Page 7 of 7 FirstFirst 1234567
Results 151 to 171 of 171
Thread: Just entered the E38 world with a 750iL needing a lot of care. Drivetrain help sought
  1. #151
    Littleton, CO
    2001 540i; 2001 750iL
    Vacuum leak update
    I got time to use the smoke machine/leak detector I bought and found a vacuum leak. The lower o-ring on fuel injector #5 was leaking. The o-rings were not put on by me, but were assembled by the shop that cleaned and flow tested my fuel injectors...so I don't actually know if they are genuine BMW parts or not if that matters. I bought 12 new o-rings at the dealer and reinstalled the fuel rail (fun, fun ). Retested the intakes with smoke machine and found an even smaller leak somewhere on the sucking jet pump (where the brake booster hose attaches). That part is original to the car, so I was wrong not to change it while doing everything else. I have a new one on order and will retest once it is installed. As of now, the idle is still a bit lumpy. I never would have found these vacuum leaks without a proper smoke machine being able to pressurize the intakes. Also, I don't know if a shop would have found both leaks at the same time either, since the 2nd leak is much smaller. It's one of my new favorite tools and will soon use it on my E39 too.
    I also just tested the A/C system pressures, since it wasn't cooling down to the levels I expect (my E39 works much better). I was able to test pressures on a 78˚F day here in December Looks like the system is overcharged with refrigerant. There is also the telltale sign of A/C dye around the very rusty low side port, indicative of a non-factory recharging job, or at the very least, a small leak. I have ordered a new receiver drier and high/low side Schrader valves to get the A/C system up to my standards. I also have a pressure sensor coming, even though I probably don't need it. The compressor has been whining a lot when in use, so it's probably slightly low on oil as well.
    Quote Originally Posted by NordmanMg View Post
    Holly mother, it is crazy amount of work, patients and money right here, you're rocking that car man,
    your the man, good job
    Quote Originally Posted by clarkitect View Post
    Wow dude. Impressive.
    Quote Originally Posted by auaq View Post
    Just finished reading this entire thread. Loved the attention to detail and your devotion on fixing this car no matter what.
    Now onto craigslist if ya don't mind .......
    Quote Originally Posted by apexilude View Post
    I applaud your dedication. Lots of good work in this thread. Took a poorly neglected ride and brought it back to life.
    Quote Originally Posted by blakamin View Post
    WOW!!! Awesome job!
    Quote Originally Posted by Dan750iL View Post
    And I'm not totally ashamed of all of the work I want to do to mine that I haven't gotten (taken the time) to do.
    Awesome work across the board!
    Thank you, kind sirs!
    Quote Originally Posted by dannyzabolotny View Post
    That was my exact reaction. I want a really trashed 750il to fix up now. There was a 1996 750il locally for $1000, but when I emailed the seller it had already been sold.
    I don't know why, but the symmetry of the M73 engine pleases me greatly. Two banks, two air intakes, two intake manifolds, just beautiful.
    It is fun, but a lot of work. Also, I have found that at least two of the dysphemisms for 'BMW' are quite accurate: Break My Wallet, and Bring More Wrenches! I've spent a sizable sum getting new tools I needed or special, "gold ingot style" BMW tools. Mind you, I have owned an E39 for 5 years before getting the E38, and had previously done the entire suspension and timing chain guide job on that E39... so I already owned plenty of tools haha.
    Quote Originally Posted by dan87951 View Post
    Wow! Nice work! I don't even want to know what you have into that car after all that work. I really hope you enjoy the car and it provides many years of trouble free motoring.
    You da man on E38's that's for sure!
    I have a spreadsheet on the costs, but lately, I've just not been updating it...too afraid It is becoming a very comfortable ride now, finally.
    Quote Originally Posted by rahee006 View Post
    this is very impressive! the fuel lines under the car rust, mine was leaking randomly one day after i started the car ( after almost 3 months ) and i replaced the hoses/clamps.
    i want to blast my brakes(calipers) and spindle too, but my hopper doesn't work with walnut shells. this is amazing what you've done. keep it up!
    The hard fuel line rusted through on you? Yikes, I'll have to keep an eye on that, since this car spent many years up north before coming to me. I had to use a more aggressive blasting media, iron oxide, as I found that crushed walnut shell media didn't cut it, at least with my blast cabinet setup and air pressures. I used blasting soda on all of the old timing covers/housings to remove the paper gaskets, since they were NOT coming off by conventional means.
    m73 is very labor intensive, everything is very hard to reach, how hard is it to pull the engine out?
    Now that I've pulled the engine once, it wouldn't seem so bad to remove again (now that everything is clean de-rusted). But I did pull it separately from the transmission (only put it in with the engine & transmission together). Also, it was a very grimy process, since the PO had let CHF fluid leak EVERYWHERE on the left fender area. I also couldn't get either motor mount off while engine was in the car, so I had to remove the mounting arm at the block on one side before removing the motor. I was very glad to have a transmission jack when I separated the tranny while laying under the car. The part of the engine pull that I screwed up was in removing the exhaust nuts/studs from manifold pipes to downpipes. 9 out of 12 studs snapped right off using the impact wrench, and I was trigger happy to get the motor out, so I didn't take my time with trying to get those nuts off carefully, though I did try using penetrating oil. Machine shop couldn't extract the broken studs (even with the manifolds removed) for an acceptable cost, so I had to find 4 used exhaust manifolds.
  2. #152
    Feb 2012
    Bottom of a Bottle
    96 740il, XJS & CBR1000F
    My god man, It would be easier to list what you havn't had to do! Great Work.
    The World is ruled by Kings and Queens that blind your eyes and steal your dreams.
    When answering my questions please use a qualifier if you are not sure.
    The more I work on this car the less I respect German engineering.
    When you speak in Absolutes you are always wrong!
    Semper Fi
  3. #153
    Feb 2014
    MA
    2000 750iL
    I am in the process of rebuilding my engine. Where did you buy the cam locking tool from?
  4. #154
    Littleton, CO
    Quote Originally Posted by masu3701 View Post
    I bought two of them so that both cams would lock at the same time. It is BMW part number 83300490947. You can buy them from anywhere that sells BMW parts; I got mine online from Husker Auto Group. They cost $$$ though, but I think I remember seeing some aftermarket cam locks (made to look like the BMW ones) that were cheaper on ebay.
  5. #155
    Feb 2014
    MA
    2000 750iL
    Quote Originally Posted by atakordie View Post
    Thanks. ordered a set from amazon.
  6. #156
    Arizona
    2015 328i M Sport
    Is this thing running yet??
    Sent from my VS995 using Tapatalk
  7. #157
    Littleton, CO
    yeah, it's been on the road for a while. It made it on a cross-country road trip and back as well. I simply haven't had time for updates, maybe someday.
  8. #158
    Arizona
    2015 328i M Sport
    Nice. So no issues since everything has been fixed?
  9. #159
    Nov 2018
    Melbourne Australia
    Bmw e38 750iL
    Nov 2018....i just joined the group as i bought a 96 750iL.
    Mate......that is the MOST impressive journey you decided to take. And so helpful to the rest of us who own these wonderful machines. I take my hat off to you.
  10. #160
    Mar 2011
    Greenville, NC
    2001 7-S62, 2002 X5 S2,
    Enormous undertaking. Great job!
    Thanks for the kind words. Not sure why, but my subscription to this thread isn't working to notify me of replies, so I have to check manually. Anyway, more pics below of engine install.
    Engine mostly complete, as much as I was willing to do while still on the stand.
    Moving engine from stand to hoist.
    Mounting transmission:
    Waiting to go in:
    Getting started, I have the hoist all the way up here and I'm a bit nervous:
    Had some helping hands thankfully
    A very tight fit. Would have been much easier with the condenser out of the way.
    In.
    Underneath looking back:
    Prepped the injectors. They were cleaned ultrasonically and flow tested fine. Had to buy all new hoses for the fuel recovery side because the somewhat new ones (put on by PO) were tending to split.
    Fuel rail on:
    Engine wiring harness on and most stuff connected:
    Put on new center silencer and new mufflers $$$
    Bleeding brakes, take 1 of 4:
    Video of first startup:
    Working on error codes, module coding, etc.
    Getting ready to let the car down for a fuel fill-up, then back to torque the new suspension with proper weight in the rear:
    2001 | DINAN 7 Sport | S62 Swapped 6-Speed
    DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
    Dual Pane Glass | Black & Sand Int.
    2001
    | 750iL | AlpineWeiss III
    @scotthduke on Instagram
  11. #161
    Arizona
    2015 328i M Sport
    Did you know your color combo of your 750il is 1 of 1?
  12. #162
    Apr 2006
    San Diego, CA
    1998 E38 750IL
    Did the 1270 code get resolved? If so what was ur fix? I’m running into that my self now
  13. #163
    Littleton, CO
    Quote Originally Posted by M I C H A E L View Post
    Nope, did not know that. Never would have expected it.
    Quote Originally Posted by 95E36M3 View Post
    Yes, after checking ohm levels in the crank sensors themselves (within spec), continuity to the DMEs, gap, etc, I pulled a hail mary one day before taking a cross-country trip in the 750...Purchased two new crank sensors at the dealer and installed them. No 1270 codes since. Not sure if one or both of the crank sensors was bad, but it's been on the road for at least 25k miles since then with no crank sensor issues.
  14. #164
    Arizona
    2015 328i M Sport
    Glad all that hard work and money invested is paying itself back to you
  15. #165
    Arizona
    2015 328i M Sport
    How’s the 750 fairing lately?
  16. #166
    Littleton, CO
    Still using her almost daily. Recently drove cross-country for the second time in this car. Discovered the active seats as well as the lumbar function quit working. Will be looking into that after I get my 540 back on the road.
  17. #167
    May 2009
    Richmond, VA
    '01 750il Sport
    How many miles have you put on it? This thread convinced me to get back in the e38 game with a 750 - I know that seems odd given the struggles you had but it seems like as long as you don't overheat them and keep up with maintenance, the v12 drivetrain is mechanically bullet proof. Electronics a bit of a different story, but that goes for all e38s. They're just such great cars when they're right. It's getting them right that's the hard part after 20 years.
  18. #168
    Littleton, CO
    Only put about 43,000 miles on it since rebuilding the engine. No engine trouble since, however, I've put in 2 alternators (both new) due to faulty ones from BMW. I also had a power steering leak at the rebuilt pump, also from BMW. The leak was from a blind plug torqued at the rebuilder/factory, not by me. I had to find a suitable o-ring for the CHF11S fluid used in this car (also services the rear axle suspension) and loctite the bolt back in place. Have had several power steering reservoir spillovers, not sure why, so I run the level lower than max to prevent it. Really frustrating to have cleaned and installed everything, then having to pull off quite new engine components that necessitate leaking fluids to replace them. It took a lot of time, research, and $$ to get the car to a point where I can be confident in using it without worrying about this or that breaking. But it is fun to drive and nice to have the size and presence the 750 gives.
  19. #169
    Dec 2020
    New Zealand
    2004 E65 730i
    Well done sir!!!!!
    G'day all,
    First of all, all the KUDOS in the world to the OP, for taking on a project like this and sticking with it. Unbelievable what has been thrown in your way, and you have charged right through, and carried on and saved a beautiful machine.
    Now I have question to all here, who have read through this entire saga. I am looking at a '97 750iL myself. 165,350 miles on the clock. I can get it for about $3300US.
    Do you think this is a good deal, especially as from what I can gather, parts are becoming very hard to come by, and almost getting priced off the market?
    Below are the specs on her from decoding the VIN
    750iL
    WBAGK22080DH62325
    Model Description GK22
    Model 750iL
    Market Europe
    Development Code E38 (2)
    Chassis Sedan
    Steering right
    Doors 4
    Engine M73
    Displacement 5.40 l
    Power 240 kW
    Drivetrain Rear-Wheel Drive
    Transmission automatic
    Color Aspen Silver - 339
    Upholstery Standardleder/lavendelgrau - N8MK
    Manufacturer BMW AG
    Production Plant Dingolfing, Germany
    Production Date 1997-01-14 (Tuesday)
    202 Steptronic
    214 Automatic Stability Control+traction
    216 Servotronic
    220 Self-leveling Suspension
    223 Dynamic Damper Control
    245 Steering Column Adjustment Elec
    260 Side Airbag Driver/frt Passenger
    295 Lt/aly Wheels/star Spoke 96
    302 Alarm System
    352 Double Glazing
    401 Sliding/vent Roof, Electric
    416 Sunblinds
    428 Warning Triangle
    430 Interior And Exterior Mirror Packa
    431 Interior Rr Vw Mirror W Aut Anti-d
    438 Wood Trim
    441 Smokers Package
    456 Comfort Seats, Electric. Adjustable
    460 Comfort Seats Rr Electric. Adjustable
    462 Comfort Seats With Folding Tables
    464 Skibag
    473 Armrest, Front
    494 Seat Heating F Driver/front Passenger
    496 Seat Heating For Rear Seats
    500 Headlight Washer Sys/intensive Cleaning
    508 Park Distance Control (pdc)
    510 Headlight Beam-throw Contr. F Low Beam
    534 Automatic Air Conditioning
    548 Speedometer With Kilometer Reading
    555 On-board Computer
    602 On-board Monitor With Tv
    629 Car Telephone (gsm) W Card Reader
    672 Cd Changer Bmw For 6 Cds
    677 Hifi System Professional
    694 Preparation For Cd Changer
    806 3rd Stop Light
    818 Main Battery Switch
    841 Option Code Package Pseudo-code-no.
    853 Language Version English
    864 Overseas/dealer Directory Service
    880 English / On-board Documentation
    925 Shipping Protection Package
    Opinions please before I buy her, and end up divorced because the missus throws her toys out of the cot......
    Cheers
    Rob
  20. #170
    May 2009
    Richmond, VA
    '01 750il Sport
    I'd start a new thread, lots of people will give their opinion but all comes down to condition and maintenance.
  21. #171
    Arizona
    2015 328i M Sport
    Nice job. Yes they are quite the experience and presence. A couple years ago I sold a rare 2001 750il sport pkg it was anthracite with black interior. It needed way too much work. It was a bad mistake on my part but I loved every minute of driving it.
