Results 1 to 25 of 54
Thread: F/I engine oil weight choice?
    Elkridge, MD
    11 X3 35i M
    I don't want to get into a discussion of oil brands. What oil weight are you using in your forced induction engine?
    I have an E36 M3 with stage II AA Twinscrew supercharger daily driver, no track time. I am thinking either 0w-40 or 5w-50...the 0w-40 is what is recommended for the stock engine, is that sufficient or should a F/I engine use different weight oil than a N/A engine?
    Looking forward to what others have to say.
    Sent from my DROID4 using Tapatalk
    Current: 2011 X3 35i M-Sport, Deep Sea Blue Metallic, Oyster Napa interior, Afe intake, RaceChip Ultimate.
    Past: 1998 M3 sedan, Cosmos Schwartz Metallic, Black interior, Euro 6-speed, AA Stage II TwinScrew supercharger, and a bunch of other mods.
    Manchester, N.H.
    96 332IS 6466 turbo
    M1 0-40 euro spec
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Sep 2008
    Toronto, ON
    6465 328ti
    Quote Originally Posted by Butters Stoch View Post
    M1 0-40 euro spec
    Aka the unicorn tesrs oil. Down there do you guys have bigger than the qt bottles there in stores?
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by e30kid89 View Post
    We can get 5qt jugs. I think even walmart carries it.
    1996 332IS
    Built 3.2
    m3mods's Avatar
    m3mods is offline Boost Addict BMW CCA Member
    Sep 2011
    AC Schnitzer S3 CLS
    How many miles are on your motor and what are the current temps (highs and lows)?
    Ambient temps that is..
    Jan 2006
    Mechanicsburg, PA
    yes
    40w under 40deg. 50 over it. Adjust your lower number to your average LOWEST temp. In EC, MD, I'd run 10-40 in winter/late fall, 15-50 late spring/early fall. Just take it easy until the oil warms up....thoroughly.
    Don
    m3mods's Avatar
    Sep 2011
    AC Schnitzer S3 CLS
    Quote Originally Posted by dcvee View Post
    Don
    That's about what I was going to recommend as well unless it is a fully rebuilt from the ground up motor (which I am assuming its not) in which case I would go with a bit lighter weight.
    A house
    '86 325e, '14 VW EPA
    I would go with the lightest weight oil that gets you good oil pressure under your operating conditions.
    Feb 2013
    missouri
    e28 m52, 240sx m106
    Liqui Moly 10w-60
    Toronto, Canada
    E36 Turbo
    Liqui 5W-40 here... been using it on all my cars for the better part of 10 years now
    M3
    m1 15w50 for summer
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    If you are running a proper thermostat controlled oil cooler, the ambient temp should not play a significant role in choosing the hot weight. But since I don't have a cooler, I've been running Liquimoly 10W60.
    /.randy
    Saskatoon, SK, Canada
    m3, gtr
    0w-delicious
    bacon fat oil
    Feb 2008
    Sacramento CA, USA
    turbo m3, Z4M, M5,
    Another Liqui Moly 10w-60 here..
    the lighter weights oil's just don't seem to cut it.
    Nanaimo, B.C., Canada
    EuroS50B30,e83,Frontier
    Quote Originally Posted by Inicent Child View Post
    Maybe not in hot Cali, but here in Canada we might want to choose a lighter weight oil like 5-40 or 0-40..
    "There are bold drivers and there are old drivers, but there are no bold, old drivers."
    Toronto, Canada
    E36 Turbo
    How did you come to that conclusion?
    Apr 2009
    norcal
    a few e30s
    Quote Originally Posted by NOTORIOUS VR View Post
    Same way he came to the spelling of innocent.
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    I run 5w40 rotella t6
    Suffolk, Virginia
    35D X5, 335d
    Quote Originally Posted by E36 HateR View Post
    I run T6 in just about everything.
    OLD
    E30
    636whp
    1/4 mile: 10.91@144.38
    http://www.youtube.com/watch?v=L_f7fUVqblI
    NEW BUILD
    335d
    520whp
    635wtq
    120.51mph trap speed
    Dec 2007
    Great Dismal Swamp
    Randy: really, no oil cooler? I'll hook you up with an adapter if you want to go with the S-54 filter housing.
    Nope, no cooler as yet. The way my car gets used, the bigger problem is cold oil. By the time it's up to temp, I'm at my destination. And the bit of hooning it does see is short bursts. For *my* usage, I"ve been watching for an OE oil->water cooler I can adapt to my appllcation.
    /.randy
    Elkridge, MD
    11 X3 35i M
    Thanks for the advice all. I am going to go with M1 0w-40 euro spec for this oil change and see how it does. Will update if it doesnt work out.
    Toronto, Canada
    E36 Turbo
    Quote Originally Posted by najnad View Post
    You will be fine, M1 0W-40 is good oil with a great additive pack.
    Nov 2011
    Hillingdon
    E36 325i
    10-60 here in UK conditions
    Nov 2008
    nnj
    Vipers, Radical SR3
    Do you run a cooler too? Do you have an oil temp gauge?
    Toronto, Canada
    E36 Turbo
    Quote Originally Posted by B3 DRIFT View Post
    Isn't that a little thick for cool and rainy? :P
