Page 23 of 23 FirstFirst ... 1314151617181920212223
Results 551 to 575 of 575
Thread: FOR RENT: Rear Subframe Bushing Remover/Installer Tool for E39 Sedan AND Touring
  1. #551
    Dec 2007
    McLean, VA
    1999 BMW 528it,2003 530M
    Hi, Are you still renting the subframe bushing tool?
    Merrimack, NH
    '02 525iT and '89 944S2
    Ooops, replied to wrong thread.
    Last edited by neilschelly; 06-21-2021 at 06:44 AM. Reason: Ooops, replied to wrong thread.
  3. #553
    Jun 2021
    Asheboro, NC
    2000 E39 Touring
    Looking to rent the tool. Let me know when its available.
  4. #554
    Salt Lake City Utah
    03 525iT, 01 33Ci, 318is
    Looking to rent the tool. '03 525iT. Also looking for Lemförder bushings in case any one has a set (expected to be available January, 2022.) I tried Meyle HDs on my last wagon but they seemed harsh.
    Oct 2020
    Florida
    E39 m5
    Do you still have the tool and is it for rental
  6. #556
    Oct 2020
    Florida
    E39 m5
    What are the dimensions of this tool? I need to do my bushings and understand the tool rental is a NO GO? Or am I wrong. Either case I would like to build or purchase this simplified version
    Quote Originally Posted by mlytle View Post
    Make your own. Simple.
    what are the dimensions of this tool
  7. #557
    Oct 2021
    NJ
    1999 528i Touring
    I'd also like to rent this.
  8. #558
    Sep 2014
    KS
    e24e30e36e39e90
    Quote Originally Posted by Tinonhall View Post
    Eh that 'simple' claim is way off target.
    The main benefit of the rental tool is that it is designed so that you don't have to remove the sub frame from the car. You just loosen the bolts to drop the sub frame down a few inches, enough to fit the bushing in between the body and sub frame, and the tool both extracts the old ones and pushes in the new ones. AND works for both wagons and sedans. Looks like that home-made job is just a basic extractor and won't work with the sub frame on the car because that lip is on top of the sub frame. Only about 2-3 hours to do all four from start to finish with the good tool. Hell you don't even have to take the wheels off of the car.
    I would try to send the renter a PM if you haven't already.
  9. #559
    Salt Lake City Utah
    FYI, in case this tool is not available, I rented a slightly different tool from Neil Schelly. I was very pleased with the tool and the OE BMW bushings which I ordered from GetBMWParts for my 2003 525 touring. Several years ago I tried Meyle solid bushings in a different wagon and noticed no decrease in harshness and clunking over bumps. Here is a link to Neil's thread: https://www.bimmerforums.com/forum/s...placement-Tool
  10. #560
    Jan 2022
    Vancouver WA
    2005 330ci ZHP, 6MT
    Looking to rent tool, but can't get PMs to work thru the site...please contact me
  11. #561
    May 2009
    Orange County, CA
    2000 Dinan S2 M5T
    Quote Originally Posted by john.douglas View Post
    I’m no longer renting out the tool.
  12. #562
    Jan 2021
    Ny
    94e36, 00e39 532it turbo
    Pretty easy to make a solution. Make sure to grease the threads so they slide easily / dont damage.
    This was a few dollars in angle iron that was laying around, and a 1/2" threaded rod with a few nuts. (Also laying around) the threads got chewed some. But I have 6 feet of this rod, so i will just replace it each bushing. Replacing with powerflex busings so no tools needed for installation.
  13. #563
    Jul 2012
    mitten
    525it,02 525it,73 2002
    I have no idea if this is still available to rent or anything about the logistics. Caveat Emptor
  14. #564
    Merrimack, NH
    Quote Originally Posted by jp5Touring View Post
    Yes, it is. Logistics are in that thread.
    -N
  15. #565
    Sep 2014
    KS
    e24e30e36e39e90
    Quote Originally Posted by Sio2crew View Post
    Once again, the point of the tool is that no sub-frame removal is required. Unscrew the bolts to drop the subframe down enough to fit the top part of tool between sub-frame and body, then remove and replace bushings, working your way around all four. 2 hour job. You don't even have to take the wheels off.
  16. #566
    Nov 2016
    Santa Cruz, CA
    2000 540i Touring
    Quote Originally Posted by sienayr View Post
    Just to clarify, since I too will soon be doing this job, are you saying do one corner at a time with all four bolts loosened but only one removed at a time? Is it worth getting some threaded rod to "hang" the subframe a bit lower on as some threads suggest, or is that not really required?
  17. #567
    Jul 2012
    mitten
    Quote Originally Posted by msvphoto View Post
    Yes loosen up then one corner at a time. No threaded rod is required. I had access to a hoist so really easy. I would think theirs a how to somewhere in this thread.
    If doing on jack stand maybe 3 hours or so. Just takes a while ratcheting the old ones out and new ones in.
  18. #568
    May 2014
    Fredericksburg, VA
    2000 528iT
    I have a tool available for rent. Did my bushes in under 2 hours with it. Cost is $50 + shipping at actual cost + refundable $300 deposit.
    Robert
  19. #569
    Jan 2021
    Ny
    Once again, the point of the tool is that no sub-frame removal is required. Unscrew the bolts to drop the subframe down enough to fit the top part of tool between sub-frame and body, then remove and replace bushings, working your way around all four. 2 hour job. You don't even have to take the wheels off. -sienayr
    Yes, you could pay for shipping. Wait for the mail. Get it done in the allowed time? Hope you don't compromise the rented tool? Then spend another day shipping it out. Or just slap together some angle iron. Drop the subfrane because your refreshing more than just the bushings when your in there. Spend nothing, owe nothing. Takes one day. New tool on the shelf. To each their own. In the end I actually only used the first rod. Grease does wonders.
    To each their own. If you can't handle bleeding rear brakes. I totally understand.
  20. #570
    Jul 2012
    mitten
    A eight year old tool rental thread and a two year old thread with no complaints but okay. The tool rental is super easy way to do it.
    Couple hours of work and two minutes to print a new shipping label on to the next person.
    Again there is no need to pull the the rear sub frame, but hey to each their own.
  21. #571
    Dec 2017
    Warsaw, Poland
    2001 BMW 525i
    This thread is so helpful, even to those who can't rent the tool ( like me, I am from Europe). I just made the tool from metal bits and scraps. I have a question to you guys - I just got back from a test drive. Squicking noise from the back is gone and car feels much better. However, there is one thing that got me worried. I can hear a distinct metallic sound from under the car, it is speed related. Is possible that lowering the subframe damaged the shaft/center support beering ??
  22. #572
    Nov 2022
    Clifton, Va
    2000 528it
    Rent
    Quote Originally Posted by raftel View Post
    Robert
    Is the tool still available for rental? Thanks
  23. #573
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    YES Robert (Raftel) has the tool for rent
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
  24. #574
    Sep 2022
    Washington
    2011 e92 328i, 2003 e39
    Are you still renting? Interested..
  25. #575
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    PM him
    https://www.bimmerforums.com/forum/m...?635416-raftel
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
