New parts!!! Nice!
Rounded up a bunch of roundie tails, so I will be piecing the best ones together and doing the full LED retrofit. Centers and red sections will be repainted with Testors transparent Candy Apple, then doing a UV clear over the whole lens. If the other lenses are good enough, I will do some spare sets as well. Can't wait to see how they come out, should be fantastic.
Sweet can't wait for more updates!!!
Almost finished with the "Terminator" dash:
Top section - mostly stripped
e10 2002 dash core - Terminator style dash by Spyke e36/e30, on Flickr
Top & Bottom, completely stripped, sanded and smoothed.
Painted, just need to paint the bottom as well (to seal from rust) and clear the whole thing.
e10 2002 dash core - Terminator style dash - Painted by Spyke e36/e30, on Flickr
Nice
The restoration is going great so far! Do I mind asking how much you payed for the car when you got it, and how much you have payed so fer in parts. I want to do a 02 restoration, but I don't know how much it will cost. Thanks!
The cheapest I have seen in CA is in the $2000-$3500 range, though if you don't mind waiting a year and comb Craigslist daily you might be able to find the rare "fire sale" deal. This one looked pretty solid on the body and chassis, I loved the color, complete almost running car, and it was close enough to bring home with a AAA tow. It was listed for $3500, but we ended up closing at $3000.
I have not tallied up my receipts as of yet, but I do have them all and will be putting together a spreadsheet soon and will post it in here.
A proper restoration (full paint removal) price is highly dependent on what percentage of the work you are doing yourself. One of the top concours bimmer restoration shops just crossed the 100k mark, but most shops will be fine between 30k-50k complete, if you do a good chunk yourself expect to pay 20k-30k all in.
If its a cosmetic (or mechanical) refresh, or an "artistic" approach like Spyke's then the total is highly variable.
Neat looking dash core Spyke. While your approach is unconventional, it will be cool to see how it turns out.
Tail light lenses sanded, painted all red, and cleared. Inner diffusers and reflectors removed to allow more light to pass
Freshly painted & cleared tail light lenses by Spyke e36/e30, on Flickr
LED panel lights retrofit
LED panel lights retrofit by Spyke e36/e30, on Flickr
Got new gaskets for the tails too, so now they can go back on the car.
Awesome pics and updates. PM me if you need any 02 parts I have 3 cars worth in my garage and I know how hard to find they can be sometimes
M42 arranged to be picked up next week, scored it for under $200 and already got the trans from a local buddy for $80. M42 > 2002 swap mounts and exhaust manifold ordered up from Jakeb as well.
Looks like things will finally start moving again, excited!
Nice can't wait. .
Engine is now at my house - got my lift and engine stand back from my little brother just in time.
In the final steps of floor prep and surface rust mitigation, so should be painting the interior soon. Pedal box rebuild/upgrade kit just came in as well.
Pictures man!!!! Lol
BMP Aluminum M42 flywheel by Spyke e36, on Flickr
Looking good buddy! Cant wait to see when it's finished
95 Hellrot/Modena 332is, 287k chassis 143k S52, 6 speed 420g, DS2's, 3.23 LSD, 97+ facelift, 96+ climate control conversion.
98 Alpine white/Black and Tan, 328i Sedan 226k chassis 163k M52, Auto to 5 speed ZF manual swapped, E46 sport seats, 2.93 open diff, style 30 wheels, OEM M3 catback, nothing special here
IMG_0152 by Spyke e36, on Flickr
IMG_0153 by Spyke e36, on Flickr
IMG_0162 by Spyke e36, on Flickr
IMG_0164 by Spyke e36, on Flickr
IMG_0161 by Spyke e36, on Flickr
IMG_0158 by Spyke e36, on Flickr
IMG_0168 by Spyke e36, on Flickr
IMG_0165 by Spyke e36, on Flickr
M42 Coil-on-plug conversion kit ordered!
Also found another valve cover to replace the cracked one + full engine wiring harness + 175 ECU.
(I don't think they realized the valve cover was cracked - damage was on the back side, up against the firewall. Hence why I got the whole thing so cheap.)
Love the updates, keep 'em coming!
1998 M3/4/5 - 1994 740iL - 1991 325iX - 1984 745i - 1976 2002 - 2002 x5 Dinan S3 4.6is - 2008 M6/6
Here's my NA M42 refresh list besides hoses, hardware, fluids, and upgrades:
Fuel pressure regulator o-rings
Fuel filter 13321270038
Oil dipstick guide tube 11431717942
Oil dipstick 11431734248
Oil dipstick tube o-rings
Oil intake snorkel 11411715264
Oil intake snorkel gasket 11411715116
Alternator bushings 12311715491 (x2)
Alternator bushings 12311715490 (x2)
Throttle cable clip 13541288013
Throttle cable bar 35411152372
Thermostat 11537511580
Thermostat o-ring 11531721218
Thermostat housing gasket 11531721172
Water pump o-ring 11511714519
Coolant pipe 11531714738
Coolant pipe o-ring 11531709157
Intake manifold gasket (u>l) 11611717761
Intake manifold gasket (>head) 11611734684
Throttle body gasket 13541743261
Timing cover gasket 11141734422
Timing cover gasket 11141247633
Timing case top profile gasket 11141247849
Timing case top profile gasket 11141247837
Chain case gasket (lower) 11141721802
Chain case gasket (upper) 11141721919
Front crankshaft seal 11141439570
Rear flywheel/output shaft seal 11142249533
Sensor o-ring 12141727220 (x2)
Oil filter housing o-ring 11421709513
Oil filter housing gasket 11421709800
Oil filter kit 11-42-1-727-300-M67
Lower M42 oil pan 11131715266
Oil pan bolt 11-13-1-273-093-M36
Upper oil pan gasket 11131739592
Lower oil pan gasket 11131709815
Dipstick tube o-ring 11431287541
Dipstick o-ring 11431717666
Valve cover gasket 11121721876
Spark plug gasket (#2 hole) 11121721475
Spark plug gasket 11121721476 (x3)
NGK BKR6EK (2288) 12-12-9-064-619-M220 (x4)
