1993 850 Ci, On my driver's door, the window doesn't drop when you lift the door handle. If I open the door 1/2", it drops. From the inside, pull the handle until you get tension, and the window drops properly. I've tried the car running hold window up button for 30 seconds to try to reset to no avail...anyone else got ideas? Is there another rest technique I can try? Is there a switch in the outer door handle?
Any help would be much appreciated
Yes. They tend to break. Each door has two of them.
#9 For outer door handle:
#4 For inner:
Real picture:
WBR, Tony
Thanks, for the prompt response...I've had the door handle apart, last year, but didn't get into the electrics of it. I should have no problem getting in there and checking the switch....
I ran into the same issue last fall, it was the switch. I could not find an original switch, and people who had the entire assembly were obviously reluctant to part with just the switch. I was able to find a close enough match at Mouser.
I found a switch thru my BMW dealer...
I'd appreciate your help as this seems to be a common problem with many BMW models. However I am hoping to get some E31-specific advice. My passenger window drop-down feature is acting up. Sometimes it works fine and other times not. Yesterday I went to open the passenger door using the exterior handle and couldn't because the window wouldn't drop down. I released the handle and attempted again and eventually it worked. I opened and closed the door a few more times and the window feature worked fine. I believe a microswitch is acting up but I wanted to get some guidance as the photos in Post #2 of this thread are no longer viewable.
I looked on RealOEM http://www.realoem.com/bmw/enUS/show...diagId=61_0808 and saw #9 (61-31-1-383-199) listed as "MICRO SWITCH DOOR HANDLE." Is this the likely culprit? What about #10 (61-31-1-392-192) which is listed as "MICRO SWITCH WINDOW LOWERING?"
Questions:
1) What does it take to replace the door handle microswitch? Removal of the interior door panel?
2) Is there a microswitch in the door striker plate (mounted to the body) that plays a role in this window lowering function?
3) MileHigh (Post #4) mentioned he found a suitable replacement at Mouser. Any ideas what he's talking about?
Thanks in advance.
Sean
61311383199 - microswitch for outer door handle. mounted on the handle itself.
61311392192 - microswitch for inner door handle. mounted on the door lock.
1. Yes. And also removing door handle or door lock. (It might be a good idea to replace handle gaskets as well 51211970855,51211970856)
2. No, there is no microswitch in the door striker plate.
WBR, Tony
See if your window droops regularly from the inside switch as well to help narrow down further..
Another thing to consider.. There are door modules that sometimes act up.. In my car, about 10% of the time, my driver's door doesn't respond to the turning the key, so it doesn't disarm the alarm nor wake the car up. If I open the door I might set off the alarm, and have to walk over to the passenger side and unlock.
'89 735i, '91 850i, '81 MB 380SLC (For Sale), Tesla Model 3, and VW Passat TDI -- Yes, I still repair General Modules, DM for info!
Located in the door, responsible for collecting all the inputs from the door (handle microswitches, window switches, limit switches, door lock cylinder microswitches) and sending them to the GM. They have a few capacitors, but I suspect in most cases, it's usually problems with the switches, not the door modules.
Item #6 here: http://www.realoem.com/bmw/enUS/show...diagId=61_0809
Just replaced two, one each on 2 different cars.
91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
Tom-- Just like the GMs, These door modules are very much repairable--
In fact, they have the same (or very similar) Hitachi CPU in them(privately labeled BMW AG), 2 capacitors, a 5 pin transistor (Probably a 12V to 3.3 or 5V regulator?), and 4x HCF40106 chips (6 inputs each chip, for the window switches, lock and handle microswitches, etc )
They don't seem to have any high power outputs as locks, windows are all handled by the RM.
Interestingly, I don't see any physical difference between the two modules, except the CPUs have different stickers on them (different EPROMs)
What would be cool is having two driver's door modules, and a second set of window switches for the passenger, just because.. :-)
1993 850 ci
New wrinkle on an old problem:
Drivers side window drops 1/2" properly from both inside and outside handles but after a few seconds of the door being open, window goes back up. It appears to think the door is still closed.
Replaced both micro-switches and door module with used parts but no change.
Passenger side - no problems. Door locks - no problems. Window up/down reset did not fix the problem.
What makes the window stay down when the door is open? On my good door, when I manually close the door latch, the window goes back up. On the problem door, the window is already up so nothing happens.
Any thoughts?
Hi
I am resurrecting this one.
In my case it is the door handle switch issue only.
Can you help me to locate where is the microswitch?
61311383199 - microswitch for outer doorhandle. mounted on the handle itself.
You remove panel and then? Does the handle need to be removed? How? and Where exactly is the switch?
All shown here:
My BMW Repair YouTube Channel
Great Video....
Thanks a lot¡
super¡
