Looking for advice before dismantling valve cover and checking engine timing marks.
I think it was a broken/loose timing chain tensioner, and now the engine is out of timing with bent valves.
What size is the crankshaft bolt? Any help appreciated.
Does it turn over?
T-chain failure on that engine is rare. T-chain failure will also stop the engine suddenly, no screeching.
Crank bolt is 32mm
However tensioner will fail. How many miles?
Unknown, 2nd engine. (1st one overheated) I just removed the valve cover, and the chain is off the sprocket, tensioner broken in pieces. The camshaft is at TDC, engine turns over with the starter, is it possible that no valves were bent? I'd like to try a new chain & tensioner before rebuilding the head.
I don't believe it's possible. On a 6 cylinder, I believe 3 valves must be open at any given time. I further believe that a collision is not avoidable in the M30, if the valve is open it's getting bent. So 2 bent valves minimum (maybe the 3rd one was only half open) but possibly many or all of them if the cam rotated at all during the failure.
If no valves are bent you are the luckiest M30 owner ever to have lived
[QUOTE=Binjammin;27693099]Actually I think it's 24 or 27mm...
QUOTE]
Now that you have me thinking about it I think 32mm is wrong but I think it's bigger, 36mm.
No M30 here to confirm. (yes, I said that)
I never saw a green on tan 535i... I don't think that came around until 1994. At least it wasn't common. So you'd have to swap the M30's into 94-95 cars before driving them into landfills.
Like a public service.
