BMW E36 NASA GTS2 Race car
Price $16000 +$1000 data system
Car has been looked after by
2014 - Bimmer Blue motorsports
2013/2012 - Northeast & bulldog motorsports
prior- 3D Autoworks in NH.
Chassis and safety:
1994 E36 BMW.
8 point SCCA legal cage with x bar in rear, nascar door bars for driver and x bars for passanger, x in rear downtubes, additional roof bar, dash bar, additional cross bar for harness mounting for taller drivers.
All chassis re enforcements welded in.
20 gallon fuel cell mounted in trunk, new bladder in 2010.
Halon fire system with 2 nozzles on driver and 1 in engine bay.
Electrical cut out switch.
2010 Sparco Pro Advanced drivers seat with halo protection, welded to chassis/cage.
2011 Cobra Monaco passanger seat on VAC mount.
Schroth 6 point Profi belts for driver
Drivers side net in date.
AMB transponder hard wired in.
Has a current NASA GTS2 logbook with last annual tech done in 2013. Finished 2 races.
Engine :
S52 (E36 M3 engine) with OBD1 conversion. 60K miles on bottom end, 30K miles on top end (installed Mar 2012)
UUC oil cooler
RRT race cooling system, large aluminum radiator, euro resevior etc, electric fan on a switch.
Transmission :
Getrag 5 speed + Bimmerworld Getrag rebuit transmission available as a spare.
RRT /Diffsonline race diff, polished gears etc, connection point for diff temp monitor + spare diff.
New clutch installed May 2012.
Lightened flywheel.
VAC oil pan baffle and new oil pump with welded/wired nut installed Mar 2011.
Brakes :
Rebuilt front calipers installed May 2012.
SS lines
Brake ducts in front bumper with new hoses to adapters on the back of the hubs (not sure which ones but they work fine and are a nice blue color ...).
New rotors installed Mar 2012 + spare new front and rear rotors included.
Hawke DTC pads front and read (70% left) + 4 sets of used HT10 pads, 20-40% left on each included.
Suspension:
Brand New - just installed : E36 TC Kline Racing Double Adjustable Coilover Kit - http://www.tcklineracing.com/webdocs/Items/Details375.cfm
Ground Control adjustable sway bars.
All bearings and bushings replaced with sperical bearings.
Wheels and Tires :
4 Kosei 15x8 wheels with 225/45/15 Hoosier R6 tires (7 heat cycles, lots of tread left)
4 15x7 wheels (unsure of type) with 225/45/15 Toyo RA1 (40% tread left)
4 Stock BMW wheels with 205/50/15 Star Spec tires for rains (bearly used)
Data Logging (available as extra)
Aim Evo 4 data logging with MyChron3 Dash (GPS position/speed, oil pressure, water temp, throttle position, brake position + spare channels to add more, digital dash with shift lights and 4 channel warning lights).
Other :
PC680 lightweight battery in trunk (New 2011)
Repainted black then vynal wrapped, paint is not perfect but it looks good for a track car.
Carbon rear wing.
Heavy duty front race splitter from sneed for speed (splitter has a lifetime warranty)
http://www.sneed4speed.com/bmw-splitter-for-e36-m3-by-sneed4speed/
Spares :
3 very large plastic bins full including what is listed bellow plus more since I never went through and listed it all
Spare E36 front bumper new and unpainted.
Spare E36 M3 bumper, some cracks.
Full set of brake rotors, 4 sets of used HT10 pads.
Diff
Stock radiator, 2 OBD1 M50 intakes,
Full set of injectors
Control arms and other suspension parts.
2 Spare ECUs (unknow types)
List Date: 3/23/2014
For more info, click here to view the original listing: BMW E36 NASA GTS2 Race car
This item is no longer available.
Last edited by apochiraju; 06-22-2016 at 02:03 PM. Reason: latest state of the car.
More pics here https://www.dropbox.com/sc/va087yjgrrq671y/sKPuVTDyl8
