What are u using to adjust it tru boost ?
doesnt the movement of your sway bar interfere with your turbo pipes?
Looks good! Lets see some numbers.
Current:
'97 E36 M3 Track/Street Silver Coupe
'03 325XI AW Sedan
Prev:
'02 E46 M3 Active Autowerke Stage 3.5 S/C'd IR/IR Coupe
Had a little photoshoot thanks to ///dean
http://forums.bimmerforums.com/forum...ontent-warning
So what's the final verdict on the kit? I'm currently installing mine right now, I'm so excited!
Unfortunately I haven't been able to put in much mileage after resolving some minor problems. I'm @ ~40miles since resetting adaptation and still need to fine tune my eboost settings. Hopefully the Zeitronix I just installed will help instead of trying to eyeball it while driving. I did find out that I have a leaking VANOS unit and was something I forgot to replace "while" it was apart
Boost is FUN!
Care to share what else you're getting installed besides the TT Stg2 kit?
My setup is going to consist of:
New dual mass flywheel (installed)
Southbend stage 3 clutch from Technica (installed)
Shifter detents gears 1-5 and Reverse
New Vanos unit
Heater hoses
New tensioners
AEM digital wideband o2 sensor
AEM digital boost gauge
RallyRoad 52mm gauge pods
New drive belts
Aluminum thermostat housing
Various seals
S54 radiator
The head is getting resurfaced to about 12 RA along with getting new valve stem seals and a valve job.
I'm also planning on running a full exhaust with no cats. Speaking of which, I need to email Nick and tell him that I want to post cat O2 sensors deleted.
I've already removed the head, ran the oil and water lines, installed fuel pump/injectors, and installed the intercooler.
Seems like we have a very similar setup!
Nothing David couldn't handle
During install, car had wrong the MAF connector (OBD1) cuz of my Dinan HFM and a missing M50 throttle body plate.
Post install, it was CELs for missing SAP solenoid and evap purge valve (Took the parts home by mistake..doh!). And CEL 1519 which David fixed.
Really curious as to how much power you're putting down. Any plans on putting it on a dyno?
I'm doing all the work myself, except the exhaust.
I just finished tapping the oil pan a couple of hours ago. I should be getting the head back from the machine shop tomorrow. Planning on having the head installed by the end of the weekend as well as the turbo. The DME is likely the item that i'll be waiting on because I opted for ground shipping with UPS for some reason.
Finally was able to do a baseline dyno@ FFTEC in Hayward.
Mustang dyno
Temp 70
Run#1 @ 12psi 322whp/285tq
Run#3 @ 8psi 288whp/272tq
Nice! That's not too shabby considering it's Mustang dyno and not a Dynojet
More stuff to share..
Some pics @ FFTEC
Inside
Getting strapped down
Dyno#s
Logs from the ZT-2
Nice flat boost curve @ 8psi setting
Not so nice @ 13psi setting
Decided to upgrade to a gtx and add corn juice
