Results 1 to 8 of 8
Thread: '87 325is RADIATOR FAN NOT WORKING
    Dec 2013
    Atlanta, GA
    1987 BMW 325is Coupe
    So my car's radiator doesn't work. I don't believe that it's ever worked since I bought the car. Please help, SoWo is this weekend and I can't let my car overheat and risk a break down.
    Apr 2009
    norcal
    a few e30s
    Is it the radiator, or the fan? Probably the fan clutch if the car runs fine when driving/moving but heats up at a stop. Test it and replace if necessary.
    Jul 2012
    Woodinville, WA
    2002 BMW 330Ci
    More info pls.
    Pine Plains, NY
    88iX, 89iX, 90iX, 91iX
    Quote Originally Posted by Silverdogz View Post
    More info pls.
    Yes, I would backtrack the steps (like in pee wee's big adventure but in reverse) by first testing the big fan you see under the hood...that's the clutched fan dohcdoh is talking about. There are bunches of posts about testing this jerk ass fan. If that fan passes the clutch test, then perhaps you mean the AUX fan right behind the bumper. Jump it to 12v and see if it spins. If it does, great! (if not, test the ground post). You have bigger problems, but cheaper and easier than a fan. Check the "AUX fan" sensor in the radiator (3 prong guy, I believe). I'm not too keen on the wiring but one of those prongs should be GND, and one should be zeroed out to a prong on your fan. The other prong can suck my butt. Sorry, but I don't know much more than that. My '90iX hasn't had an aux fan since '08 and sat many hot NY I-84 hours idling and never hit 1/2 way to the 3/4 mark ( like between 1/2 and 3/4). Your overheating problem might be something else.
    My For Sale stuff on r3v
    Quote Originally Posted by jagerking View Post
    Despite what people think or you may have heard, the iX E30's are NOT rare. They made 193,000 of them
    Oct 2003
    Santa Clarita, CA
    E30 Turbo
    You absolutely don't need an aux (electric) fan as long as your mechanical fan clutch is in good shape and you're not using the AC.
    BimmerHeads
    Classic BMW Specialists
    Santa Clarita, CA
    www.BimmerHeads.com
    Oct 2013
    Chicago, Illinois
    '90 bmw 325is, '90 vert
    Newspaper test on the fan clutch to see if it is in proper working order and check the radiator for obstructions.
    Dec 2013
    Atlanta, GA
    nvm guys, problem solved. fan guard was catching the fan blades towards the bottom
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    Check your motor mounts.
    "Howdy, Folks!"
