I have the new style dss ds and I have no issues with vibration
I was trapping over 130 mph last year on drag radials with a $725 DSS DS from Butters, cyro treated rebuilt M3 axles from Butters, and a 188 mm 3.15 diff rebuilt into a 3 clutch by Butters. None of those parts broke. I did break 2 axle stubs, but my launch technique was not smooth or consistent and I think they might have held if I used the handbrake launch technique that Butters was using (he had the same parts, ran more than me, and did not break anything).
The first priority is the driveshaft. The second is rebuilding the 188 diff or going to a 210 diff. The 210 diff requires $150 in parts and some prep and welding time. You can find them used for $250 to $500. Since most 210 that fit come with 6 bolt input, ideally you would buy the 6 bolt DSS DS at the same time (I had a 4 bolt and sold it to buy a 6 bolt for my 210 mm diff). I did not rebuild my 210 since it was a nice example, but will probably do so later this year if funds allow (figure on $500 for a 4 clutch conversion).
$725 for DSS, $150 for 210mm conversion (sell your 188 for the same $250 you pay for the 210), and $200 to cyro and rebuild the axles. You might be able to do this for $1100 rather than $2000. And maybe you could put off the cyro axles since some run the stock ones without issue. The only problem is that if you break one, you then have to buy another.
I've been running on stock m3 axels without any issues running high 10s trapping 133+. Just have to run slicks and know how to launch the car properly they should hold up and if I happen to break one I have 2 sets of spares!
Slicks have the reputation for less breakage with manual transmissions. They also have the reputation for being squirrelly. Have not tried them yet myself.
They're only squirrely if u run a soft side wall (which is what I'm currently running) and if u run them at 18-19 psi its not that bad just have to drive the car up top
I've been looking for a 2.93 LSD, haven't found one yet, and the only 3.15's I've found are $500. I'm going to keep looking. If I ever have enough "spare" money lying around I'll do a full front runner setup with slicks but for now it will have to be radials.
ICS Stage 1 NickG tune, 60lb Injectors, Blow through MAF, Synapse BOV, Boostlogic Manifold, BW-S366, Full 4" exhaust, Built Block w/ Wiseco's and K1 Rods = Good Times
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
not yet I'm picking up a set of mt 26x10x15 stiff side wall slicks for the new wheels today still waiting on studs and lugs before I can't test though
What the heck is a stiff sidewall slick? Not a drag radial ?
Sent from my iPhone using BF.com
Its basically a bias ply slick with a stiff sidewall
So not a drag radial.....what model tire we talking? Maybe that's what I should try first
Mickey Thompson et drag
http://www.jegs.com/webapp/wcs/store...p:OrderItemAdd
These? With the "S" rating for stiffer sidewall?
Yes
here she is with her new shoes! Weld rodlites 15x4 up front 15x8 out back with mt 26x8.5x15 with m3 brakes front & back
How do you fit m3 front brakes in 15 inch wheels? Because brakes are barely in the 4 inch wide wheel?
90 mm studs with 15mm spacers and some shaving of the front calipers
How does it handle on a fast sweeper?
Nice and straight. feels great!
Do you feel the whole car swaying as apposed to the rear?
World record holder for a m52 stock bottom end.
9.41@153 c4 auto 28" et streets, e34 3.64 gearset 900+hp
E36 chassis irs world record holder 8.49@162
Th400, e85, 7685, m50 intake 26.6 lbs of boost
Car doesn't sway at all now. It goes straight as a arrow I'm extremely happy with it!
1996 332IS
Built 3.2
The rear tires are wrinkle walls
Turns out my clutch didn't like the extra grip from the new slicks! So had to get something that would hold. Special thanx to butters for coming thru with this new clutch. Hit em up if you need anything he has great prices and great shipping time. New clutch is a clutchmasters fx400 btw
