Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 80
Thread: The Official S54 -> E36 Swap FAQ
  1. #51
    Oct 2005
    Lawrenceville, GA!
    Many Broken Ones
    Quote Originally Posted by TerraPhantm View Post
    Alternatively you can run the DME in "E36" mode. The DME will then calculate how much torque the compressor uses instead of depending on the CAN bus for that info.
    AFAIK, The DME controls the AC compressor through the CAN lines in the E46M, it doesnt get the torque values from that.
    460whp/515wtq wifes MMW tuned 335i
  2. #52
    Philadelphia, PA
    2005 M3 & 2004 330i
    Quote Originally Posted by 328iJunkie View Post
    Turns out we're both wrong.
    On the E46, the IHKA module signals the DME to turn on the air conditioning and gives it the torque consumption via the CAN-bus (through the intstrument cluster). The DME is what turns on the compressor, and uses the torque load information to maintain a steady idle. Also, the DME controls the aux fan via a PWM signal based on coolant temperature and the speed the IHKA is requesting (the DME will go with whichever requests the higher speed).
    On the Z3M, there is no IHKA module. So the AC is pretty much wired up like it would be on any other E36. Main difference is that instead of the compressor on signal being sent directly to the DME, it is sent to the cluster (which presumably sends the DME a signal to turn on the compressor to the CAN-bus). The aux fan's high-speed circuit is triggered by the DME.
    So in "E36 mode" the DME figures out the torque consumption on its own, but the part I was missing was the instrument cluster's involvement. So you will still need a module to tell the CAN-bus that the AC button is pressed. If you leave the AC constantly on, I guess one could hardcode the software to think the AC is always requested on.
    Edit: Actually, the signal to turn on the AC is over the K-bus rather than the CAN-bus.
  3. #53
    Little Rock, AR
    07/95 E36 ///M3
    Nice work!
    Now just because I'm lazy and super sleepy...
    How would you wire up for exemple my "standalone managed s54".
    Again, Idle speed and auxil fan are not an issue.
    Z3 m compressor ==> pressure switch
    Current:
    1983 E21 320I ''Trusty stead!'' Ireland engineering suspension, solid strut bar, all stock
    1995 E36 ///M3 ''Could it be love? it is!'' so Much $$$$$ Dumped on this car!
    2002 E39 ///M5 ''Angry little thing!'' dinan tune, dinan diff, supersprint exhaust system overhaul...
    The goners:
    1992 E30 318is slicktop ''Knuckles'' volvo lip, full stock
    1992 E36 320i ''You did good little one'' Full stock
    1988 w124 Mercedes 250d ''Best car ever...EVER!'' Bone stock!
    Whatever you can ''faster'', I can do ''faster''!
  4. #54
    Philadelphia, PA
    2005 M3 & 2004 330i
    Quote Originally Posted by mindstorm00 View Post
    Nice work!
    So you're not using an MSS54 at all? I assume you still have the climate control module?
    I would do something like below
  5. #55
    Little Rock, AR
    07/95 E36 ///M3
    Nah brother!
    I m the black sheep here. For most people doing standalone ems means going for dta, haltec, aem. Not this guy right here!
    I'm using a specialist component uk management system
    Let me get out there to the shop here in a few and i ll take some pictures.
    Snd btw heath works, climate module and controls are still in place. I just never did put the ac comp on the car for 2 reasons.
    1- I was too happy the car was runing
    2- had to do a lot of road tuning and the ac was not a priority.
    Current:
    The goners:
  6. #56
    Philadelphia, PA
    2005 M3 & 2004 330i
    Well in any case I'd wire it like I show above. Unlike a stock setup, the AC won't turn off in full load operation.
  7. #57
    Little Rock, AR
    07/95 E36 ///M3
    E36 compressor with smaller belt. Or z3m ac comp in your opinion...
    Having rhe ac comp on non stop still wouldn't be as bad as burning up inside a black m3 with black interior... deleted heat reflectors "shield" ... it s not as bad as i make it sound jk
    Current:
    The goners:
  8. #58
    Jun 2002
    Burlington, Wa
    96 M3
    Do you need to swap in the s54 fuel pump (or does s52 pump work)? Does the s54 have a separate fuel pressure regulator?
  9. #59
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by cheades View Post
    Use the S54 pump, it fits in the e36 carrier. You need to use the S54 regulator and fuel filter as well.
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  10. #60
    May 2009
    Orangeville, On, canada
    1998 M3, 2001 530i
    I think this power steering hose http://www.realoem.com/bmw/enUS/show...27#32411093461 should work it has the right end for the PS pump
  11. #61
    Aug 2008
    fairfax,va
    E36 M3 TV/ E36 M3 CB
    If anyone is interested, im selling my complete s54 e36 swap with all brand new parts here. Includes trans, complete engine, accessories, etc.
    https://www.bimmerforums.com/forum/s...in-parts-6-750
  12. #62
    Dec 2010
    Santa Barbara, CA
    '90 325i: S54 6 Speed 5
    For anyone that wants the coding for free, or further info, TunerPro XDFs are here along with directions and youtube vid:
    https://github.com/saildot4k/MSS54-XDFs/
    For AC, user GPeterson made an AC Controller:
    https://www.bimmerforums.com/forum/s...proper-CEL-A-C
    '90 325i: S52+C&S chip, 5 Lug, ZF320, 2.93 LSD
    RIP: '88 325is: M50B25TU+M3 Cam+Turner Chip, ZF320+ 2.93 LSD
  13. #63
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Quote Originally Posted by R3Z3N View Post
    Don't buy Garry's POS can controller it doesn't work.
  14. #64
    Dec 2010
    Santa Barbara, CA
    Mine works fine. Elaborate?
  15. #65
    Jul 2003
    Texas
    1997 M3/4/A
    Does your aux fan run continuously when the engine is running?
  16. #66
    UT
    98 M3/4/5
    they were built with no heat sink and over heat at some point, causing a failure, and his box also allows the SES light and you wont know if you throw a code. best bet is to get an 01-04 Z3 cluster and have it repinned to the E36 plug, easy to do, user busterhaux makes them.
    98 Estoril ///M3 4/6
    S54 swap CSL
  17. #67
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Hey party people, who is flashing MSS54HP DMEs these days for swaps?
    Thought I would ask here before I just LMGTFY
  18. #68
    Jul 2003
    Texas
    1997 M3/4/A
    Quote Originally Posted by golgo13 View Post
    Contact matt(pittsm3rr) he has a build page here. Bad ass man, 24hr support and all, very knowledgeable with these swaps
  19. #69
    Northern CA
    1998 M3/4/5
    I do them for $50, preferably remote, but you can mail it as well.
  20. #70
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Quote Originally Posted by brokeazz View Post
    I'll keep him in mind, thanks!
    Quote Originally Posted by gpeterson View Post
    Support for A/C, Cruise Control, CEL and removal of non-essential DME items as part of the swap? This would be with busterhax Z3M CAN cluster.
  21. #71
    Northern CA
    1998 M3/4/5
    Yes. Note that cruise has nothing to do with CAN, other than an optional visual indicator for cruise off/on.
    For anyone that does the Z3 CAN cluster - I documented the pinout differences and made notes on what you need to do:
    https://docs.google.com/spreadsheets...it?usp=sharing
    If you need odometer correction on a used cluster I can help with that as well.
  22. #72
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    All great stuff here!
    Is it possible to run two different tunes and switch between them on the fly?
    I'm considering a race tune where the smog equipment isn't used or is disabled via the DME and exhaust headers lacking catalytic converters are present for increased power
    and
    a SMOG tune whereby all the O2 sensors, EGT probe and SAP is used by the car to pass emissions
    Would this require having two different DMEs and physically swapping them in and out with the exhaust parts?
    I know with the Evo I had you could flash in two maps and switch between them by holding down the throttle when turning the ignition on.
  23. #73
    louisville ky
    What do people do to retain ABS communication to the OBDII plug?
  24. #74
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Quote Originally Posted by Yahweh View Post
    If you are using the ABS harness from 3dm Motorsport, it has its own OBDII port you would plug into.
    https://3dmmotorsport.com/collection...ness-basic-kit
    This is the harness I’m interested in using for this swap as well.
  25. #75
    louisville ky
    I’m looking to communicate to the factory E36 ABS from the OBDII plug.
    I’ve had no luck with stock E36 ABS, MK60 systems communicate flawlessly though.
