I recently ordered a set of 17x8.5 comps and I need to know if I need to run a spacer. I tried to test fit the wheel, and it will clear the strut w/o a tire on it. I'm afraid that with a tire on it, it will rub. (Oh, I'm using a 235/40/17 SO-3).
Do any of you know if it wil fit? I just want to make sure before I pay for spacers. Thanks
Find the Offset. I'm able to do 255/35/18s on 18x8.5 ET 38. You should be able to do the same with 17x8.5 ET 38 and 255/40/17s if you wanted. Offset is key here, and if you have fenders rolled, more clearance...
Charlie.
Engine & Driveline: ICS Stage 4 SC * 8 Rib * 15+psi * xx# injectors * Schrick Cams * Larger HFM * Port & Polished Head * 3 Angle Valve Job * VAC MLS .140 HG * E36TD Fan Setup * Shorty Headers * Track Pipe * UUC UDPs * S54 Oil Cooler * OEM S54 Radiator * S54 Guibo * Stromung Exhaust * ACS Delete * UUC SSK * Rouge WSR * UUC TME
Chasis Tuning: GC COs * UUC Sways * X-Brace * Rouge RSM * GC RTAB * AA DSB * Z3 Steering Rack * BBS RC 18x8.5 ET38/ 255/35/18s @ all 4* Front Strut Brace * RaceLogic * 3.38 LSD
Exterior: DEEP BLACK PAINT * Rolled Fenders * Custom Vented Hood * RD Diffuser * Red DDEs * 8,000K HIDs * Smoked Markers
Coming Soon: Finish ICE * 6-sp Trans * 6 Pot 13.6 Fr, 4 Pot 12.9 Rr BBK
4 Sale: M3 S52 Cams * M3 Rear Seats * 99 M3 Fan&Clutch, Intake Manifold, Headers * Alum Therm Housing * 42# Injectors * Dresmann Rear Kit * Tilton/ICS Flywheel & Clutch * LED, Smoked & OEM Taillights * & More
Wheels & Tires: Custom 18x8.5 BBS RCs * 3 17x8 Grey OZ Superleggeras * RD RGS 17x8
Oh yeah, offset is ET 44
sounds like a 5mm or 8mm spacer might be in order...
I'm pretty much dropped in the front...so you might be better of, however I do have a decent fender roll.
I just ordered a 10mm spacer, I guess the fenders will be ok?
If you are only doing a 235, then who knows, otherwise I deff know a 255 would need a fenderroll.
I think I'll be ok with a 235 S-03. Anyone know?
