but it has to be an automatic.
so if you guys run across one in the salvage yards please let me know.
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
14 f800gsa - red headed stepchild!
I have 4.44 ring pinion from 96 coupe 318 ATM... My understanding is that's the same
I thought 318i coupes had a 188mm differential... I remember reading you had to get it from a ti to install into an E21 case.
If you get tired of waiting to find one at junkyard prices, I'd check with www.2002parts.com first.
The e36 318i/is and 318ti all have 168mm diffs.
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
100% sure. The guts in my e21 diff are from an e36 318is
The e36 320i also has a 168mm diff, but there probably aren't many of those in the US.
thanks
are you running 3.45:1 ?
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
Yeah, 3.45
I think being Canadian is confusing the issue... there's a much wider variation in euro/canadian cars and a lot more small case diffs used. I'm 100% certain that I have READ that US coupes have a 188mm diff. Reading doesn't make it a fact though, and I've mercifully never been tasked to look at an E36 up close.
Is this what you're looking for?
http://www.ebay.com/itm/BMW-168mm-Sm...2c3726&vxp=mtr
2011-E90 328i 6 speed manual.
If any e36 318 has a 188mm diff, it was swapped in. They all came with 168mm diffs, regardless of USA/Canada/Euro spec.
No, the 318i/is has the e36 style rear suspension. The diffs have two mounting points on the rear cover. They look like the 188mm e36 diffs, but smaller.
Found a pic on google images. The diff on the left is a 318i/is diff, one on the right is a 188mm.
Joey has it correct.
In short, the 4-cylinder E36's came with 168mm diffs.
I have a set of 168mm 4.45 ratio gears cryogenically frozen; local bay area
Wanganstyle Powertrain
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
