Page 2 of 12 FirstFirst 1234567891011 ... LastLast
Results 26 to 50 of 299
Thread: Here at last: jjjjjjj's turbo build.
  1. #26
    Manchester, N.H.
    96 332IS 6466 turbo
    Crack the line and walk away from it for 20min.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  2. #27
    Jul 2004
    Austin, TX
    AA turbo 332i
    lol that was my first idea but not the greenest solution ever.
    I will make sure it gets towed to the proper facility for safe release of refrigerant
    1995 325i | OBD1 S52 | S50 cams | AA Turbo TD06 20g / 42lb / Porsche maf | .140 MLS | F1 s3 clutch | Ultimate SSK | AKG 75D subframe/diff bushings | 3.23 LSD | Powerflex LCAB/RTAB | e46 fca | Raceland coils | BMP rear arms | DEPO HID | AEM Failsafe | Aeromotive FPR | Walbo 255 | 3" Magnaflow muffler/cat/res | 17x8.5/9.5" 225/45 & 255/40
  3. #28
    Mar 2012
    Renton, Wa
    98 m3
    Or Crack the line and have several large baloons handy. This usually works for me.
    You can unbolt the.compressor.and.move it so you can get finished and rolling again if you really want to take it somewhere.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  4. #29
    Manchester, N.H.
    96 332IS 6466 turbo
    134A is environmentally friendly for the most part. You wont be killing the seals and bald eagles.
    1996 332IS
    Built 3.2
  5. #30
    Nov 2011
    St. Louis
    250 & 2.5 Hellrot
    I knew that name looked familiar. Turbo drift car FTW!
  6. #31
    Nov 2010
    portland, Oregon
    1998 m3 coupe, 68 FJ40
    nice work 380whp is a very quick car. I drove around at 380 last year, and its no slouch. You will be blown away. I ran the stage 3 F1 clutch kit, brand new $525 shipped. I loved it, but had to switch to uuc due to cranking up the boost. Held my power at 380 no sweat last year.
  7. #32
    Jul 2004
    Austin, TX
    AA turbo 332i
    Ok so got the front end properly ripped open, no more problems there. Thanks for the environmentally friendly advice!
    Quote Originally Posted by motomanb3 View Post
    Can't wait to get to the track!
    Quote Originally Posted by graphite9 View Post
    I'm really thinking about getting either the stage 3 or 4, leaning toward the 4. Only really want to pull the engine and trans once! F1 says up to like 430ft-lbs with either one but I'm guessing the stage 4 will be a bit harsh... Idc, have hard poly bushings everywhere anyways so what's one more thing, right?
    Should I expect problems with a F1 clutch and a stock flywheel? Getrag trans...
  8. #33
    Manchester, N.H.
    96 332IS 6466 turbo
    Get the stage 3 sprung hub.
    Also you have a package soon from UPS : )
    1996 332IS
    Built 3.2
  9. #34
    Nov 2010
    portland, Oregon
    For $5xx the stage 3 comes with a flywheel. Its a great clutch. Can't beat it for the money.
  10. #35
    Jul 2004
    Austin, TX
    AA turbo 332i
    I've been trying to research this.. Anybody knows what F1 clutch I'll need or if there is a difference between the M50, M52, S52 aftermarket clutches? I have S52 block and will be keeping the stock (getrag I assume) transmission from the 1995 M50tu.
    The F1 S3 right at $500 with a flywheel seems like a great buy but really I have no clue what I can and can't use due to my mixed setup.. Closer to $200 is in my budget right now but I'd really like to do it right and get a lightweight flywheel while it's all apart. My research really has only led me to stuff about 24v e30's as far as compatibility goes and no one seems to use my transmission. I hear it's weak and really hope that's not a red flag but honestly I really don't want to spend the money to upgrade unless it's a 6 speed.
  11. #36
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by jjjjjjj View Post
    Youre drifting? Get a e36 m trans and a stage three F1. Its clear cut. Your trans wont make it a season.
    1989 535i - sold
  12. #37
    Woodbury, MN
    Boosted '92 325is
    I ran my Getrag at 300whp/270wtq (supercharged) and destroyed it after about 3 months of street use. I'm pretty forgiving on my cars too and when it blew it stripped the teeth completely off 2nd gear. I upgraded to a m3 tranny and f1 stage 3 and was very pleased.
  13. #38
    Jul 2004
    Austin, TX
    AA turbo 332i
    Not what I wanted to hear but exactly what I expected
  14. #39
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by Doesnt Matter View Post
    My kid destroyed a getrag with his SCed 325 . Less power than that.
    1996 332IS
    Built 3.2
  15. #40
    Mar 2012
    Renton, Wa
    98 m3
    Dude m3 trans can be had so cheap. Dont worry. Find one with a good dampener and clutch and throw a 100$ clutch in there if you have to.
    1989 535i - sold
  16. #41
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by vollosso View Post
    M3 / 328 trans, just if OP doesn't know. Both ZF
    1996 332IS
    Built 3.2
  17. #42
    Jul 2004
    Austin, TX
    AA turbo 332i
    Yes, thanks! I'll see what I can find. Any downsides to a custom or one-piece driveshaft?
  18. #43
    Mar 2003
    Hell Hole, NC
    325i
    OP,
    If you are going with the ZF transmission. You will need the DS and Guibo disc for it also. Your 325/Getrag use smaller flange.
    Fast lookin' but slow movin'
    237 rwhp N/A power
  19. #44
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by M3poseur View Post
    OP,
    I has a used 328 guibo. Its a little smaller (thickness) than the M3 , but I never had a problem.
    Im willing to donate it to your build. Just send me the $5.80 for the flat rate box.
    1996 332IS
    Built 3.2
  20. #45
    Jul 2004
    Austin, TX
    AA turbo 332i
    Now, to make the one on the left look like the one on the right! Swapping everything from M50tu --> Rebuilt S52 shortblock + S50 cams.
    Perfectly fine 205k M50 shortblock, M50 cams, Getrag 5-speed, clutch/flywheel/PP, driveshaft FS soon by the way. Cheap.
    Got these nice Vorshlag bits for increased cabin comfort Thanks again Casey!
    Also got a .140 MLS (you rock, Butters!) and am currently hunting down a local ZF and driveshaft. Probably going with a F1 S3 kit with the lighter flywheel. My parts list is dwindling down!
    Noticed that F1 clutch is no longer on eBay, now it's all FX and Kupp??? Probably same stuff different name.
  21. #46
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    I went with a Spec III clutch with my initial build....was a great street clutch.....
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
  22. #47
    greenville, nc, usa
    Turbo E36, V8 E39
    Good luck with your build. For your clutch you can just go to gripforce.com to get the f1 stage 3. I just recently bought and installed this clutch. You have to buy the flywheel they offer for the pressure plate to clamp the 6 puck correctly. It will not work with the stock dual mass flywheel unless you buy a brand new one, which cheapest I found was 370 from gripforce as well.
  23. #48
    Ship, Pa
    Red Sled, RC51
    It's funny how so many people blow up the Getrag. I know they are weak, so I purposely tried to blow mine apart at the drag strip and I couldn't. The thing is still fine. I was trapping 118mph.
    "Believe nothing you hear, half of what you read"
  24. #49
    Manchester, N.H.
    96 332IS 6466 turbo
    I think my ZF is on the way out. The input shaft is taking a beating from the twin disc.
    1996 332IS
    Built 3.2
  25. #50
    Dec 2010
    Vancouver, BC
    1998 328is
    Quote Originally Posted by usherboy83 View Post
    I wouldn't suggest trying to pair the f1 clutch disc with an OEM flywheel. The chromoly flywheel has a higher heat capacity, preventing the clutch disc from melting/fusing with it (chromoly's have a higher heat capacity, while ceramic discs have a lower heat capacity)
