Decided to change things up I'll a bit and go top mount twin scroll
the manifold is from goodntight, or as most of you know him Otis.
i believe that after the 650-700hp mark the open scroll boost logic was really hurting performance .
when more funds are available I'll throw on a the 42 style 7675 to take full advantage of the twin scroll
but until then I'll stick with the open housing 7675
this is the last manifold for the e36 to have been made by Otis so soak it up.
World record holder for a m52 stock bottom end.
9.41@153 c4 auto 28" et streets, e34 3.64 gearset 900+hp
E36 chassis irs world record holder 8.49@162
Th400, e85, 7685, m50 intake 26.6 lbs of boost
Nice!!!!
But, what? So, he's not going to make anymore e36 manifolds? I've always wanted one if his pieces of art.
This is my signature....
Yeah from what he said , hauled off the e36 he used for mock up.
Nice mani!!! What's Otis doing now?
It would be awesome if he could do one on the n54 platform
Sent from my S4 using BF.com
Damn straight, good times.
Cam if your reading this I have your vbox. Email me your address--> panayiotisx2@gmail.com
See ya Bimmerforums...!! I'm out...!!!!!
My manifolds powering 8sec and over 1000rwp cars
Home of the highest HP stock M30 in the world 550rwhp/622rwtq
1/4 mile---> 9.81 @138 C4 Auto
10.08 in car vid --->https://youtu.be/OiinFhUomjg
Dyno vid... http://www.youtube.com/watch?v=C7aM7..._order&list=UL
Congrats man, I can sense this chapter of my life closing as well.
That is a lot of plumbing. Wedging it all in is going to be a trick. All that emissions, ac, windshield washer fluid, HID stuff will have to go on a shelf.
97 BMW M3 (s52b32) - VF-Supercharger kit ( Vortech V2-SQ supercharger, 32 pound injectors, VF tuning ), VDO/LeatherZ Gauge Kit (Oil Temp, Oil Pressure, and Boost), UUC Motorwerks RSC36 Exhaust, Stainless Steel 6-2 Exhaust Headers, Bilstein Sports, Rear Adjustable Camber bushings, Wheel Spacers 10mm in front 25mm in back, Uprated Clutch, UUC Shift Knob, Short Shifter and Clutch Stop, Cross Brace, Mason Engineering front strut bar, Contour Wheels, Euro Ellipsoid (Angel Eyes) HID Headlights, braided steel brake lines, aluminum thermostat housing, mishimoto aluminum radiator and silicone hoses and a partridge in a pear tree
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
NICE! Happy to see you are sticking with F/I, make some powaa, once again thanks for the boostlogic manifold, love it!
Dream big, work hard, and let what you love, be what you do.
Best in Arizona, Certified Master Technitions, Founded in 1992 and family owned since.
http://ultimateautoworks.com/
awesome dude! cant wait for that 150mph trap and can you please please get some supra kills on camera!!
Powertrain: Big Bore 87mm S50| Boost Logic Gen 2 Mani | BorgWarner S366 | CP 8.5:1 pistons | Eagle Rods | O-Ringed block | Tial 50mm | Precision 46mm | LINK G4 standalone | ZF| F1 stage 3 clutch/15lb ltwfw| UUC Black TM/E| Vorshlag MM's | 3.23LSD w/AKG race bushings| AKG race subframe bushings| 'Bear Motorsports' Re-enforced subframe | Walbro 525lp fp| VPD pulleys| 4'' DP into 3.5 straight pipe"||
Handling: FK konigsports| '95 M3 strut mounts| Rogue Engineering RSM's| UUC RTAB's| 20mm front spacers| 2915lbs Full interior
Aesthetics: M3 bumpers| 18''x 8.5/9.5 BBS LMs| ZKW's| 50w 6000k HID| Smoked Corners| 50% wndshld/5% all around| M3 sedan seats F&R| Black headliner| Black/Grey suede door panels| ZHP knob| M3 steering Wheel|
made some more progress over the past few weekends, all it needs is oil anc coolant and i will fire it up tomorrow.
3.5 in pown pipe with v band by the header to easy removal
15x9 rims for traction
i also picked up some shrick sport cams 264/256 that i will install when i pull the s52cams to re torque the 11mm l19s after somem heat cycles.
The go parts looking good; but no rear brakes?
WOT
Ok, I was wondering just "how crazy" you were haha. Won't you have to throw on a smaller rotor to fit 15" wheels. I've see guys grind to fit 16's but 15 with a M3 rotor?
WOT
I had to grind off a lot , I could run a smaller rotor but the caliper is what diktats fittment and I even thought about running smaller calipers but the size differance it not too much. The mounting of the caliper plays a big role
Looking good!
