Didn't read which DME you're using but make sure it's from the manual trans car. Otherwise it's expecting feedback from the auto trans computer and it will be retarding ignition timing
Mike
93 M5 3.8 Sterling Silver/Black (euro)
94 M5 Touring Madeiraschwarz/Black
80 745i (project)
83 735i / 5 speed (euro)
86 745i
Kinghorn, did you ever get that third brake light out with those rusty screws?
Mottati: Holy crap... Ahahaha! I have a HOOOOORIBBLE rough idle, and I mean vicious at stops. Thought you had to switch DME's but decided ill wait it out and if the car starts it starts, if not, swap DME's but this could be the solution! Im running the stock motors DME, so ill swap it over tonight and hopefully comeback with some awesome results! Thank you so much sir!
Edit: Welp, the parts car 530i/5 had the hood off as well as the engine software cover during the rain so yes some rain got into the 404 DME out of the manual car. Took it apart and cleaned up all the contacts/parts off water, letting it air dry for the next coupla days then once i feel its completely dry ill install it and hopefully it fixes most of my issues. thanks for the suggestion once again!
Chuddism: Not yet, and its so embarrassing driving around with a quarter of the third brake light bulbs lighting up. I may just try drilling them out and disposing of this third brake light if i cant properly get them out. You going through the same struggles?
Chuddism: Not yet, and its so embarrassing driving around with a quarter of the third brake light bulbs lighting up. I may just try drilling them out and disposing of this third brake light if i cant properly get them out. You going through the same struggles?[/QUOTE]
Yep, rusted to hell. I want to get the light sent off to sse43 to get swapped to LEDs so I might fire up my drill.
Or just swap the chip. (or even better get an aftermarket manual 530 chip)
Mike
80 745i (project)
86 745i
Mottati: both dme's were 404's so i didn't know if swapping would solve the issue, so I swapped anyway and the car ran even worse. not sure if it was supposed to happen, but it did. All ive done is kept the stock engine harness/software, just swapped the tranny and motor (Doesn't rev hang...) May end up purchasing a DUDM chip... just don't know if it would even help... Now that i penciled out software once again, it may just be a vacuum leak. Im still looking for a secondary throttle body cable, and then ill swap my old intake mani, or may just even pick up a b40 intake mani and throttle body if i have the cash... but hopefully that will solve the issue.
Chuddism: Lol, try to use a tap kit to drill the rusted bolt out first (10 bucks) and if not, then id go for drillin the sucker out. but good luck and let me know the results, may just attempt this tonight as well...
hood opening mechanism broke, so the hood pops open one the roads. anyone have a parts car that has this part they'd wanna sell me
also wired in a quick release clip for my subs, and washed/waxed the touring again...
the car should run ok with both dmes but the software is different for the manual vs auto. When i did my 6 speed swap on my 530iT, it was a dog, really flat in the midrange. Timing was being retarded because the dme with auto trans will retard timing when the trans shifts, or when not in gear, vs normal acceleration. Swapping the chip made a huge difference in performance.
But the car idled and ran fine, it was smooth etc. If you've got idle issues, something else is going on. Did the engine run ok in the donor car before the swap? Sure there are no vacuum leaks? Crank sensor ok?
I'd be a bit hesitant to use the dme that was flooded. Put the manual trans chip in the wagon's dme.
Mike
80 745i (project)
86 745i
i didnt read eventhing, but did you do the intake gaskets? if you have a rough idle, thats definitely where id start. And when you take a look at the condition of the knock sensors when you pull the intake, PM me, i have a nearly brand new set of Bosch knock sensors for sale .
As far as the diff goes, the 3.23 felt fine in my b40/6spd. The 5spd ratios are basically the first 5 of the 6spd. Without that overdrive gear, anything shorter than the 3.23 will be screaming at highway speeds! i get it though, with the power the b30 has, a gearing change will help it feel a bit faster.
And about the auto vs. manual chips. Mottati is correct, the auto chip is a little short on power below about 3krpm. And the idle will hang between shifts. I would definitely be using the manual 530i dme/chip. I do highly recommend DUDMD chips!
I also have all these things. PM me if interested in anything.
-Alex
It did run fine, just a bit rougher with a loud vacuum noise, swapped the old dme back in and it didn't do it again. Im going to take your advice though and just swap the chips for now, so id be fine taking the old manual 530 chip and throwing it in the tourings auto DME? (it was rained on so this could be the issue as well. It sounds like I have this problem, cus the low-mid range doesn't seem usual. Yes the donor motor prior to pulling ran fine and smooth, it just runs like this now. Their may be some vacuum leaks though, thats what im leading to believe now. We did have a rough time with the crank sensor, would this cause the idle? oh and the cars idle sits around 550 RPM which seems a tad low, and while the cars in neutral on the streets my cluster lights get brighter and dimmer as if the cars about to die. maybe the idles too low?
The motor was just basically pulled and thrown into the touring. When it was running prior, it ran smooth! I do have new intake manifold gaskets, knock sensors, pcv valve, their just on my old motor, so when I upgrade to the B40 intake manifold and throttle body ill throw on the new maintenance items. My point exactly with the diff, its not bad, i just want a lil more ummmph, so im on the hunt for a S3.46
As for the chip, im just going to end up swapping just the chips at the moment and see where it takes me. Now that I think about it the car did rev hang but only very slightly. Thanks for the input, and you've got a pm coming your way for the whole 540i intake mani + throttle body
yes the manual chip will go into the auto dme, they're the same dme other than the chip programming. I didn't use a stock manual trans chip, but when i did the dudmd 530 manual chip onto my dme it did raise the idle speed up a little. Automatic trans is set to idle a little lower.
Mike
80 745i (project)
86 745i
this congratulations is quite a bit late, but great job on the thread! I know I already commented on your IG photo, but I cant explain how happy I am to see someone else share the passion of the e34 wagons that I have. even more so that we are round about the same age! ill have my own thread soon, more than likely when I get my license . (2 months away)
So after a couple weeks, im back at it with another update.
Here is a few legit shots of my touring over the past little while
**Note the new bumper that's not cracked/broken, should get painted soon,
and also the ONE 540i duct
as well as a roller of anthonys e34 from earlier today.
this section is mainly devoted to chuddism... lol, my whole third brake light ordeal.
tightest spot ive ever had to solder in, less than a third of a cm of room,
and joints still are still spot on contact and not touching. (4 prong connector)
finished product
Redid the foot well lighting, yes I need my drivers kickpanel on...
A photo of my horrible, cracked, chipped, broken tabbed, zip tied,
misalligned previous bumper. lol.
Then two weeks after the swap and what I thought was a fresh motor,
the water pump had started to leak...
New water pump, (metal impeller) as well as new o-rings and gaskets.
Oh, and metal thermostat housing as well as new thermostat.
Finally got around to pulling the manual chip out of the prior 530i/5's dme.
Will throw the chip in tomorrow and see if it makes any difference (hopefully it increases my current 10MPG)
because I have vacuum issues as well, I thought, might as well pickup a B40 Intake mani and throttle body
and do a complete intake reseal while I swap in the B40 manifold. So basically new gaskets and plates all around
It should add twenty horses and make her idle properly. Thanks Alex (ahenry014) once again brotha!
(comparison of bottom b30 mani/top b40 mani)
When installing the previous b30 intake sensor, the threads broke off in the whole sooooo
yeah... gay.
So that's it for this update, for now please enjoy this photo again because its my favorite.
The last photo is great. Good progress man!
Why didn't you just solder led's to the oem board?
Good job on the third brake light. I like the LEDs. If it ever stops being so freaking cold in NY I may just try to drill the damn thing out.
-Alex
Looks really good. Those 530's will run forever because they were never run out by the little old ladies that were the first owners. They also love a chip.
Wagon's with sticks....welcome to the club.
Thanks guys!
because this project was half the cost of soldering them to the board, looked cooler, and was something different. You will start to see this on most of the new cars nowadays. Love your touring by the way!
This is horrible news. I plan on throwing a b40 in as soon as this motor dies, but if you say so... and thanks! It will end up getting a chip, most likely a DUDMD.
and yeeeup! wagons with sticks are where its at! Glad to be a part of it (:
A cockpit shot
My CB radio install. Hardwired in as well as an external speaker for my PA system
Mostly back to the way it was, everything being tidied and fixed up for reinstall. Looks so clean!
Because their isn't enough space in a touring, I bought a roof rack for under 30 bucks (Future plans with this are in the works )
Will hopefully be installing the new B40 Intake manifold/TB this weekend
as well as resealing the entire intake. Reaching for 255hp with a b40 IM/TB & DUDMD Performance Chip.
Thanks once again!
Didn't know they still made CB radios
Wagon is coming along nicely. Wish I only had $30 into my rack.
my version of a midlife crisis: 20 year old spray painted, lowered BMW station wagon.
Nice touring and great job. Interior looks very nice
Have you tested performance?
Mine -93 530A touring went 8,4 0-100km/h and 1/4 was 15,4
lol i did the CB radio and PA speaker back in the day too. The CB was awesome for long distance road trips/cruises with friends.
-Alex
Man, I want a $30 roof rack. Good work on your touring!
Holy crap, is that 8awg amp-install wire for that LED strip? I mean, you'll never have a problem with the wire heating up. lol.
Hey Kinghorn, the trunk lid you sold me is exactly what I wanted, thanks again. My current trunk didn't even have the little spring-loaded poppers, so I'm gaining functionality in addition to removing rust!
Somewhat on topic, a factory B30 5 speed (in the UK): http://www.pistonheads.com/regulars/...-carpool/31742
They do, they do. Thanks stud, and actually $32 and some change but your rack is 14x's better.
Thanks, as for performance I have not tested yet. Need to though, and the local drag strips having something next month so ill get back to you then. Pretty good numbers for the quarter mile!
Great minds think alike!
Thank you sir! Yes it was 8awg wiring, but only for a foot or so. Wanted something that could handle the heat and not break or shred upon opening the tailgate/window ahahaha.
Great news Brent! Glad it everything worked out. and Sorta sad, but id trade my touring for that euro spec RHD one in a heartbeat....
A small update:
-I got grounded, (HA!) so my keys were taken away. Thought I had spares, but I don't, fml.
-Although they tried to shut me down, progress doesn't stop...
Probably two months back, I was looking for diff options, saw that most 535i/5's had LSD's
remembered that we have a 535i/5 as a parts car, ran the vin and came back to be a S3.46 w/ 25% locking rate
(Photo is of our Third Parts car E34, this one being a 535i/5 that was a donor.
Sorry for the iphone pics, didn't want to take camera down into Mexico)
Rear seal is toast. $10 gasket, new input shaft, and needs new fluid anyway.
My work area, lol.
My boy chewy helpin out
and also pulled an m20 head that was recently resurfaced and refurbished
less than 200 miles before me pulling it. **FOR SALE**
and that's about it. thanks for reading!
