so im looking for some 15" wheels and local guy has these for sale for a really good deal, i wanted to see if someone has experience fitting domestic 15" rims to the e36.
15x8 5x 4-3/4 or 5x 120 with 5.5 backspace
thanks in advance.
http://www.jegs.com/i/Billet-Special...arentProductId=
World record holder for a m52 stock bottom end.
9.41@153 c4 auto 28" et streets, e34 3.64 gearset 900+hp
E36 chassis irs world record holder 8.49@162
Th400, e85, 7685, m50 intake 26.6 lbs of boost
Someone be getting some slicks.
Please share your findings. I have been interested in this as well.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
yes , i figured it time to go a little faster or atleast try.
15" rim is key for low 60ft times and this is why i decided on 15" rims. Ive been doing more digging and here is what i got.
e36 has a 5x120 bolt pattern and the weld and billet wheels along with domestic stuff is 5x4.75 and that = 5x120.6.
5x120.6 is not 5x120 but it is VERY close , i spoke to david tran and he has ran a 5x4.74 domestic wheel befor and the jegs guy says that fittment should not be an issue. the only thing im waiting on now if for my friend to measure the hub bore to see if they jive with the e36 hub.
also has anyone ever tried to run a 27" tire?, both hoosier and mickey thompson make one.
Turns out it's right at 5.1/2" back spacing
bmw is 72.56 mm the billet rim is 78.23 and I found some hubcentric rings that will make up. The differance.
and boom ..http://www.jegs.com/i/Detroit+Wheels...256-4/10002/-1
We're u able to mount these bad boys up yet? How's the fitment?
Nice! I'm looking to move down to 15s myself but I wanna see how the 16 inch DRs do first!
My best time to date is 12.2 @ 112mph with a 1.78 60 ft on the 16s with a 120 shot of n20. But now it's boosted haven't been to the track yet hope to take it soon though still have to reinforce the rear subframe mounts and put all new bushings back there and recently put in a dss ds so should be decent on the track!
I finally got some 15s to work. Took quite the amount of work.
Needed to pull my H&R OE sport springs, drop in some raceland rear springs and height adjusters pretty much maxed. Also needed to install 12mm spacers.
What OEM 15inch wheel is common for this mod? Im not sure what style im running but ill get the #s off it later. They are 15x7 and et of 40iirc
1996 332IS
Built 3.2
Did you have to alter the calipers ?
1996 332IS
Built 3.2
1996 332IS
Built 3.2
Butters, more pics of what you did?
OP-Perhaps I have asked before...I forget. What mods on the fenders have you done to fit that size tire out back?...sorry if I have asked before.
1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
1996 332IS
Built 3.2
Ah. Misread.
Op, nvm I see I have asked before about the fenders. They must be pulled pretty well to clear the if tires, no?
The best tire for a high power manual trans is a bias ply slick, not drag radial. Its very hard to make a radial stick and not spin with a manual trans high horsepower. Bias ply slicks can spin and still be gripping, radials cannot. They usually stick or spin, there is not much in between. and when they stick, its usually an automatic car with awesome suspension that has been dialed in properly.
Need front runners with a Bias Ply?
1996 332IS
Built 3.2
Yeah...I thought so..need something I can drive on the street w/o needing front runners.
OP-have pics of what your fenders look like with those 275's mounted?
People mix radials and bias slicks... But it's not very safe. I drive my front runners on the street all the time. Just have to know their capabilities.... Like no turning or stopping LOL
Hahaha..no thanks..not for my case anyway..
Sorry, didn't mean to thread jack.
If I was going for sub 1.5 60 ft I'd get a bias ply setup and skinnies up front
by best 60 to date is 1.9 .... Shitty shitty
if I can pull a 1.6 or a 1.5 on drag radials I'd be happy
Well good luck my friend! I'm rooting for ya!
Gonna na have to do some fender pulling/ busy work
decided to try the Hoosiers , a guy had em for sale locally at a killer deal .
And mounted had to pull the fenders
[/URL]
