Page 21 of 23 FirstFirst ... 11121314151617181920212223 LastLast
Results 501 to 525 of 575
Thread: FOR RENT: Rear Subframe Bushing Remover/Installer Tool for E39 Sedan AND Touring
  1. #501
    Salem, Nh
    01 Z3M Coupe
    The tool is on it's way back to M5 Jed for the next in line.
  2. #502
    May 2016
    Las Vegas
    2003 540iT Touring Wagon
    Ordered bushings should have June 4th or 5th, will be ready for the tool anytime after the 7th.
    Jed if you could PM your pay pal address will send the deposit...
    Matt
  3. #503
    May 2016
    Las Vegas
    Thanks Jed shipping the tool works on Wed...
    Matt
  4. #504
    Sacramento, CA
    88 M5, 02 525i
    I would like to be next in line for the tool if thats possible. Jed, I sent you a PM yesterday.
    Thanks,
  5. #505
    May 2009
    Orange County, CA
    2000 Dinan S2 M5T
    Updating the reservation list.
    Subframe bushing tool is with adamocca
    1. CMM3
    2. adamocca - current renter
    3. SCRSUVS
    4. mike okisbig
    Diff bushing tool is available.
  6. #506
    May 2016
    Las Vegas
    Hello Jed,
    Just looking for an update on the tool shipping est?
    TKU much,
    Matt
  7. #507
    May 2016
    Las Vegas
    SF tool arrived late Monday afternoon, the name tool was bugging me so I renamed it the "Jedi M5"...a nod to the man making it all possible...& sounds better than the "subframe bushing tool"...easier to ask is the "Jedi M5" available?
  8. #508
    May 2009
    Orange County, CA
    2000 Dinan S2 M5T
    Subframe bushing tool is with SCRSUVS.
    1. CMM3
    2. adamocca
    3. SCRSUVS - current renter
    4. mike okisbig
  9. #509
    May 2009
    Orange County, CA
    2000 Dinan S2 M5T
    Quote Originally Posted by mike okisbig View Post
    Thanks,
    The tool will be ready and available for you in the next couple of days. The current renter has plans to go to Sacramento and can meet with you to hand off the tool. Please respond to my PM I sent yesterday. Thanks!
  10. #510
    Sacramento, CA
    88 M5, 02 525i
    PM sent thanks!
  11. #511
    May 2016
    Las Vegas
    Quote Originally Posted by M5 Jed View Post
    My update;
    Finished using the "Jedi M5", no way to do this job without it. After reading the instructions was easy to pull the bushings out with "extra wrenching" with the 24mm socket inc. By chance IM going to Sacramento & plan on dropping it off to okisbig next week. The two front bushings were more stubborn, the rears one went in quite a bit just by pushing, needed to finish it with the Jedi M5. I still need to do VC gaskets, cooling hoses, bleed brakes, oil pan gasket, brake hoses.
    Cleaned all the parts off ready to use again. Get some grease, it is the key, jack stands, floor jack, read instructions, it really is an easier job than expected, my car is still down so will be a few more days to feel the results. The bushings although splitting were not in as bad of shape as I expected,
    GREAT TOOL...AKA...THE JEDI M5...
  12. #512
    May 2016
    Las Vegas
    PM sent thanks!
    Carl see your PM from me, the Jedi M5 is ready to use, I plan on heading to Sac upcoming week after my car is done...waiting for transmission cooler valve, will bring the Jedi M5 end of upcoming week, will need to coordinate times, will be in touch...PM me...
    Matt
  13. #513
    May 2016
    Las Vegas
    Carl, change of plans the Jedi M5 has been shipped off to you...
  14. #514
    May 2009
    Orange County, CA
    2000 Dinan S2 M5T
    Updating the reservation list for subframe bushing tool:
    1. CMM3
    2. adamocca
    3. SCRSUVS
    4. mike okisbig - current renter
    Diff bushing tool
    1. Tudor Stan - current renter
  15. #515
    Fresno, CA
    2002 330i, 2000 528iT
    All - Good thread, but I feel it is lacking in some good photos. I did this job yesterday using the BavAuto tool since the Koch kit is no longer available. I ended up removing both fender liners. Did the project from start to finish in 4H:22M.
    Here's a link to my photos:
    https://************/ya8cl99e copy and paste url, then erase all * and substitute tiny url dot com (one word and dot is a .). Forum is filtering out the link.
    | 2002 330i 5-SPD - 101k | 2000 528iT - 146k |
    My E46 Maintenance Thread http://forum.e46fanatics.com/showthread.php?t=1124584
  16. #516
    Aug 2018
    Dayton Ohio
    2000 528iT
    Anyone currently renting the tool? Either way, I'd like to add myself to the waiting list.
  17. #517
    707 CA
    naggin' wagon
    Anyone on here try the Rein Subframe mounts? FCP has a sale for $33 a pop right now. I was going to hold on doing the subframe mounts till I actually diagnose where my rear vibration is coming from, but I don't want to miss out on a deal.
    Any input on the Rein mounts vs the Meyle's??
    https://www.fcpeuro.com/products/bmw...9-33311094036a
    If I end up getting these, I will have to reserve my name on the list!
    1994 325is (2006-2010) -- 1989 325i M50 Swap (2011 - 2014) -- 2001 525iT (2018 -Current)
  18. #518
    Oct 2012
    Charlotte, NC
    2003 540it
    i dunno man, the Lemfeorders are only $100 more for the set, I'd rather go with that. Rein is made in China, and that's not necessarily a bad thing but for an item like this, I probably spend a little more. I use Rein for non critical parts so I'm all for saving some money here and there.
    This is too PITA of a job to do it twice!
    From what I heard, the Meyles are actually solid on the inside (no fluide) and last even longer, theymight be worth a shot!
  19. #519
    707 CA
    naggin' wagon
    Yeah the Meyle's would be roughly $40 for the set. I'll have to throw my car on the jack stands to see what's going on under the car that's causing my vibration. If they don't look good (very probable), I might bite the bullet. I have an entire wish-list that I have to prioritize.
    Thanks for the quick response!
    EDIT: And btw, this is what is on FCP about the Meyle bushings: "Meyle HD bushings are redesigned from the OEM part to have a longer service life. This bushing features solid rubber construction instead of the more traditional OE style hydro fill."
  20. #520
    Aug 2018
    Dayton Ohio
    2000 528iT
    I PM’d Jed about the tool rental but have not received a reply so I started looking into buying the tool myself and I can only find international sellers selling it for around $200 shipped from the UK.
    https://m.ebay.com/itm/BMW-E39-520i-520d-523i-528i-530-ESTATE-TOURING-REAR-SUBFRAME-REMOVAL-BUSH-TOOL/263390598095?hash=item3d534d93cf:g:zi4AAOSw6n5Xq9E 0
  21. #521
    Oct 2012
    Charlotte, NC
    2003 540it
    thinking about buying the tool from uk Ebay, I'm also waiting on another guy to respond about renting me the tool. $200 ain't bad.
    It seems like the ebay one only gives you one extension rod, whereas the members on this forum give you 4 extension rods to lower the entire subframe, (not just one side at a time). Wonder if the Ebay one will work with only 1 extension rod...
    2019 X3 M40i Glacier Silver
    -stock
    2003 540iT Titanium Silver
    -Dinan Exhaust
    2003 325i 5-speed Japanrot
    -BMW Performance Intake
    -Dinan exhaust
  22. #522
    Aug 2018
    Dayton Ohio
    2000 528iT
    I bought and just received a tool from Ebay.
    https://www.ebay.co.uk/itm/REAR-BUSHES-REMOVAL-AND-INSTALLER-TOOL-BMW-5-ESTATE-TOURING-E39-1995-2004-/322510681422
    It took 6 weeks to show up but I plan on trying it this weekend. Ill let you know how it goes.
  23. #523
    Aug 2017
    Ann Arbor, MI.
    2000 528i Touring
    Howdy all. I'm looking to rent the tool. Approximately how long is the waiting list?
  24. #524
    Aug 2018
    Dayton Ohio
    2000 528iT
    there isnt a list at moment, at least i dont think. i purchased a tool and will be trying it out this weekend. if all goes well it would be available for someone next week.
  25. #525
    Oct 2012
    Charlotte, NC
    2003 540it
    Quote Originally Posted by kidwell754 View Post
    Alright Keep us updated, I'd like to rent the tool from you when you're done. I'm located in North Carolina. Lemme know if you run into any trouble lowering the subframe. I think the person that used to rent the tool includes 4 longer subframe bolts that allow the subframe to drop further inorder to fit the tool onto the bushes.
    Talk soon!
    -stock
    -Dinan Exhaust
    -Dinan exhaust
