Page 4 of 7 FirstFirst 1234567 LastLast
Results 76 to 100 of 157
Thread: billet specialties 15x8 fittment and sizing
  1. #76
    Chicopee, MA usa
    1998 M3 TURBO
    Yup that's what I need haha
    Sent from my iPhone using BF.com
    ICS Stage 1 NickG tune, 60lb Injectors, Blow through MAF, Synapse BOV, Boostlogic Manifold, BW-S366, Full 4" exhaust, Built Block w/ Wiseco's and K1 Rods = Good Times
  2. #77
    Jun 2012
    South fla
    97 332i, 90 535i
    Just ordered a set of 15 inch welds so I'll be retiring these soon
  3. #78
    Chicopee, MA usa
    1998 M3 TURBO
    Quote Originally Posted by Bke36Is View Post
    Why the switch to 15"s ? If you were me, would you use 16"s with drag radials or go straight to 15"s?
  4. #79
    Oct 2008
    Albuquerque
    a m3 on a 7675
    Drag radials break shit, with a 15" rim you have way more of a cushion effect especially with a bias tire.
    World record holder for a m52 stock bottom end.
    9.41@153 c4 auto 28" et streets, e34 3.64 gearset 900+hp
    E36 chassis irs world record holder 8.49@162
    Th400, e85, 7685, m50 intake 26.6 lbs of boost
  5. #80
    Jun 2012
    South fla
    97 332i, 90 535i
    It depends on what ur goals are. I'm switching to 15s cuz theres more of a selection when it comes to tires theres only 1 or 2 choices in a 16 inch
  6. #81
    Jun 2012
    South fla
    97 332i, 90 535i
    I'd stay away from drag radials if I were u. Every drivetrain component I've broken has been while running the dr. Ur better off going with a full slick they're more forgiving on the driveline
  7. #82
    Manchester, N.H.
    96 332IS 6466 turbo
    Going full slick requires front as well. I've been debating this as well . I have a set of Hoosiers and also drag radials. Since I've been preloading with handbrake , I have yet to break anything. John from CES is deep into the 10s running a very simple setup. No antilag, no NOS, even has stock M3 axles. He probably has more passes on that car than the majority here combined. Very impressive and inspirational.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  8. #83
    Chicopee, MA usa
    1998 M3 TURBO
    My goal is a 10 second pass haha
  9. #84
    Chicopee, MA usa
    1998 M3 TURBO
    Quote Originally Posted by e36ALPINE View Post
    My goal is a 10 second pass haha Sent from my iPhone using BF.com
    There isn't a 15" wheel that clears the m3 brakes correct?
    I also wonder how many people have actually ran Slicks without the front runners. I know some people that have done it say it isn't that bad. My car runs like it's on rails now but I'm not sure I would without street tires on. I can pick up 4 15" bottle caps local for like $75. I might just do that and grind the calipers down. That way there I could still start with a radial and then go to a slick if I wanted.
    Welp I'm going to pick up some style 6 15" wheels within the next couple days. I'll grind down the calipers as much as I have to I guess. If M&H drag radials have the softest sidewalls I might go with them. If I find some slicks cheap enough I might at least try them.
    Will a 28"x9" slick fit?
  10. #85
    Manchester, N.H.
    96 332IS 6466 turbo
    26 inch fits
    1996 332IS
    Built 3.2
  11. #86
    Chicopee, MA usa
    1998 M3 TURBO
    you can't fit a 15" rim on the front correct? I found a cheap set of rear and front skinnies but they're 15" all the way around.
  12. #87
    Jun 2012
    South fla
    97 332i, 90 535i
    Front runners shouldn't be an issue if u run a 3.5 or 4 inch wide rim once I put my front runners on I'll post up some pics
  13. #88
    Oct 2008
    Albuquerque
    a m3 on a 7675
    28x9 ,,,, would be awsome but it would take ALOT to fit a 28x9.
    the biggest you can fit with a agressive pull on the fenders and 5 1/2 backspace 15" rim is a 27" tire and the ass end needs to come up alot.
  14. #89
    Jun 2012
    South fla
    97 332i, 90 535i
    10s are doable with the right tires out back. Here's mine left lane
  15. #90
    Manchester, N.H.
    96 332IS 6466 turbo
    10s are doable with drag radials as well. Just need to be a good driver.
    1996 332IS
    Built 3.2
  16. #91
    Jun 2012
    South fla
    97 332i, 90 535i
    Radials r harsh on the drivetrain unless ur running an auto
  17. #92
    Chicopee, MA usa
    1998 M3 TURBO
    Are you the one that was running bias ply's with regular front tires?
  18. #93
    Jun 2012
    South fla
    97 332i, 90 535i
    Yes thats me
  19. #94
    Chicopee, MA usa
    1998 M3 TURBO
    Maybe I should just do the 210mm diff swap now.
    Yes thats me
    And you never felt as though you were going to lose control?
  20. #95
    Jun 2012
    South fla
    97 332i, 90 535i
    Yes I highly recommend u do the upgrade or u will break the stock med case diff they just can't hold anything over 350 whp on the drag strip
  21. #96
    Chicopee, MA usa
    1998 M3 TURBO
    I forgot, the only smart way to do it is to also buy the DSS $850 6 bolt driveshaft. And then whats really the point without the $1000 axles? This sucks. I'm looking at over $2000. Probably not going to happen.
  22. #97
    Jun 2012
    South fla
    97 332i, 90 535i
    I have the dss driveshaft and an evo m3 (big case) diff upgraded by bimmers.com and stock m3 axles so far they're holding up pulling 1.5 60 fts. Ur looking at right around $2k or so for the upgrade I know its allot of coin to drop but its way worth it.
  23. #98
    Manchester, N.H.
    96 332IS 6466 turbo
    I can get you that driveshaft for $725 shipped brand new.
    1996 332IS
    Built 3.2
  24. #99
    Jun 2012
    South fla
    97 332i, 90 535i
    ^ thats what I paid for mine!
  25. #100
    Chicopee, MA usa
    1998 M3 TURBO
    Is the vibration stuff solved on the new shafts or what?
