Upgrading to a parallel-flow condenser is definitely the way to go. I haven't done the E21 yet, but I converted my e28 to 134A including a sanden compressor and new PF condensor. Together they work VERY well.
1975 2002 - Swap in Progress
1982 320i - Well Loved
1982 323i - Cooler than first appearance
1988 M5 - The Original
Does anyone know of a confirmed "drop in" parallel flow condensor that will work in an E21 with the original hoses? One that will work with little or no mods?
Not a valid question, since any 30 year old hose must be replaced, and also the old hoses are often not suitable for R134a anyway (it has a smaller molecule that leaks out more easily). Hoses are cheap and easy to get. Search for a "hose and gasket" or hydraulic hose shop in your area. I pay about $15/ea to have them made.
No one sells an exact replacement parallel flow condenser, but there are many generic ones. I just bought one from Nostalgicac.com for another project. I haven't measured, but I'm sure they have one that's suitable for an E21. You want to cram in the biggest one possible.
Pardon my ignorance but the only benefit from a PF condenser is more efficient cooling of the refrigerant which in turn is lower temps at the vent?
In a nutshell, yes. I imagine it would also reduce load on the compressor, though I'm not sure if ours cycles at all, to be honest. If it does, the controls must be somewhere in the dash
-John
I know you (John) have a late model but, to the early crowd....
I know that I did not plug in my wire from the AC switch into wherever it goes (the expansion valve)...I know this now. Can I get to it just after taking off the heater panel or do I need to remove the whole center console? Thanks, I guess I will start with just the panel. I am going to get this thing fixed.
Just to add some info:
It looks like this FOUR SEASONS company has taken over the YORK car AC business and YORK has moved on to Home and Commercial refrigeration.
Anyhoo...right here, it says this is a reman York 206 but, it doesn't say mini. Over at the S10 (chevy truck) forum, I guess they used a 206, 209, and a 210. If some of them are right, there is a 206 mini and a 206. Would love to know just in case someone else wants to know.
I guess my expansion valve wasn't unplugged. I unplugged the wires to it, I guess. Going to test it now. From external power, I already know the compressor works.
oh...here's the link:
https://www.amazon.com/Four-Seasons-...ype=automotive
ALSO...the S10 guys are saying that the 80-83 e21 has the York 209 mini. Early has a 206 mini but, they are in the same case, have the same mounting, and something is changed internally to make the displacement bigger.
There's a bunch of John's around here, huh? Does anyone know if my early model has a wire going to the expansion valve? Never noticed it uninstalling the old one, maybe it came off?
-John
The expansion valve is purely mechanical, there are no wires to it.
Not WIRE per se but, flexible metal prong? Pretty much every 70-80's AC "MIN/MAX" knob I've ever seen has one. For example:
that probe goes somewhere eh? it plugs in. anyhoo, I guess the electrical power wires on my AC thermostat switch came off therefore, my ac would not kick on. Now I'm going to fill it again and use some oil/leak sealer this time. Yes, I know I need to fill the oil in the compressor but, I'm just not ready yet.
Has anybody used one of those?
http://www.dtechparts.com/bmw-2002-k...ac-evaporator/
Made for a 2002, but the setup in the E21 should be very similar, and you don't have to mess with integrating the A/C into the existing heater system.
The evaporator is 14" wide, so it might interfere with either your right leg or the glove box.
But it would all be brand new and efficient...
Dieter
On the current season of "Wheeler Dealers", they just put one of those in a 65 Volvo. That's it...that's all I got. Totally useless information.
Hi Guys,
I just found and went through this thread. I replaced the "Brick" in my 83 back in 2010-2011. I actually bought the York compressor from, of all places, Freightliner(the truck company).
I changed over to r134 at the time but I cannot remember all of the steps. I did replace the drier and a part under the dash with the little capillary tube, and the o-rings. It's been working well ever since. I found and attached a pdf in case it's helpful.
If I find anything else I will post, I'm still looking for the Freightliner part number for it.
It looks like my gas is all leaking out of the passenger side, right before the glove box starts and just after the center console. It came right out the lower trim under the dash. I have no idea what's right there but, I do know that trim piece is separate. Thinking maybe I can get some orings on whatever is there for now. Any idea what it might be? I think a pipe or two comes out of the box there?
So it basically leaks right out of the Vent (for the heat from the engine) flap there. Know what I mean?
Sounds like your condenser or your evap valve. Does it come from the tar-like goo, or actually in the console?
Yeah, I'm thinking it's something like #5 here. Going in to the pipes coming from the evaporator. Only for mine it calls it a "conical ring" instead of a rubber gasket. 20mm (or 3/4 inch if I have to.) it says, for late model, 11.1mm. Someday, when it's colder...I'll fix it.
I got a e30 318i rotary compressor and bracket recently and I am going to attempt to use it. I think I need to have 1-2 new hoses made to install it though. I just hope the compressor is still good since I am going through the effort of installing it.
88 M3
91 318is
91 318i
83 320is
08 X3 3.0si
These #5's are copper "flare gaskets", not rubber o-rings. Best price I found for them (they can be several bucks apiece) is from this guy on ebay (no relationship, just a satisfied customer).
http://www.ebay.com/itm/FLARE-A-C-CO...oAAOSwo4pYL8uU
Smear some "Nylog" on the tube ends and copper seals before you tighten it back together.
oh boy. Another Florida summer, and I still haven't fixed it.
