Found this doing some research, whoever ( Jim ) could make one if these, I think would be quite cool.Essentially you can modify the thermostat to open before the 105, or whatever the factor setting is.
http://www.xoutpost.com/bmw-sav-foru...long-post.html
I saw that about 18 months ago, printed it and was going to do it. I have almost all of the parts needed.
Just never got to it.
Then a few months ago someone was posting about cutting his coil springs to lower the car. We told him it wouldn't work.
He then said he was going to heat them. So thinking outside the box I thought this t-stat would be even easier.
I'm ready to get flamed for this red neck mod.....bring it on.
I took one of my 3 spare t-stats and heated the spring to reduce it's tension. There is no way to determine what your going to end up with.
After I was done, all of 45 seconds, I put it in a pan of water with a Fluke digital thermometer.
At 98.5°C it started to open. Not bad, got it on the first attempt.
I now need to put it in my car and see what it's operating temp will be.
I'm liking this already. Very clever. Sub'd.
Report operating temps when you get a chance to install it.
I did my research too and ended up with a European diesel 4.4 thermostat rated at 88C. Driving around I see temps in 90-93C mostly due to stock fan clutch which is rated at 93C, if I could install a fan clutch rated at 85C maybe I could see temps around 90C, but so far I'm happy with the mod.
Just chiming here... engines operate most efficiently within a certain temperature range. Running lower temps is not always inherently better.
A car with a broken thermostat runs cooler and gets worse mpg and worse performance then a car at correct operating range. Dropping a few degrees is no problem, 95C is about the lowest I would want to go.
PRICE CUT on ALL FABRICS
Agreed their BX, if Jim could find the optimal heating time to get that magical number it would be great !!
It might have been even less, that time was for both sides. I did this about 3+ weeks ago.
As soon as I saw the spring starting to glow I stopped and did the other side.
You need to use a pencil tip flame torch to only hear up the spring and nothing else. Hold the torch parallel to the spring.
I didn't want to lower the temp too much, same reason as blackxs stated.
I hope to test it out soon, will post results.
Does seem like a significant drop to me as well...
I dont want to start an argument here, but I do urge anyone considering dropping such a significant amount in their thermostat to do a lot of research on the topic first
Stuck open is different than normally opening thermostat, my car warms up as fast as with the stock thermostat, I just dont cook my engine and timing guides anymore .
Direct bolt on, no more connector though, but no check engine light. Post # 8 http://forums.bimmerforums.com/forum...-it-works-well
I looked into the diesel thing - it comes in several flavors (temps) IIRC but real hard to find here. Id like a slight temp nudged down stat but agree w the fact that low temps are not better temps for both performance and efficiency. If i could find the diesel model in 95C say i might try that if i could find a source to ship to USA#1....
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
On the topic, my 1998 540i pre-vanos runs constantly at around 80c... if I am parked and idling it will eventually get to 104c where the aux fan kicks in and brings it back down to 80-90c. I did a mechanical fan delete and it is winter here (under 10c) but still I think its running too cool for a 540i.
I also use the 88 C direct fit M62tu thermostat and my operating temps are between 93-95 C cruising and 99 C A/C on idling.
No mechanical fan either.
1999 BMW 540i Sport
2003 M3CicM6 TiAg
Former:
11512248542 direct fit for M62TU, cheapest place I found, and I think many from this forum bought it from: http://www.estore-central.com/part/11512248542, please email the guy first and he may give you even a better deal. My total shipped to the states was $150.
Here's a thought, perhaps the newer DME's will trigger a fault, perhaps they've been remapped. I assume this because it seems the older models seem not to get a fault triggered or a check engine light.
Also anyone the has put a resistor to satisfy the DME, any pics or a DIY ? I'd like to put a resistor, my DME is a 7.2.
