
    Changed out my Cabin filter. Wow, I think it may have been t he original one.
  6. #81
    Southern California 92307
    '95 525i
    Quote Originally Posted by chuddism View Post
    Same! When I got the car a month ago the air wouldn't blow out the vents it was super weak. I thought it was the blower motor but it was working fine! As soon as I took out the air filter it blew out of the vents normally! Yeah for a cheep fix to get the air fixed!
  7. #82
    Jun 2005
    @6500RPM Las Vegas
    1990 535i Prod Date 09/1989
    225/60/15 Spare Tire INSTALLED 7/29/14
    Hose clamp L16-30 64218367179 10 each
    Support 13541272473 01 each
    Vent hose D=20MM 11151276485 01 each
    Rubber Mounting 13411705564 01 each
    Hose clamp L12-15 07129952104 20 each
    08 VACUUM HOSE BLACK 3,5X1,8 11727545323 02 METER
    10 KIT FOR FUEL HOSE AND CLAMP 400MM/FPM 1 13311748685 01 each
    11 KIT FOR FUEL HOSE AND CLAMP 40MM/FPM 13531748684 [See MH 9790448] 01 each
    14 KIT FOR FUEL HOSE AND CLAMP FPM 13311748689 [See MH 9790448] 01 each
    15 KIT FOR FUEL HOSE AND CLAMP 400MM/FPM 1 13311748685 01 each
    04 O-ring 7,52X3,53 ? 13641730767 $3.75 01 each
    06 PRESSURE REGULATOR 3,0BAR 1 13531722040 01 each
    1995 525i prod date 05/1994
    14 KIT FOR FUEL HOSE AND CLAMP 360MM/FPM 1 13311703488 $23.63 See SI 130293692, MH 9790448 01 each
    16 KIT FOR FUEL HOSE AND CLAMP .45MM/FPM 1 13311703489 $7.78 See SI 130293692, MH 9790448 01 each
    17 KIT FOR FUEL HOSE AND CLAMP 360MM/FPM 1 13311703488 $23.63 See SI 130293692, MH 9790448 01 each
    06 PRESSURE REGULATOR 1 13531436110 $75.10 01 each
    07 O-ring 5X1,5 1 13531720252 $3.75 01 each
    08 O-ring 20X2,5 1 13531720251 $4.38 01 each
  8. #83
    Apr 2008
    Scottsdale,Arizona
    95 540i/6 M, 87 535is
    putting in s3.15 with new seals, new gas tank, powerflex subframe bushings, akg trailing arm bushings, new diff mount and all 3 diff bushings, pitman arms and rear sway bar links within the next week.
    1995 BMW 540i/6 M sport, Cosmos Metallic
    Black
    Dinan ECU/Trumpet,B&B Exhaust,3.15lsd,Koni sports and H&R springs,UUC SSK, AKG poly RTAB, Powerflex SF bushings,
    RevShift Motor Mounts, M5 Executive interior, Turner Spacers 15mm
  9. #84
    May 2014
    Springfield OH
    1993 525i 1995 553i
    Assessed everything that was wrong with the car, it's a lot.
    95 E34 553i6 LS TR6060 Project
    93 E34 525iA Beater with no heater
    VANOS kicked in yo!
  10. #85
    Apr 2009
    Corbin, KY. USA
    328ic, CLK55 AMG, Disco
    !#$%*%#@!#$! lost the friggin rear windshield trim this morning. Speed was a factor, but I feel the biggest factor was that every single cheap-ass plastic clip that holds the trim on, was broken.
    Without removing the rear windshield, does anyone know if those clips can be replaced? They look to be exactly like the front windshield trim clips, so they are slipped onto the glass before the glass is installed. I would rather avoid paying to have the rear glass removed, just to install new clips.
    2001 CLK55 AMG - 223K Miles : 1999 Land Rover Discovery Series II - 259K miles - 4th engine : 1996 328i Convertible 89K Miles (The wife's) : 2005 Outback Wagon 203K Miles (also The wife's)
  11. #86
    Jun 2008
    Atlanta, GA
    E53, E38, E34, E39T
    Quote Originally Posted by SinisterMoose View Post
    Yes, you can replace Without removing the windshield. Use a 90 degree angle pick, pry out the old clip, insert the new clip in its place. I've done it twice now.
    Some Places remain unknown because no one has ventured forth. Others remain so because no one has ever come back......
  12. #87
    Mar 2010
    Say "log ooh knee tas"
    '95 528iT/5 sport
    Had my car drawn by @cartunedpg.
    my version of a midlife crisis: 20 year old spray painted, lowered BMW station wagon.
  13. #88
    Mar 2011
    Neverland
    E34 525i
    Changed the mirror someone broke yesterday and also the fuel vapor resevoir
  14. #89
    Apr 2013
    New York
    1990 535i 5 speed
    Just bought one yesterday and woke up this morning and stared at it for a good 5 minutes. 535i 5 speed. Soooo happy to find her!
    Ordered some strut mounts, rear seat belts, new shift knob and short shift kit to clean up the shifting.535i.jpg
  15. #90
    Jul 2014
    Chicago, IL
    1992 BMW 525i
    Bought it two days ago (92' 525i), got insurance yesterday, got the plates today and drove all over town!
  16. #91
    South Africa
    '04 330i, '95 540i6
    Drove it to work this morning and for the first time in many months it decided to stall just as I depressed the clutch to downshift.....sigh..
  17. #92
    Apr 2009
    Corbin, KY. USA
    Quote Originally Posted by Trasportador View Post
    Thanks, I'll give it a shot. Beats trying to gorilla glue it.
  18. #93
    May 2013
    Toronto, ON
    e34, e30
    I installed new M-tech pedals, in a dark underground.
  19. #94
    '95 525i
    I finally got all the pieces for the wide grill. Before I bought the car the front had been in a minor accident and the grill was bent. The po installed a thin grill not knowing the difference even though the car had the wide hood.... So I finally have a matching grill again!
  20. #95
    Nov 2007
    NYC
    86 911, 91 XJ
    Picked up a ZF 6spd for it
  21. #96
    Jan 2003
    Bay Area, Ca.
    94 M5T
    Installed some red seatbelts into my m5
    Mike
    93 M5 3.8 Sterling Silver/Black (euro)
    94 M5 Touring Madeiraschwarz/Black
    80 745i (project)
    83 735i / 5 speed (euro)
    86 745i
  22. #97
    May 2013
    Toronto, ON
    e34, e30
    After this i´m done spending money...until next month.
  23. #98
    '95 525i
    Quote Originally Posted by spanish pants View Post
    That window switch delete! Is that a stock option or custom?
  24. #99
    Feb 2014
    Minneapolis, MN
    E34 95 540i/6
    resprayed the rear windowshelf
    resprayed the rear windowshelf with a matte black fabric paint to get rid of the dreadful lavender color that the sun had faded it to on my recently purchased 540i/6. To my surprise, I didn't need to remove the C pillars.
  25. #100
    Apr 2014
    PA
    Finished installing new brake calipers/rotors/ brake lines. Tried to bleed the brakes and the system won't build pressure after trying a few methods. Suspect master cylinder. Ordered a new one. Time to sit on my hands until it comes in
    "Helicopters: 10,0000 pieces of metal fatigue rotating around an oil leak."
