Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 124
Thread: 99M3 TT Stg2 build
  1. #76
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Im loving the update
  2. #77
    m3mods's Avatar
    m3mods is offline Boost Addict BMW CCA Member
    Sep 2011
    AC Schnitzer S3 CLS
    Interested to see if the tt manifold becomes a restriction for you. Stoked you're finally using the gtx though!
  3. #78
    Jan 2005
    Santa clara,CA
    F80
    Quote Originally Posted by IR M5 View Post
    Wow you're making me very jealous.
    What modifications need to be done? And who's doing the tuning?
    I went w/ a compact T04E frame with 3" inlet and 2" Vband outlet on the gtx. Everything seems to fit besides modifying the downpipe.
    For tuning I went w/ :
    Quote Originally Posted by m3mods View Post
    Yes, I'm assuming that would be the next bottleneck.
  4. #79
    Jan 2012
    Tucson AZ
    99 Tslvr M3 /98 dakar M3
    Sub'd
  5. #80
    Indy--->Chicago-->Atlanta
    2003 530i E39
    what software are you tuning the ecu with?
  6. #81
    Bay Area, CA
    e36 m3
    What did you do to your cyclone oil separator? Looks beefed up.
  7. #82
    Vancouver, B.C., Canada
    '97 M3
    NickG has said that the TT manifold is a restriction above 500 whp.
    Sent from my GTX3582R
  8. #83
    Jan 2005
    Santa clara,CA
    F80
    Quote Originally Posted by rcatank View Post
    E85 Tune is handled by RK Tuning
    Quote Originally Posted by DrewMontE36 View Post
    The stock one was modified w/ the parts provided by the Technique Tuning Stg 2 kit.
    Quote Originally Posted by chikinhed View Post
    Yeah, a new manifold is on the list when the "want more" itch starts
  9. #84
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Aren't we forgetting the most obvious though? You are running stock cats and a muffler.....that's about 50 rwhp right there just in restriction alone! Let that bad boy breathe!
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
  10. #85
    Jan 2005
    Santa clara,CA
    F80
    Quote Originally Posted by BMWManiac View Post
    Got it covered
  11. #86
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    youll pick up even more power if you dump the gate and do a cat delete with a blow through muffler
  12. #87
    Orange County, California
    99 Estoril M3
    Dang, you jumped real quick for the upgrade Thirst for more powa is addictive, huh?
  13. #88
    Jan 2005
    Santa clara,CA
    F80
    Quote Originally Posted by kobe 8 View Post
    Having an E85 station 3 miles from me helped make the decision easier
  14. #89
    Jan 2005
    Santa clara,CA
    F80
    First semi-fill up
    With about 12gals of E85 and 4 gals of 91 oct
    Thanks goes out to David@4B and Jordan@rk
  15. #90
    Jul 2011
    Bay Area, California
    M3 w/Gt35r
    Did you just have a V-band flange welded onto the existing TT downpipe? Looks great. Interested in hearing how she's performing now.
  16. #91
    Jan 2005
    Santa clara,CA
    F80
    I believe you can do that w/ the existing TT downpipe but for my setup david fabbed a new dp
  17. #92
    Kirkland, WA
    2006 Toyota Tundra
    What did you do with the Garrett 60-1
  18. #93
    Jan 2005
    Santa clara,CA
    F80
    Quote Originally Posted by Alpine 318is View Post
    Gonna be fs soon along with the parts that was swapped out
  19. #94
    Jan 2005
    Santa clara,CA
    F80
    Slowly cranking up the boost ...
    Base tune @ ~9psi
    First revision then @ ~12psi
  20. #95
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Was surprised to see the traction control intact.
  21. #96
    Jan 2005
    Santa clara,CA
    F80
    Well, the run above was the best out of the ones I did. If you look closely, it slipped abit ~4500... Usually it ends up like below:
  22. #97
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    Quote Originally Posted by rodw View Post
    He means the actual traction control hardware still in place.
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
  23. #98
    Jan 2005
    Santa clara,CA
    F80
    Quote Originally Posted by Matutino View Post
    Oh..why wouldn't it be?
  24. #99
    May 2003
    Irvine
    Is a restriction.
  25. #100
    May 2003
    quebec
    |99 Turbo M3 | 2K7 335|
    NickG sells a TC bypass elbow if you need one... I bought one with ASC and one without with my kit...
    _____________________________
