Results 1 to 25 of 52
Thread: My E39 LSx Turbo Swap
    Australia
    E46 M3 Turbo
    So just picked this up Friday last week. Got it very cheap off ebay.
    Idea of this one is a daily cruiser so will be auto. I've got a RHS block, brodix headed 427ci getting built for it at the moment. 9.2:1 comp and thinking a couple of T04Z's would come on nice and early and still make 800-1000rwhp through the auto.
    Already got the M5 bodykit and mirrors here. Everything is going to be fixed up as new. M5 diff and shafts are on the way. KW Coilovers are in the post. New wheels went on Monday. Now have 10" rears. Stereo is getting done tomorrow.
    Naperville, IL
    1998 540i
    Sounds like a great plan.
    Rob
    Prior projects:
    1998 540i with 6.6 LS2/T56 Chevy Power
    - pictures and details
    1992 325i with 6.6 LS2/T56 Chevy power - pictures and details
    1995 M3 with 6.6 LS2/T56 Chevy power - pictures and details
    VA
    E63AMG/Z31/Tacoma/F31
    I like 427 ci and turbo.
    May 2010
    Salem, OR
    2000 BMW 528
    Very cool! I'm jealous of all these turbo builds, I want twins.
    Buffalo, NY
    2001 BMW 540i/6
    what trans are you going to be using? I take it this was originally a 6 cyl car?
    In for Australian hooning
    2001 BMW 560i 6.0 LSx/T56 SOLD
    2000 Corvette Hardtop FRC
    M5Hunter is offline Still has a E39 Supporting Vendor
    Nov 2009
    Hanover, VA
    E39
    Should be a stout combo! Looking forward to seeing the turbo setup.
    Australia
    E46 M3 Turbo
    Quote Originally Posted by nsogiba View Post
    Just going to use a T400
    Australia
    E46 M3 Turbo
    OK stereo install is done Yes I was listening to some old school music. Boost controller install done.
    Replaced the destroyed door sills.
    M5 diff and half shafts turned up along with all new control arms. But still waiting lots of parts to turn up.
    Oh got the windows tinted too so it's less like a fish bowl.
    Australia
    E46 M3 Turbo
    Spent the afternoon vinyl wrapping to get rid of the dreaded wooden grain.
    Australia
    E46 M3 Turbo
    Modified the fuel pump holder to fit a Walbro 255. It fits great. Even with the filter on it there is just enough room if you face it the right way. This will feed the surge tank in the spare wheel well.
    KW V1's installed along with front strut tops for camber adjustment. Also all new suspension arms so new bushes throughout. Rides really nicely now.
    So waiting on a block still for the engine build RHS still don't have any in stock.
    Waiting on Airbag for my M5 steering wheel so I can install that.
    Waiting on AP Racing BBK
    Waiting on my gearbox
    I hate waiting for things. I'm thinking I might send the car in for the re-spray so I can put the M5 body kit on etc. Maybe I'll just wait till after the engine conversion just in case I scratch something.
    Nov 2009
    Hanover, VA
    E39
    Single 255 pump for a twin turbo 427?
    May 2010
    Salem, OR
    2000 BMW 528
    Quote Originally Posted by M5Hunter View Post
    255 to a surge tank, that I'm assuming has dual 044s. Kinda like running inline boostapump.
    Nov 2009
    Hanover, VA
    E39
    I would still want more pump to the surge tank, but thats me
    May 2010
    Salem, OR
    2000 BMW 528
    I agree. Walbro 400 retrofit!
    VA
    +1 on more pump. Clay and I are using the Aeromotive 340 IIRC. I would want 2 for twin turbo 427.
    Feb 2008
    Upstate
    2 Boosted,1 more left to
    Quote Originally Posted by Jesus Freak View Post
    Thats what I did but not too sure of that 255 to surge tank.
    E39 LSX SWAP PARTS FORSALE
    Australia
    E46 M3 Turbo
    I already use a 255 in tank to surge tank in another car with an LS making over 1000rwhp with no fuel problems on e85. You have to remember a 255 at zero pressure flows a lot more than 255lph. Pumps to the engine I will be running twin pierburg pumps.
    Australia
    E46 M3 Turbo
    Spent the weekend fixing the vapour seals on all doors to stop the car turning into a pool. What a bad design BMW. That's no vapour seal its a water seal.
    Nov 2009
    Hanover, VA
    E39
    I have to do that too. Considered drilling drains in the bottom of the doors.
    Elizabethtown, PA
    99 540i6
    Quote Originally Posted by 02PRUV View Post
    How do you know that you have this problem? I've heard of it plenty of times, but not sure how to know that you've got a problem.
    '99 BMW 540i6 L33 5.3, PRC Heads, E-force supercharged
    http://forums.bimmerforums.com/forum....php?t=1674320
    Australia
    E46 M3 Turbo
    Carpet was wet was the first I knew. Googled wet carpet E39 found heaps about it. Opened a door and poured a bottle of water down the outer side of the glass and watched the water flow down between the bottle of the door trim and the inner door skin instead of just out the bottom of the door. All doors had the problem. Rear doors were worse amount of water but all did it.
    Australia
    E46 M3 Turbo
    Intercooler fitted. Twin entry single exit for twin turbo setup
    M5 Front bumper fitted as well
    M5 Rear bumper fitted. Now just need to cut the spare wheel tub for the RH exhaust.
    Australia
    E46 M3 Turbo
    Finally got the car back from the painters. Still not finished. They still need to do bars and moulds but at least I can start fitting all the other parts I need to before doing the engine conversion. A quick install Friday night:
    Aug 2013
    Sydney
    01 E39 530i,05 E53 4.8IS
    Looking good!
    01 E39 530i - SOLD !
    05 E53 4.8is
    Pics of Bianca (E39) and Betsy (E53)
    Australia
    E46 M3 Turbo
    Smashed some progress today. Took myself and a mate from 8am to 1:30pm to get the stock driveline stripped and converted to M5 Diff and LS with turbo 400. It's all mounted and ready to get turbo manifolds and exhaust done over the next few weeks.
    We are using a factory F Body sump so had to remove the swaybar for clearance. Going to get a custom swaybar made up to fit behind the sump.
