Page 1 of 9 123456789 LastLast
Results 1 to 25 of 204
Thread: rebuilt injectors blowout prices 19-20-22-24-30-34#s
    bavaria tx
    91 e30-07 350Z -E63 AMG
    sets of 4,6,8,10,12 available as well.Prices below for set of 6
    I have many sets available at blowout prices. Prices below are shipped in the USA for a set of 6 injectors. if you need other sizes or quantities please let me know.
    Match up the number with pic at bottom for full specs.
    Every injectors is:
    • -Fully disassembled
    • -Cleaned in a chemical bath
    • -Sonic cleaned
    • -Impedance Checked
    • -Cycled with compressed air
    • -Rebuilt with all new components (filters, Viton orings, spacers, ect)
    #1 Yellow Tops -- 19# 60 shipped
    Flow Rates (Aprox.):
    • 3.00 Bar/ 43.5 PSI --- 19.40 lbs/HR --- 205cc/min
    • 3.50 Bar/ 50.7 PSI --- 20.94 lbs/HR --- 220cc/min
    • 4.00 Bar/ 58.0 PSI --- 22.40 lbs/HR --- 235cc/min
    • 2.50 Bar/ 36.3 PSI --- 17.72 lbs/HR --- 186cc/min
    #2 Dark Blue Tops -- 19s+# 65 shipped
    • 3.00 Bar/ 43.5 PSI --- 19.81 lbs/HR --- 208cc/min
    • 3.50 Bar/ 50.7 PSI --- 21.43 lbs/HR --- 225cc/min
    • 4.00 Bar/ 58.0 PSI --- 22.86 lbs/HR --- 240cc/min
    • 2.50 Bar/ 36.3 PSI --- 18.10 lbs/HR --- 190cc/min
    #3 Pink Tops -- 22lbs $75 shipped
    • 3.00 Bar/ 43.5 PSI --- 22.50 lbs/HR --- 236cc/min
    • 3.50 Bar/ 50.7 PSI --- 24.30 lbs/HR --- 255cc/min
    • 4.00 Bar/ 58.0 PSI --- 25.98 lbs/HR --- 315cc/min
    • 2.50 Bar/ 36.3 PSI --- 20.55 lbs/HR --- 216cc/min
    #4 BLUE Tops 24lbs -- $75 shipped
    • 3.00 Bar/ 43.5 PSI --- 24.00 lbs/HR --- 252cc/min
    • 3.50 Bar/ 50.7 PSI --- 25.90 lbs/HR --- 272cc/min
    • 4.00 Bar/ 58.0 PSI --- 27.70 lbs/HR --- 290cc/min
    • 2.50 Bar/ 36.3 PSI --- 21.92 lbs/HR --- 230cc/min
    #5 Red Tops 32lbs --- $90 shipped
    • 3.00 Bar/ 43.5 PSI --- 32.00 lbs/HR --- 330cc/min
    • 3.50 Bar/ 50.7 PSI --- 33.93 lbs/HR --- 356cc/min
    • 4.00 Bar/ 58.0 PSI --- 36.29 lbs/HR --- 381cc/min
    • 2.50 Bar/ 36.3 PSI --- 28.72 lbs/HR --- 301cc/min
    #6 White Tops 34slbs --- $100 shipped
    • 3.00 Bar/ 43.5 PSI --- 33.34 lbs/HR --- 350cc/min
    • 3.50 Bar/ 50.7 PSI --- 36.00 lbs/HR --- 378cc/min
    • 4.00 Bar/ 58.0 PSI --- 38.48 lbs/HR --- 404cc/min
    • 2.50 Bar/ 36.3 PSI --- 30.45 lbs/HR --- 320cc/min
    Click on picture for larger image
    commonly asked Question 1--- why are there different flow rates for the sme injector.
    Answer ---- most injectors are referred to their flow at a common bar (psi) such as 3 bar(43.5psi) but they are capable fo flowing more or less by simply changing the bar(psi). or in most cases not all cars used a 3.0 bar fuel pressure regulator they varied from 2.5-4 but can be tuned up to 10 bar with a adjustable fuel pressure regulator. so to let the buyer knwo what to expect on their car I list the different flows for the SAME injector using higher/lower pressure.
    Question 2 --- whats the difference for bosch design 1 vs 2 vs 3.
    Answer ---- Well Design I injectors were introduced in the mid 70s and design didnt change till about early 1990.They were basicly all metal with plastics tops and a single pintle.Most engines that were non dohc came with these until the design II.
    Design 2 and 3 changed to a four nozzle design that atomized the fuel instead of simply squirting it in.Both are plug and play.Both designs are 4 nozzle but design III are one piece all plastic manufactured to within 1% of specs vs design II half metal/halfplastic housing manufactured within 2% of specs. basically design III are same flow just longer lasting tighter specd injectors.Also set of 6 is a full 1/2 lb lighter then set of design II. So you also getfur raze car!
    I dont bother with design 1s because the cores are likely almost 30 yrs OLD! Design 2s probably no newer than 15 yr old cores......... so I only design 3........ newer more design and takes the same amountof work as the others to rebuild.
    I guarantee asgainst DOA and full a full year. They should last a good 6-8 yrs before needing another rebuild.
    address is e30ultimate@gmail.com
    --please put a memo so i know which ones to ship out as I have several orders coming in.
    Long Beach, CA
    '97 BMW 332ti
    Do these have any fitment issues? They look different than the original ones i have, 21 lb injectors.
    bavaria tx
    Quote Originally Posted by Marv17 View Post
    I have never personally had fitment issues with any of these from m20->s5x->m6x . Ive installed easily over a hundred sets and sold nearly a thousand I would say. So long as you lightly lube the oring and ensure it seats properly you should not have any leaks or other issues. Now there have been cases of people being clumsy and tearing orings or not seating them properly but that again is user error. Thank you for your interest senor.
    Long Beach, CA
    '97 BMW 332ti
    Oh okay cool. I just wanted to make sure
    Oct 2013
    Beloit WI
    have 4 wheels
    I was going to ask the same question my pink tops are fat and these are nice and skinny, as long as you say you haven't had any issues do you have a set of 6 #4 blue tops 24# in stock?
    Jul 2010
    562/ 949 CA
    M3 Saloon
    PM sent.
    To all those wondering about the pink top injector fitment: the stock s52 injectors are called type-II (metal), the updated versions above are called type-III (plastic). They save you about ~1/2 pound in weight for all 6 and they fit fine. I believe the same o-ring diameter and filters diameter, though there is not a pintle cap to break and lose like the type-II's just a small plastic retainer to hold the bottom o-ring on..
    If the mind can conceive it, & you believe it, you will achieve it. - Napolean Hill
    1998 Alpine White & 1998 Arctic Silver ///m3/4/5
    JC Intake - ASC Delete - Dinan TB - Flow Matched 21.5# Injectors - JC Tune - SS Euro Reps (modified to retain SAP) - z3m ssk - Eisenmann Race 76mm - Yokohama Advan S2 - Squared LTW's - FK Silverline +X - Rogue FCAB/ RTAB/ RSM/ TM - X-Brace - CDV Delete -Racing Dynamics F&R Strut Braces - NGK BKR6E- German Castrol 0w-40
    bavaria tx
    Quote Originally Posted by hide1 View Post
    PM sent.
    This man speaks the truth ! Now order some lol!
    bavaria tx
    All PMs replied. Down to 1 set of pinks! Plenty of others.
    bavaria tx
    All orders went out! Enjoy!
    Central Jersey
    1979 335i
    Bump for an awesome seller
    Long Beach, CA
    95 M3, 2012 civic
    Interest in a set of 24#.
    Still available?
    bavaria tx
    Bump details up top.
    #1 Yellow Tops -- 19# 55 shipped
    #2 Dark Blue Tops -- 19s+# 60 shipped
    #3 Pink Tops -- 22lbs $68 shipped
    #4 BLUE Tops 24lbs -- $70 shipped
    #5 Red Tops 32lbs --- $85 shipped
    #6 White Tops 34slbs --- $95 shipped
    bavaria tx
    Dec 2009
    Los Angeles, Ca
    1995 332i
    payment sent!
    bavaria tx
    Quote Originally Posted by la36bmw View Post
    payment sent!
    thank you sir!
    ok no more pinks left now. and down to 2 sets of blues. plenty of everything else. keep the orders coming
    bavaria tx
    1 st of blues left for now for those that were still on the sidelines.......
    Aug 2008
    Lafayette, IN
    93 Mazda RX-7
    I would like a set of blues could you PM me additional details on payment.
    May 2009
    Miami
    97 M3
    do you have any E36 M3 OBDII pink tops?
    Feb 2008
    Georgia
    328i
    Sent you a PM. I am interested in some 19# yellow tops.
    Apr 2013
    san francisco
    M3
    pm sent
    bavaria tx
    Ok folks. Everyone should have a PM response.
    Now let's get some more orders in for your labor day weekend project!!!!
    Central, PA
    98 328is
    Gonna need a 24# set
    May 2009
    Miami
    97 M3
    I do not have a PM
    Oct 2002
    New York, NY
    95 M3
    Email sent.
    Sardil
    '95 M3
    Oct 2002
    New York, NY
    95 M3
    Anybody home?
    Sardil
    '95 M3
