Bump,
Jack, how have you been liking your kit and do you wanna share bracket dimensions?
cheers
As I stated before, communicate well and often, especially when the news is not going to be pleasant.
good thing i found this thread, it's interesting to find out about used parts on other cars being used as upgrades.....mostly because cheapern
this hodge podge kit using 17z and 18z stuff is really cool but...
not sure if this 993 kit has been mentioned here yet?
it's cheaper for the whole thing i believe, but the downside being 4 piston fronts and the rears require a lot of work, including fab work and grinding down brackets and stuff
http://www.zeckhausen.com/e39_bmw_rear_install.htm
Looking for an e39 Touring black carpet set, including the rear cargo cubbies and side sections!
ALSO looking for 540i 6speed manual transmission sets (2001+ pedals with switches, driveshaft, gearbox), for the 6speed swap! Probably not for a while....
GN92489
540i msport touring; jet black on grey
Progress Thread (general)
Progress thread (touring specific)
I know this thread is old but could we get an update or dimensions on the adapter bracket for the front brakes?
Heads up all: I bought Stuck's 18Z BBK for my wagon but I am going to try another front set up that will clear 18" M5 wheels. If anyone is interested in the 18z kit, let me know, its 1-off! They fit under M-pars and other 18s but NOT style 65s.
The kit accepts e92 M3 360x30 rotors which I will have a brand new set to sell with the kit if anyone is interested. PM ME
To fit inside Style 65's do you need a spacer?
I see.
I'm guessing the 19" 65's will probably fit.
OK fair enough RSB do you happen to know where the brackets are available as I'd like to get a set I will source the calipers over here as air freight and customs makes it expensive buying from USA.
Sent from my SM-G920F using Tapatalk
1999 540 Auto with Eaton M112 supercharger
Airlift 3H/P management, M5 steering box, M5 LSD, Eibach/Dinan front and rear anti roll bars, PM Modifich door boards, 4 Eton 6.5s, Sound Magus VS3500.1, 2 x 10" Kove audio subs, Alpine ICS X7 Headunit, 19" BBS Hammer Sports RT245/RT246, Muffler delete, electric coolant fan.
Greetings...
I know this thread is dated but it is the main source of the inspiration for this upgrade\project for the 530i so I hope you guys are still around...
My parts list is below and I was wondering what you guys thought and if I am missing anything?
Rotors:
https://www.fcpeuro.com/products/bmw-brake-disc-front-left-1-series-m-m3-34112283801z
https://www.fcpeuro.com/products/bmw...3-34112283802z
Pads:
https://www.fcpeuro.com/products/vw-...reg-7l0698151s
Calipers:
2005 Porsche Cayenne (17z)
Needed:
Brackets to mount the calipers
Brake lines? I have some stainless steel lines from FCPEuro sitting around, any issues with using them?
No idea, but I like your style If you do figure it out, let us know!
Nate J.
(oOO\ (|||)º(|||) /OOo)
(eŌō\ (||||)º(||||) / ōŌe)
There is a brake bias chart with caliper type and rotor size that might help, not E39 specific but should be close enough.
https://thebuildjournal.com/tech-gui...-chart-e46-m3/
Developing brackets for lugged calipers can be a challenge because of limited space and mounting distance of the caliper from the knuckle. Additional issues may arise when the new calipers have a lug spacing that is close to the spacing of the OEM mounting points. This makes radially mounted calipers much easier to adapt (big reds or similar).
I haven't taken the time to measure the stock mounting points of my e39 yet but I'm contemplating doing so and running off some test brackets on my cnc.
1999 S62 Powered 540i
2009 N54 335xi
I'm very interested in a front kit and/or a bracket too!
So my current road block is getting a CAD design or such for the brackets and a fabricator willing to make them.
So far the issue for the companies I have communicated with seems to be the limited quantity being requested.
Also, I have not received any positive responses from my follow up questions regarding at what quantity does it make sense for them to do it...
