Yeah but what about brake clearance up front? Have u ever tried to fit a set onto ur ride?
http://weldwheels.com/shop/street-st...s/prostar.html
Jordans car with 15s up front
World record holder for a m52 stock bottom end.
9.41@153 c4 auto 28" et streets, e34 3.64 gearset 900+hp
E36 chassis irs world record holder 8.49@162
Th400, e85, 7685, m50 intake 26.6 lbs of boost
Oh my! That looks hot! Do u happen to know the specs on them wheels?
15x8 rear with 5 1/2 backspace
not too sure on the fronts but I think it's 15x4
Nice! Ima look into them
Your lookin at about a G for the wheels.
and run low pressure and bias all around and alot more safer.
1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
Buy some 330i spares. They are 17x4.5 and will fit m3 front brakes. They are about $50 from the dealer new. Moroso , M/T , M&H all make 17 front runners. But I think M&H is the only one that has a 4+ inch front. The others are 2.5 wide. Iirc.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
http://www.realoem.com/bmw/showparts...=36&fg=95&hl=1
these look pretty , wonder how much are?
1996 332IS
Built 3.2
Ecs has em for 55$
gonna grab some , but man the rubber is alot to wrap em in.
1996 332IS
Built 3.2
ICS Stage 1 NickG tune, 60lb Injectors, Blow through MAF, Synapse BOV, Boostlogic Manifold, BW-S366, Full 4" exhaust, Built Block w/ Wiseco's and K1 Rods = Good Times
1996 332IS
Built 3.2
1996 332IS
Built 3.2
Yeah , I just looked on the Hoosier website. They say recommended 8" wheel but I guess they'll fit. $220 a piece from Jegs. M&H only offers one 16" and I thinks its a 275 series.
For that matter I have one 17" ds2 that's 7.5" wide now. Maybe I should just pick up one more and do 17's. Not sure how big of a difference there would be for 60' times
We ran 255/50/16 M/T drag radials on 328is wheels. No problem. Many others have as well.
1996 332IS
Built 3.2
Alright I'll give you $500 for the setup haha.
Sent from my iPhone using BF.com
1995 540i /6 speed, Black on black, VF m62 S/C kit v3 6psi - Cold air intake/ SSSquid Tune/racing exhuast, Vortech 8:1 RRFPR ,545 SSK /3.15 with LSD / rev-shift motor mounts/stage 4, 6 puck clutch/ K Sport coil overs / suede sparco 368 steering wheel, Recaro seats, N2O, M/T drag slicks
"Skill can only get you so far, then comes money!"
R . I . P Paul Walker - 1973 - 2013
Looking fancy up there. Zenn's 5 with I believe also running the same wheels .
― George Orwell
