Hi
I bought a usb/aux.. interface for my business cd(cd43). I used my cd changer (kdc c461fm) untill broke down. Item link is below;
http://www.aliexpress.com/item/AUX-U...858557164.html
all wires were connected step by step in accordence with user manuel. But I can't active the cd changer option (1-12 , 2-25, 4-15 etc). We press the CD BUTTON two times, cd changer option (1-12, 1-25 etc) will be showed. But My cd 43 didn't show. How can I active cd changer option to use my interface? It has cd changer port (10 pin male socket). Although it has 10 pin male socket, it only have five needle. 10 Pin female socket with comes interface has got four needle. It's maybe a problem! If I active changer option on cd43, I think I will use my interface. Help please.
I can't use my radio as if this video,
This is my cable.
Not sure what you mean by "But my CD43 didn't show", as that is the radio itself.
Maybe this is the same problem as these supercheap aux cables. The CD43 needs to see an active device on the ibus to turn on the interface. There is a company that makes these small "CD Changer interfaces" to solve this.
I personally use a Dension GW300 (since 2007) which has 3 wires on the small 10-pin CDC connector.
