Nice work on the pull! I am glad you were able to still have the vertical face on the edge of the fender!
1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
subscribed!
ICS Stage 1 NickG tune, 60lb Injectors, Blow through MAF, Synapse BOV, Boostlogic Manifold, BW-S366, Full 4" exhaust, Built Block w/ Wiseco's and K1 Rods = Good Times
Just picked up a pair of Hoosier drag slicks, they are 26 x 10 x 15.
Only a few passes according to the PO. I think I want to go a different route. If someone wants them PM me for pricing. Don't want to clutter this thread. But kinda on topic.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Are u guys running slicks with inner tubes?
I don't run tubes. Just seems like an added complication... And they can stick to the tire, so u gotta use talcom powder... I think they are more suited for very low-pressure slicks to keep them stable on the top end of the track.
So it's fine to run a 275 series tire on a 8" wide wheel? The m&h said it needed to be at least an 8.5" wheel. I need to make a list of wheels that will fit with the proper back spacing. Evertime I go on craigslist to try and find a deal I get confused and cant remember which wheels would work.
http://westernmass.craigslist.org/pts/4571073806.html
Will the wheels work just not the tires at 28" tall?
so I went to the track this past Wednesday night for a test n tune and this happened. No more drag radials for me I'm switching to a bias ply I'm tired of breaking ish!
Holy hell! What DR were you running?
I was running the nitto 555r Dr 245/50/16
World record holder for a m52 stock bottom end.
9.41@153 c4 auto 28" et streets, e34 3.64 gearset 900+hp
E36 chassis irs world record holder 8.49@162
Th400, e85, 7685, m50 intake 26.6 lbs of boost
Wow that ish looks hot! I need to step down to 15s eventually but the 16s are working for now I was able to pull a 1.55 60 ft with them!
THanks man.
Heak yeah man , 1.55 is awsome , there alot involoved going 15" rims unless you can the right backspace.
With antilag and these tires I'm shooting for sub 1.5 60s
U'll definitely get there that's for sure! I'm pretty consistently in the 1.5-1.6 60 ft no 2 step or anti lag! Just a lil 50 shot out the hole!
What tires are you running on aigan?
These tires made my 3.15 diff feel like a 2.93
Hoosier quick time pro 26x9.5x16 but they're too narrow I have to run 18 psi in them to keep the car from doin the dance up top!
These seem pretty stable
I hit it in 3rd on the highway and felt pretty good
15 psi is recomended for best results so I'm curious how they will react , Have you tried airing up your fronts to like 50 psi.
Yep there already there! I'd love to find a set of front runners that'll work on our cars!
Gm bolt pattern.
