Thanks Dan, had some Noico in the lab for an old audio project, never thought to use it for this!
Btw Olin, did you use a M10x160mm bolt to connect both pedals to the pedal bracket? I ordered the 90mm bolt that was in your parts list, but there doesn't seem to be any other way to mount the pedals side-by-side without a long 160mm bolt going through both sets of bushings.
Gotya, thanks...on order ;-) I wonder why the realoem for the euro 840 shows the clutch pedal attached with the m10x90.
Got the pedals back in, clutch bled and tested. This thing works! Not bad for an old airline pilot guy
I tested it while still up on jack stands, without the exhaust. This thing sounds like a top fuel dragster when revved. Still have to get it all patched back together and do a road test, but I want to thank Olin and Terminator for making this doable!
Just wondering if you had any issues with getting the stick into reverse. I can feel all the gates in the gearbox 1-6, but it doesn't seem to want to get into reverse. I googled it and apparently you really have to force the stick left to compress the reverse spring. Just wondering about your experience with this. I'd hate to find out my Getrag 420 is bad, but they seem to be pretty bullet proof so I'm wondering if I'm missing something here.
I think it's an adjustment isue. The stick doesn't seem to be able to physically go over to the left far enough. I've fiddled with the selector rod to no avail. The BMW service manual says to put in in reverse, then use a template to line up the stick. I can't seem to manually put the thing into reverse to begin with.
Are you using the 840-specific linkage? If so, are you sure it isn't in upside-down or something?
Woo-hoo!!! Finally got it. I'm using all 840 stock parts. The selector rod for some reason didn't want to cooperate but I went back underneath and finally got the damn thing positioned properly. As I suspected, it was an adjustment issue. There's no real guidance on this anywhere, so like an infinite number of monkeys in front of an infinite number of typewriters, I now have reverse. Finally I can get the exhaust back on and get it road tested
I am anxious to hear how it drives.
Road test - AOK! Runs really smooth through all gears, a lot of fun to drive. Still have to bring it to the shop to get the catback exhaust put on. Well worth the time and effort, as I'm sure others would agree!
For others..... http://www.ebay.com/itm/291905121444...%3AMEBIDX%3AIT
91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
Yea I contacted the guy asking where the 8 series shifter linkage and interior bits were and he apologized, quickly updating the (Panjo) ad in the process.
2006 R53 JCW (British Racing Green) - 1994 E31 840Ci 6spd (AVUS Blue)
2021 F56 JCW (Rebel Green) - 2000 E38 740i Sport (Titanium Silver)
2017 F26 X4 M40i (Carbon Black) - 2007 E91 328iT (Deep Green)
2012 E82 135i M Sport (Marrakesh Brown) - 2015 E84 X1 (Cashmere Silver)
2005 E53 X5 3.0i Sport (Kalahari Beige) - 2000 E36/7 M Roadster (Oxford Green)
2000 E38 740i Sport (Oxford Green) - 1999 E36 M3 Coupe (Fern Green)
1995 E31 840Ci Canadian (Oxford Green) - 2000 E36/8 M Coupe (Oxford Green)
2004 E46 330Ci (Oxford Green) - 2001 E36/8 Z3 3.0i Coupe (Oxford Green)
2002 E39 525i Sport (Oxford Green) - 2002 E36/7 M Roadster (Oxford Green)
2001 E53 X5 3.0i Sport (Oxford Green) - 2007 E63 M6 (Silver Grey)
1995 E31 840Ci (Oxford Green) - 2006 E86 M Coupe (Sepang Bronze)
2001 E39 530i Sport (Aspen Silver) - 2009 E92 M3 (Space Grey)
2001 E38 740i Sport (Sahara Beige) - 2008 E92 M3 (Melbourne Red)
2000 E38 740i Sport Canadian (Sahara Beige) - 1997 E31 850Ci (Jet Black)
http://www.8er.org/forum/showthread.php?13164-From-automatic-to-manuel-conversion-840&referrerid=5465
Check out this thread from 8.er.org. Svein/Terminator did his conversion with an M60. There are a lot of photos with this conversion too. I believe you will have to join to open the thread.
Olin,
I am getting some parts together to prepare for an eventual swap of my 560g to a 420g.
1st to 2nd is notchy, and I'm sure that it won't last forever.
Looking through the 840 specific shifter parts, the shifting arm is still available, and the shift lever, but the shift rod, 25111222367 seems to be NLA.
Do you happen to have the dimensions? I think with the length, and the offset, as it's angled at either end, I could have one fabricated when the time comes.
Schmeidmann to the rescue:
https://www.schmiedmann.com/en/catn-ol?q=25111222367
I'm gunning for the 6 speed swap. I bought myself a getrag 420g and pedal assembly from an e39 540i as well as a shifter arm specific for the 840. What other "essentials" should I look out for? I'm trying to collect all the components bit by bit. Also. How does one get a manual driveshaft? Do I have to take mine into a shop; do I have to buy another and have them both combined, or do I have one completely custom made? I know it's going to be impossible to find an oem one
Sent from my SM-G970U using Tapatalk
E39 pedals won't do anything for you. You need the clutch and brake pedal from any manual E31, E32, or E34 - doesn't matter what engine. On one of the earlier pages of this thread I supplied a parts list with part numbers that includes everything you must gather before attempting the swap. Even the exhaust brackets are different if you want to do it right. As for the driveshaft, I ordered the 840-specific manual one, but I was working for BMW at the time, so it was priced reasonably. Most people just have their auto one lengthened/balanced.
Thanks Olin! I've returned the e39 pedal and I'm gonna go hunt for an e34 clutch pedal at a junk yard. Any other parts shared with the e34 I could scavenge? Master and slave cylinders too? I'm probably going to grab all the hardware I take off of it as well to use.
Where did you find the trans? At a yard? Did you have to remove it yourself?
Current
95 e31 840 Ci (Auto) Orient Blue 61k
11 e90 328i Space Gray
18 F15 X5 35i XDrive White
Past
00 e38 740 i (Auto) Titanium Silver
94 e31 840 Ci (6 speed conv.) Avus Blau (This car was Awesome!)
03 e46 325 Ci (Auto) Jet Black
91 e31 850i (Auto) Diamond Black, Yes, two!
00 e39 528i (Auto) Jet Black
92 e36 325i (Auto) Laguna Green
