Hi folks,
does anyone know a source for the thermostat installed in the 850CSi oil filter housing?
I'd like to fit an oil cooler to a non CSi and modify the oil filter housing but the thermostat is NA as a separate spare part.
BMW wants me to purchase the entire unit which I'd like to avoid.
Sounds ambitious.
Housing needs to grow a pair, complete with passage ways.
Plenty of external easies.
{pics corrected per Wokke post below}
Expect 27mm threads on that thermostat (probably, not).
Sits on the line from the oil radiator, thus bypassing the filter, thus creating the pressure drop needed to detour.
Deep dark special tool required for install/remove, so I can't examine any further. Unless I fab'd a tool.
Hey Hyper,
thanks a lot for your reply.
The standard housing you are showing is an E38/M73 oil filter housing - at least over here in our area.
The standard M70 housing looks like the one you're showing on the right side whereas it actually doesn't have the cooler ports.
The upper one is prepared for the cooler hose but the lower one has no thread nor is it drilled through. But changing that is no major issue for a machine shop.
The thermostat is actually located inside the port underneath the pressure switch. IMO the arrows on your picture are the wrong way around.
Both ports are also marked V (=Vorlauf=feeder) and R (=Rücklauf=return). This V-port also needs to be machined for the OEM thermostat but also this is possible.
What you call a thermo valve in the third picture has IMO nothing to do with temperature. This valve is open if no filter is installed and allowing the oil in the filter housing to be drained through the tube which is connected directly to the oil sump. It closes once a filter is inserted making sure that the housing is always filled with oil even with the engine/oil pump not running.
Cheers
Wolf
Hi,
quick question. my filter housing doesnt have that metal tower.. i know the newer models have a plastic tower. is it normal for my filter housing not to have that metal tower? production date of my car is 12/92
1993 e31 850ci Diamond Black
1996 Mitsubishi 3000gt VR4 Pearl green
1997 Mitsubishi Pajero LS Intercooler Grey
1993 Nissan z32 300zx Twin Turbo Pearl White
1991 Nissan Sentra GXE (Sedan) Pearl blue
Your opinion is good. Original pic corrected.
Reminds me of being caught out over OT as found on a harmonic balancer.
The housing shown is the late version, available to the e31 M60/62/73 in the gulf option, versus the earlier style shared with the e32.
This particular one was pulled a couple years back from a race team in europe, if you can consider UK part of europe.
There is no other valve on this example but it may have been messed with by the race team.
The actual temp valve is a wax actuator inside the return (left) hole on this pic, complete with a spring and circlip. problem is the valve is missing in this pic.. My 91 M70 has hot-climate option and it comes with the oil cooler and the same filter housing as in this picture. I have recently took the whole thing apart for restoration so I'm dead certain of that.
Wokke I cant remember off the top of my head but I don't remember the actuator having any manufacturer marking on it, except the number 85 which is probably the temperature. You'll also need the plastic sleeve around it which is actually the valve. Again there's no marking on it that I can remember. the spring and circlip are easy.
I'll be with the car in a couple of weeks and will check again for you as the filter is still empty and out of the car. In any case I think your best bet is to get a filter from a hot climate car. Think SE Asia, Gulf and Australia. I would look for you but all the older cars in HK junkyards are exported to ME and Africa, and Aussies generally charge 2-3x because the cars cost 2-3x to start with because of the tax man, still, pretty sure I can get this in Australia. PM me if you need it.
Below the picture of the entire thermostat assembly. It indeed has no manufacturer marking and the number on it doesn't help either. I tried various brands (Behr etc.) in combination with this number but no luck.
I did find a very similar looking actuator offered by Sandtler Motorsport and ordered it to check if it might fit. The plastic sleeve would have to be manufactured, spring and circlip are as you say not a major issue.
The non oil cooler housing needs some machining in the R port because the circlip groove isn't existing and the step the sleeve sits on is much higher so it has to be drilled. Again possible.
IF I find an actuator that fits the rest should be nothing major. But it barely makes sense for just a single housing considering that time is money as well.
I am interested in installing an engine oil cooler on my '91. Does the 'engine oil filter housing with oil cooler connections' 11427511171 used on the 740i, 750i, and 840i have the thermostat already installed? Seems like an easy enough installation to change out filter housing, add a cooler, and hoses to complete assembly. I have a cooler already that came out of a 7 series. Thanks,
AFAIK there is no thermostat in the reservoir, just the extra connections.
My BMW Repair YouTube Channel
The easy access oil filter is mounted on the left inner fender. Features include large diameter hoses to insure ample oil flow and an anti-drain back valve. Thermostatic oil cooler control is located in the lower section. At a temperature threshold of 95°C, engine oil is directed to the external oil cooler for additional heat dissipation.
see page 10, 11, 12 http://bmwe32.masscom.net/sean750/M70info.pdf
1 Oil pan
2 Oil intake, primary oil pump
3 Primary oil pump with relief valve (4 bar, activation via filtered oil pressure)
4 Oil filter (filter cartridge bypass valve-2.2 bar, one-way check valve, oil pressure switch, oil cooler valve-activated at 95° C)
5 Filtered oil, main gallery
6 Crankshaft main bearings
7 Connecting rod bearings
8 Piston pins (oil spray)
9 Cylinder wall surfaces (oil spray)
10 Oil feed bores in crankcase (cylinders 1 - 6 and 7 - 12)
11 Oil feed bores in cylinder heads
12 Oil gallery
13 Oil spray pipes for cam lobe lubrication
14 Camshaft bearings
15 Hydraulic tappets
16 Timing chain lubrication (oil splash)
17 Rocker arm thrust (guide) pads (oil splash)
18 Oil supply for hydraulically-damped chain tensioner
19 Oil drain bore
20 Oil intake, snorkel
21 Oil pump, scavenger
Lot of options out there but yes! The filter housing may still be available new.
FWIW,
The only suggestion I have is to look for a compatible wax element in a coolant thermostat. The proverbial needle in a haystack.
850CSi, p/n: 11 42 1 405 197 oil filter housing has an internal 85deg.C thermostat
E31, E32, E38, E39, version p/n: 11 42 7 511 171 oil filter housing is identical except it has an 108deg.C internal thermostat.
I installed the CSi oil filter housing on my 1997, 850 with the CSi oil cooler & lines.
As companion upgrades I installed a 85deg.C coolant thermostat, 80/88deg.C fan switch and 105mm coolant pump pulley.
On my 98, 740 which has the 105deg.C MAP thermostat, I installed the p/n: 11 42 7 511 171 oil filter housing that an 108deg.C internal thermostat. I got a new E38 OE oil cooler on eBay for $25.00..
Thanks for the help!
OEM lines and other parts would be nice to use. And the hard lines would definitely be easier to route vs larger diameter rubber or braided hose.
I sure would prefer the 85C thermostat but that may be too difficult to obtain. May be worth looking for the CSi housing before making any purchases.
I ordered a new oil filter housing with hose fittings and several o-rings and the parts came in today. I bought the CSi housing with the 85C thermostat because it gets so hot here in S Texas. I already had the old 7 series cooler and hoses so I would like to use this cooler and have some new lines made up.
I am piecing together a large Behr oil cooler with a new CSi oil filter canister. I also have the two threaded M27-M22x1.5 pipe joints, 17211723261, that fit into canister. The Behr cooler uses M22 conical hose fittings, but I am not sure what type of fitting the CSi lines use to fit onto the threaded pipe joints. Can someone identify the type of fitting on end of the CSi hoses? I would like to find a M22 hose fitting that will connect to these pipe joint adapters. Thanks,
Go to 8Tech for the info he has a good write-up on the oil cooler line upgrade.
www.bimmerforums.com/forum/showthread.php?1494823-How-To-Fit-an-engine-oil-cooler
Thanks for the suggestion! I have been in touch with Gerry and I did find the thread. The fitting I plan to use to make up some custom lines is a 5/8" JIC male to 22x1.5 metric female straight swivel adapter. The female side has an oring on the tube that goes into the oil filter canister adapter.
Sorry to revive an old thread, but has anyone figured out the oil cooler thermostat part#? The closest I could find to an available thermostat is the porsche 911 thermostat
https://www.autohausaz.com/pn/14762626-93010715500
Although I am unsure if it's the RIGHT insert, I am just wondering if anyone has tried it. I believe the ID of the port for the oil cooler exit route is 30mm
Sent from my SM-S916U using Tapatalk
It's a pain in my but using my phone to respond on here.
I finally got around to installing an oil cooler on my car several months ago. I bought a new CSI oil filter housing several years ago and it was only $225 through the dealer. There was a choice of two and I bought the one with the 85° C thermostat since it gets so hot in S Texas.
You also need the adapters to go from the threaded ports on the canister to your lines. I had a large Behr cooler already So I had custom lines made up to fit that. It adds about one and a half quarts additional capacity to oil system.
I think it was Wolf who wanted to try and tap a stock canister and install a thermostat but I don't believe he ever got around to it.
Look on realoem.com for the adapters and I believe it gives a thread size.
Here are the adapters.
Attachment 724438
Attachment 724439
Thank you, JDP530. The problem I'm running is that I nabbed an oil filter canister without the oil cooler (stock 850i), but the milled ports for it, from which I'm modifying to fit the oil cooler to. What I'd like to know is if anyone knows what the oil thermostat insert part # is. Or maybe if someone could perhaps take their thermostat out of their filter housing, share photos of it and it's dimensions.
The problem Im dealing with right now is that the 850csi oil filter housings are NLA, and if sold second-hand, they are VERY expensive. The same goes for the m62 gulf filter.
You don't necessarily need a thermostat if you just give it time to warm up. The oil in my car reaches 85C rather quickly just idling in driveway. But ambient temperature down here is 80° if not hotter on a spring or summer day.
Have you checked schmiedmann website for the canister?
