Page 1 of 10 12345678910 LastLast
Results 1 to 25 of 226
Thread: So it begins... US 840Ci 6 speed swap
    Orange County, CA
    840Ci|725tds|Alpina B7
    Hey forum,
    Even though we have a few threads on the subject already, I wanted to create one that chronicles my adventures in putting a Getrag S6S 420G manual transmission into my 1994 M60 840Ci. Now, please keep in mind that this is a LONG TERM project, so updates might be a little scarce. That said, I have already begun to gather the parts necessary to complete the swap:
    For this project, the shift knob, E31-specific linkage parts, and hardware will be new from BMW, but in an effort to make this swap as economical as possible:
    The transmission will be sourced used (likely from an E34 or E39 540i)
    The clutch will be purchased new online.
    Clutch/brake pedals, pedal bracket, and clutch hydraulics will be taken out of a junked manual-transmission E34 5-Series.
    The drive shaft will be sourced overseas or custom-made
    and the differential has already been swapped out with a 3.15 limited-slip unit from an early E32 750iL.
    ***A full parts list will be added once everything is acquired.
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    Cool and finally!
    What "thumbs up" really means
    Nov 2009
    WI
    01M5,72TA,06LBz,850,540m
    sounds good, also has any one put a 4.4 m62 into a Hole where a m60 was? What sensors need to be changed? Modified?
    Orange County, CA
    Quote Originally Posted by cer54467 View Post
    Yes, you just keep it OBDI, and use the 4.4L block. Seen two done so far in person. I don't see what this has to do with the 6-speed though.
    Jun 2010
    Mississauga, ON, Canada
    97 840Ci Individual
    Looking forward to this Olin. Anything different needed to do the swap on an M62 car?
    Orange County, CA
    Quote Originally Posted by lawlshane View Post
    The only difference I'm guessing would be the electronic procedures needed to get the car to start without the automatic. Also, you might need to use a transmission from the later E39 540i and not the earlier one to accommodate the crankshaft position sensor, which is at the flywheel of the M62 instead of the front on the the M60.
    Regina SK. Canada
    1991 850i / 6
    A project you've been contemplating for a while Olin. Are you planning to go with BMW parts right across the board, or have you thought about using some after market stuff, like shifter, clutch, etc? A worthy enterprise sir. Will this make you stand alone as a 6 speed 840 owner in North America?
    Orange County, CA
    Quote Originally Posted by garylafortuna View Post
    No aftermarket stuff. I want it to be as if BMW built it from the factory.
    No, I know of at least four, personally seen two, and have driven one.
    Mar 2011
    Denver
    1991 BMW 850i
    Not to be a jerk, but wouldn't it be easier and cheaper to source a V12 6speed?
    Orange County, CA
    Quote Originally Posted by DenverMDM View Post
    No because they are rare, not cheap, and would likely not already be as sorted out as the one I've owned for 6+ years...Then I'd be stuck trying to sell this one in a relatively soft used car market. Aside from that, it wouldn't be a V8 6-speed, which is the whole point of this endeavor. Also keep in mind that a used transmission for this car goes for $600-1000 depending where you find it (not an expensive rarity like the V12) the pedals and stuff will be pennies on the dollar at a pick-your-part junkyard, and I get employee pricing on all the new parts, which is cost+ pricing, not a % discount, so some things are like 80% off.
    Belgrade SRB - London UK
    E31 4.4, E66 V12, E70 TT
    That you just make it a wannabe CSI :P
    Keep us posted! I am still considering doing an S62 conversion + 6 speed
    1994 E31 840CI "Sport" 4.4 - Hellrot Red - Black Nappa Leather - Every Option available - OEM 65M Wheels, EDC delete/Bilstein, M60-M62 engine transplant, updated software, CSI Steering box & AHK, Full AC Schnitzer kit, Wood Trim, Front Plate Delete, Xenons + LEDs, Tints, Black Ind. headliner, BREMBO BBK, Hamann Exhaust, Custom aluminium throttle bushings, KAW springs, Strong Strut, Greg K GenII sway bars, Camber Plates, Stut tower reinforcements, X-Brace, Wokke chips, Wokke Sphericals, PM Steer Plates, H&R Spacers, Pioneer AVIC-F60DAB + more.
    1994 E34 530i
    - Calypsorot + Many mods
    2008 E66 760LI V12 - Every Option Available + Full Individual Composition
    2015 F02 750LI Xdrive - Every Option Available + Full Individual Composition
    2013 E70 40d TT - Full BMW Performance Kit
    2016 F06 M6 Gran Coupe Individual
    Indianapolis, IN
    93 850Ci, 09 Caddy SRX
    Quote Originally Posted by olinjohnston View Post
    Hey forum,
    Humm...moved to Coto de Caza (or somewhere close), new 4 series, now this. Lotto winner or recent cartel inductee? Guess "silver" won't be present at the next couple of WrenchFests.Looking forward to the outcome. There's an 840 that was at one of the earlier WF's that had the conversion...all I recall is that it was navy or dark blue.
    Orange County, CA
    Quote Originally Posted by TedBobo View Post
    Hardly...I'm actually not spending that much on this project. And I've seen cell phone bills that are higher than what they charge me for that 4-Series.
    Yeah, it's also a 94. Avus Blue with the 4.4L block swap too. It belongs to John Burgan:
    http://socaleights.com/wp-content/up...ember_2012.pdf
    Sep 2009
    Superior, Arizona
    See Sig!
    Great project and I'll be following it as so far one of the things that has held me back from getting an E31 is the lack of manual transmission cars available here...yes I know they are available with the V12, but they are somewhat few and far between and sometimes command a premium that makes this project make sense. Are you going to be changing out the gauge cluster as well, or is it really necessary?
    Tom
    Current Rides:
    1995 318i-Da Kid's Car Now!, Great Little Car "Pearl"
    1987 Porsche 944 "Liebchen"
    2002 Porsche Boxster "Sunbeam"
    2004 X3 "Xander"
    Past Rides:
    Over 50 Years Worth..Way Too Many To List, But There Were Some Really Fun Ones!!!
    www.ttrs1.com
    tvjake2's Avatar
    tvjake2 is offline SoCalEights - CA BMW CCA Member
    Oct 2012
    Glendale, CA
    '97 840Ci, 1980 308
    Olin - will this project start soon? Will you make the Mullen trip with us?
    Arizona
    2015 328i M Sport
    Cool to see you finally moving along with this... btw that e31 you linked is stunning. ESP those wheels!!
    Indianapolis, IN
    Thx Olin, that means there's 2 conversions. The other 840 was definitely a darker hue and definitely not John's 8er.
    Orange County, CA
    Quote Originally Posted by TJC1 View Post
    Not necessary. The manuals have the exact same instruments, but without the EGS inputs from the automatic transmission, the gear indicator LCD is blank.
    Quote Originally Posted by tvjake2 View Post
    As soon as possible. I need to locate a LOT more parts, and I might not be doing the work at my house. I will complete this, but it's a long term project. This thread might be quiet for several months. Don't worry.
    I work every weekend, so unfortunately I miss a lot of the get-togethers. Definitely won't miss Bimmerfest though.
    And there are others! Ron Inchausti (the mechanic in charge of John's did a Diamond Black one for himself) and a previous forum member, "Nukeduster" I believe did one too.
    Sunny Cali,
    6.5 second 69 Camaro
    He did, Nuke sold that car though.
    IcemanBHE's Avatar
    IcemanBHE is offline ¿pǝpɹɐʇǝɹ noʎ ǝɹɐ
    Wichita,KS/FortCollins,CO
    (4x7)+8=36
    Spent 5 hours in that car. John is a cool dude.
    Oct 2012
    skjold haugesund norway
    1993 bmw e31 840ci
    This is a fun project!!! Will keep watching..
    It's gone feel like you are driving a whole different car afterwards.. a better one!!
    it's not how many miles on a tank,
    but how many smiles
    Svein
    1993 840ci/6 Supercharger
    Nov 2005
    Langley BC Canada
    91 850 Panzer
    Avee up here in BC converted his 840. Also supercharged it...
    91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
    Apr 2006
    San Francisco Ca
    97 840c & 540I6 90 535im
    Will be following this closely Olin, Great project
    97 840ci-99 540i6-90 535i5 all black
    Orange County, CA
    UPDATE 4/20/14:
    Picked up the meat of the swap this morning... The S6S420G:
    The condition looked a little rough, so I am concerned. I think it has been sitting in the garage a LONG time. I don't have any experience with these units, so if anyone can offer some advice on how to judge its condition, that would be much appreciated. The input shaft is rusty, etc, but I got the transmission down to $300 (sorry V12ers), so it was worth the risk to me.
    Jun 2010
    Reykjavik Iceland
    ALPINA B10 BITURBO
    Ok,, as i am not well in the US 840 history,, but as far as i understand,, there are 3 examples of 840 6g in the states,, are they oem G420,, or converted cars ??
    Sveinbjörn Hrafnsson
    E30 CABRIO V12 M70B50 ///
    ALPINA B10 BITURBO 346 @ 507
    ULTIMA Evolution
    Contacts
    http://alpina.123.is/pictures/
