Page 5 of 16 FirstFirst 123456789101112131415 ... LastLast
Results 101 to 125 of 388
Thread: E38 swapped S62
  1. #101
    IL
    2000 740i sport
    Looks amazing!
  2. #102
    Greenville, SC
    01 749iM/6 sporty
    Trevor
    01 749i sporty, build 12/00 "Sports Barge",S62
    92 VW Corrado VR6,AAA
    81 Delorean,B28F
    81 VW Rabbit Pickup 1.8T,AWW
    03 VW Passat wagon 4.0 W8 6spd
  3. #103
    Greenville, SC
    01 749iM/6 sporty
    I had it running for a bit last night, filled the power steering and coolant. Running with not cats or O2 sensors it runs a bit rich and growls and barks. Kind of sounded like a demonic language.
    Trevor
    81 Delorean,B28F
  4. #104
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    Quote Originally Posted by 007008 View Post
    I can vouch for that, it is a true beast with no exhaust on it. I heard it last night.
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
  5. #105
    Greenville, SC
    01 749iM/6 sporty
    State of today.....
    I don't get much time during the week, so it will have to wait til Friday.
    Trevor
    81 Delorean,B28F
  6. #106
    Apr 2014
    jacksonville,fl
    2000 sporty shorty
    Look'n good!!!!!
  7. #107
    GSXRliterbikz's Avatar
    GSXRliterbikz is offline Addict Number 45573... Moderator
    Mar 2008
    Danbury NH
    01 740iL, 04 X5 3.0i
    Oh baby!
    I gotta say though, the odd length intakes drive me nutz
  8. #108
    Lake Oswego, Oregon
    2001 BMW 740i Sport
    Now you are just missing front and rear m7 bumpers.
  9. #109
    Mar 2012
    Blakeslee, PA USA
    1995 bmw 740IL
    Did you get an E39 M5 rear swaybar also?
  10. #110
    Greenville, SC
    01 749iM/6 sporty
    Quote Originally Posted by WarMachine7 View Post
    I don't like the way if fits. The end links are at a sharp angle and it can touch the subframe.
    Trevor
    81 Delorean,B28F
  11. #111
    Aug 2008
    sacramento california
    E38 E36
    It's close, I can vouch for that, so close it can shear the wire on your left rear wheel speed sensor...ask me how I know.
    Excellent and impressive work you're doing here. Congratulations!
    "Let me tell you what Melba Toast is packin' right here, alright. We got 3:15 open differential with an M5 sway-bar outback, a 4.4 liter V-8 with Bosch sequential fuel injection, four cams, 32 valves, VANOS units using Beisan Systems seals, 10 to 1 pistons, a conservative 282 macht schnell horsepower, all planted to the earth with AC Schnitzer Type II Racing Wheels and Michelin PS2s at all four corners, an M5 rear sway-bar outback, and a Strong-Strut tower brace up front. We're talkin' some Deutschland muscle."
  12. #112
    Greenville, SC
    01 749iM/6 sporty
    Secondary air delete
    Hood meet engine, Engine meet hood. You both can't have the same space.
    Trevor
    81 Delorean,B28F
  13. #113
    Arizona
    2015 328i M Sport
    wow that's crammed!!
  14. #114
    Nov 2010
    Charlotte, NC
    Can't wait to see that completed so we can do the same to mine.
    -Paul
  15. #115
    Dec 2011
    warwick rhode island us
    01 bmw 740il
    Secondary air delete Hood meet engine, Engine meet hood. You both can't have the same space.
    Can you so the secondary air pump delete in the m62tu? What's the benefit of it? My light came on for it the other day just don't know either it's the silver valve thing or the pump
    Sent from my iPhone using BF.com
  16. #116
    Jul 2014
    Pasadena, CA, US
    2001 BMW 740iL
    Yep, We have had several "ins and outs" conversations.
    Oh, I have already taken the EWS out of the S62 DME so it will start with my 740's key, also disabled the SAI since its plugged shut (another S62 common thing), and set the sport button memory.
    Can you please explain this further? I just found out that my donor engine from an Alpina B10 will come with the DME and EWS but is missing the key. Blackknight530i already advised me but I need a creative solution otherwise my engine swap is dead.
  17. #117
    Greenville, SC
    01 749iM/6 sporty
    Quote Originally Posted by datmetzkid View Post
    In theory yes. People over on M3 forum have figured out the location of just about every feature and setting in MSS5x series of DMEs. Problem is there isn't much of a hacker following for the ME7.2 so there isn't much info available.
    The SAI blows fresh air into the exhaust stream on cold starts to help the cats heat up faster for emissions. IT does not effect how the engine runs.
    Quote Originally Posted by tkbartscherer View Post
    The only thing I know of is to send the DME, EWS, and a key to someone that can rematch the 3 together. Like http://www.rmsonlinestore.com/main.sc I have not used them but they claim to be able to do it.
    The $1500 they charge to remove the EWS in the MSS52 seams a bit steep. It took me all of 5 minutes.
    Today's update...
    Got the fuel pump and regulator switched over, correct clutch switch installed.
    I had to take one of the valve covers off because it was leaking. Apparently I forgot the dab of RTV where the front cover meets the head. DOH!
    Still no driveshaft, maybe tomorrow. I don't want to try to fit the exhaust until the shaft is in. The M5 cat pipes and the 740 back half only line up sortof. They are different diameter and the spacing is slightly off.
    Some "custom" pipe work is in order
    Trevor
    81 Delorean,B28F
  18. #118
    Mar 2012
    Blakeslee, PA USA
    1995 bmw 740IL
    Is there any way of shaving off a few mm without damaging the integrity of the bar?
  19. #119
    Dec 2011
    Reading, PA
    2001 740i Sport
    Find someone to dump the full 512 flash off the dme then reflash
    That to your dme. If you're lucky the alpina dme might have the same programming code and the all you would need to do is reflash the 64kb section aka the data portion or maps. Which is much easier.
    Galleto cables off eBay can dump both 512 and 64 but in order to dump the full bin you need to put the dme in boot mode first otherwise you'll only get the 64 Kb data file.
    You can verify the code numbers on the dme using inpa
    So u bought engine on eBay? Seemed like a good buy of you can work out the shipping from Hong Kong.
    You might also be able to use a 4.6 x5 flash and you could do that with winkfp.
    Good luck
  20. #120
    Greenville, SC
    01 749iM/6 sporty
    Drove around the neighborhood.
    Trevor
    81 Delorean,B28F
  21. #121
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    Did that hood massaging work ???
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
  22. #122
    Jul 2012
    California Inland Empire
    2001 740iL /1991 E32
    Very nice job man....
    2001 740iL Guides,chains,vanos done. Full steptronic retrofit,3:15 diff. DUDMD tune. Sport seat retrofit. Porn lights
    [IMG][/IMG]
    Nitto ZR 285/40/18 rear 245/45/18 fr. UUC springs front. Porn lights. Sport wheel
    1991 735iL UUC springs front only Style 42 wheels
  23. #123
    Greenville, SC
    01 749iM/6 sporty
    Quote Originally Posted by TxDarth View Post
    It closes, Still have to take the hood off and weld it back together. I'll take it for an alignment on Friday then tackle the hood and the air filters.
    Trevor
    81 Delorean,B28F
  24. #124
    Mar 2012
    Blakeslee, PA USA
    1995 bmw 740IL
    Going dual cai?
  25. #125
    Nov 2010
    Charlotte, NC
    Nice Trevor! How is it with the M5 diff? Have you laid some "11"'s down yet? Did you already get the exhaust welded up, or are you running it right off the cats?
    Also, I see you went with the 749 moniker as well, curious about the Csi though. I thought the C usually referred to a coupe.
    -Paul
