Results 1 to 25 of 25
Thread: Warm up regulator 1979 320i
    Apr 2014
    Anyone know how to test this to see if it is working correctly?
    Jan 2013
    Ontario Canada
    1977 320i
    Cis fuel pressure tester. What's wrong with your car?
    Apr 2014
    Very hard to start but once it's running it runs great even tho the idle seems a little high
    monterey, ca.
    e21, e30 m3. e46 330ci
    hard cold start or warm?
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    14 f800gsa - red headed stepchild!
    Apr 2014
    new york
    2012 bmw x5
    Apr 2014
    Cold start, once warmed up it is good
    Jan 2013
    Ontario Canada
    1977 320i
    Yeah it's possibly a
    dirty screen in the WUR.
    monterey, ca.
    ^ most likely.
    it's the WUR's job to enrichen the fuel mixture needed for cold running and it does so by bleeding off some of the gas pressure of the operating system. except for the intake screen getting dirty there's not much to go wrong with them, but if the screen is dirty and gas does not flow it will not like starting from cold.
    remove the WUR and soak the screen with some carb cleaner.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    Apr 2014
    Tom, I am getting fuel from the return like on the cold start injector. I have not tested the injector, do they work in conjunction? I am new to this fuel injection stuff
    monterey, ca.
    there is a 5th injector that gives a quick squirt of fuel at start up but doesn't have enough duration to warm up an engine, that task falls on the WUR.
    the fuel pump supplies more then enough fuel to run the system and so the excess to dumped back into the tank. the WUR takes the already pressurized gas that's in the fuel distributor and bleeds off some of the pressure, that gas is also dumped back into the tank.
    there are three different fuel circuits, system, control and the cold start injector.
    the system runs the car and operates at about 75psi.
    the control runs the cold/warm up and runs at about 60psi plus. it does so by bleeding off the pressure of the system. as the engine warms the port in the WUR gets smaller and smaller and the pressure goes up and up until the port actually closes and the system pressure takes over.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    Nov 2005
    Mills River, NC
    '82 E21 320i
    Control pressure specifications.
    The graph depicts control pressure as it relates to engine temp.
    Eric P.
    Apr 2014
    Well I guess I will try and find this screen for the WUR and let you guys know how I make out, I have been tempted to just put an I take and carb on it
    Apr 2014
    Seems to be the cold start injector was bad so after I change that I will let everyone know if I still have a problem and see where to go from there thanks again for the help
    monterey, ca.
    BM, start with the WUR, that's where your problem is.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    Apr 2014
    Ok, had the cold start injector cleaned and check it is NOT getting any signal( power ) to open when the key is on or when cranking it. I got 7.2 volts on the power terminal and nothing from either terminal that goes to the WUR. Ok I am stumped once again.
    Apr 2014
    Ok change the cold start injector after having it cleaned and checked. Getting 7.2 volts at the time switch but nothing from the WUR at all, ok I am stumped once again
    monterey, ca.
    power, or lack of it to the WUR is not the problem.
    the WUR is mounted directly to the engine block and therefore is heated and cooled by the block itself. here's how it works
    engine block/WUR are cold and the pressure bleed off valve inside the WUR is open. as I explained above, by bleeding off some of the fuel's operating pressure the injectors will run rich for warm up operation. as the engine, block and WUR warm up the WUR's valve is slowly closed and the fuel's operating pressure is raise back up to 75psi. that's it, simple as that. so what's happening most likely in your case is the screen in the WUR is clogged and not allowing the pressure to pass through and by doing so lower the system pressure, you must remove the lines and soak the screen with carb cleaner.
    okay now for the electrical. the power going to the WUR is a timed thermo switch. it works by laminating two thin metal strips back to back made from different alloys. when you heat the bi-metal strip it will expand, but because not all metals expand at the same rate the strip will bend to one side. this strip will push on the valve as it bends and close the WUR's valve.
    so now put it all together. the engine is cold and the WUR's valve is open. you start the car and immediately the system' pressure is dropped, the fuel runs rich, the bi-metal strip recieves power and starts to heat up eventually closing the WUR's valve before the WUR itself actually fully warms, this was done for emission reasons.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    Nov 2005
    Mills River, NC
    '82 E21 320i
    Another important point:
    The cold start injector is controlled by the thermal/time switch on the coolant neck.
    That system is completely independent from the WUR.
    The WUR also receives power to the bimetallic strip per Tom's description so that control pressure is increased at a prescribed rate rather than rely on the atmospheric conditions along side the block.
    HTH.
    Eric P.
    Apr 2014
    If the screen is clog and this problem is still there is there any where that rebuilds the WUR or is it a do it your self thing?
    monterey, ca.
    there is an outline in the FAQ/DIY section above.
    one more thing. the screen doesn't get clogged by crap in the gasoline so don't be looking for a black and dirty mess, but rather from the gas turning to varnish which is invisible to the eye.
    just because it looks clean doesn't mean it's passing fuel.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    Apr 2014
    I can't find the FAQ/DIY. Section on the app, what a day
    Apr 2014
    Lol never mind blonde moment
    Apr 2014
    Is there any voltage reading off the connector that plugs in to the WUR? Mine is nothing, just wondering
    Jun 2012
    Brewer,ME,USA
    1979 BMW 320i
    Quote Originally Posted by Tom D View Post
    Old thread alert. My '79 320i is experiencing the same cold start symptoms. In addition to the difficult starting, once the engine eventually runs I have to apply enough throttle (around 2K rpm), to keep the engine running. Also, there is a large cloud of white smoke coming out of the exhaust and goes away once the engine is warmed up a bit. I have tested the cold start and that seems to be fine. Thanks Tom D for the diagnosis. I just put the car in storage for the winter, so it will be Spring before I have a chance to remove and clean the WUR. I appreciate the info.
    David
    1979 320i 134k miles
    Dec 2015
    Phoenixville, PA
    1987 BMW 535is
    Having first hand experience back in the day with an e21 and the notoriously finicky WUR, it needed to be tested with an inline pressure guage setup (custom made) and adjusted to obtain a good cold start mixture. It is a quasi adjustment that is more trial and error. Maybe a new WUR is an option. All things considered the associated temp sensors are also suspect and easier to deal with.
    Good car with a few quirks. The e10 was such a simple and easy car to maintain - but that seems to be the way we look back on prior BMW series, isn't it?
    Sent from my XT1635-01 using Tapatalk
